[Z06] How Many Z06 Owners Are Running Solid Stainless Exhaust Valves?
#541
Alright Svre46. Congrats on the new heads and the new confidence in your vehicle.
#542
I forgot to mention my Texas Speed PRC's I had installed a few months ago. 2007 Z with 69k miles. Best move I've ever made. Another dropped valve on the forum today. I just don't get it, why would Z owners not get this done.
#543
1. Some are still in warranty.
2. Some of these cars are not paid for and some of these people in here are actually upside down on these cars.
Hard to justify spending the dough on this, in a car which you already owe money on, or which you may owe more money on than it is worth, especially if it is a garage queen, weekend cruiser, and at minimal risk for a dropped valve anyway, based on how you drive it.
3. Some have no intentions of keeping the car, and will likely trade it in on something else in the near future.
4. Some look at the car the same way as they look at any of the other vehicles in their garages. When it is out of warranty, then I'll get rid of it, is the approach they take. Or if they financed it, they will trade it in on something else, long before it is paid off. Or even if the car is paid for, they may take the same approach. Out of warranty, then out it goes, and I'll pick up something else. Perhaps a C7, or a GT-R.
5. Some of these cars are leased.
6. Some over paid for these cars, or if not overpaid, stretched to get them, and resent hearing, and refuse to believe, that the car they bought might have a flaw in it's valve train, and thus see any talk to that effect as potentially further devaluing their property. They direct their ire toward's anyone whom they perceive as reinforcing such beliefs.
7. Some owners simply aren't convinced that there is a problem, or if there is one, that the valves themselves have absolutely no culpability in that which has come to be known as the LS7 valve train issue.
8. Money is tight right now for many in this country. Spending more of it on an item which is a luxury item to begin with, a Corvette Z06, one of the most powerful sports cars in the world, and for a problem which may or may not hit them, and which some in here say will never hit them, some of them from the "big shop with the big GM contract", say is unlikely to hit them, is an expense that many Americans who already have tuition, alimony and taxes to cover, simply cannot justify. People typically do not buy "insurance" if they cannot afford it. For proof of this, look at all of the uninsured motorists out there.
9. It's not hard to convince those who cannot afford insurance, or who don't want to pay for it, that they don't need it. As such, anybody telling them that this is a minor problem, and that there is no need to be concerned, is speaking their language.
10. Solid stainless steel exhaust valves and bronze guides, are not for everybody, any more than are OEM hollow stemmed valves and powdered metal valve guides are for everybody. Some simply do not need to go this route. This is the reason why talk of "crusades" to get others to go this route, amounts to utter nonsense.
People will have to make up their own minds as to if this particular modification is for them, or not, and go from there.
#544
It appears that many or most here are getting their guide wear checked, so I don't get the
#545
Any particular reason that you chose not to respond to the portion of my question relating to components to be used in this rebuild that JwT can't understand is not being universally undertaken? Is it your -- and his -- contention that all LS7 owners should rebuild their heads with bronze guides and solid stem exhaust valves?
#547
Should one check for guide wear beforehand, or would that be ignorant too?
I could care less about this rebuild. I was only supplying information from my own personal experience. You (and whomever) can do whatever you want. Apparently only a small percentage of cars are even susceptible to the guide wear as per GM, so roll the dice and take your chances that you are not one of them if you so choose.
#548
My contention is that an ounce of prevention is worth a pound of cure. Katech is even producing a Titanium valve for those worried about heavy SS valves (I'm not - Super Alloy is working just fine for me).
He already is one of them.
He stated earlier that he has discovered that his #4 exhaust guide is way out of spec.
#549
I don't take advice from a shop that's suppose to be an expert at heads and what valves to use but subs that work out......I'll stick with SS valves that the guy who actually does the work recommends
#550
Well, to set the record straight I encourage everyone to check for guide wear. Routinely. It appears to be your, and others, position that checking guide wear is pointless; rather the heads should be rebuilt with aftermarket parts of a different design regardless. That ounce -- or should I say 98 grams -- of prevention. . . .
#551
Fair enough. That's why I have runflats on my car
A lot of what you are saying, will still fall on deaf ears, and as evidenced by this very thread, there are plenty of people who either don't hear, or don't care what you are "encouraging" because they aren't interested in what you are advocating.
Not "everyone" is interested in checking for guide wear, and clearly want the stock components, which have failed time and again, on both stock and modified cars, out of their own cars, whether currently in or out of spec, depending upon their plans for modification or plans for use, or both.
Not "everyone" wants to run the stock heads, no matter whether or not they have guide wear.
And if they choose not to, then that is their prerogative and is independent of whether or not their guides are currently in spec.
A set of stock heads which just so happen to be in spec at the time they were checked, don't mean much to those seriously looking to prevent a dropped stock exhaust valve, like so many others before them.
If I'm planning on modding and/or racing my car, then there is no way I'm sticking with the stock parts. I don't give a damn whether they're in spec or not, seeing all of the stock failures in here.
Anybody else wanting to take that risk, is free to do so.
#552
#553
Chad, I only have 4500 (only been on a couple of months) on mine but will pass you like a dead snail down the road Oh, and 3 track days too
Ricky, post up the list so guys can check to see if they are accounted for
DH
DH
#554
#555
Yes, Howie, the list is on page 1 of the thread.
There are 202 forum members on it now, and that tells me that there are no doubt more that I have not accounted for in here.
Many of those on that listing, did this years ago.
It is important to note that, because it shows that this method isn't something which just sprang up overnight.
People have time, street mileage, track time and track mileage on these setups.
#556
Wow, you guys are running up the miles in those warm weather climates, while everyone else is freezing their asses off and driving when they can.
Wow, really nice job Ricky!!!
DH
#557
Lots of reasons why JwT.
#559
Go ahead and "encourage" on.
A lot of what you are saying, will still fall on deaf ears, and as evidenced by this very thread, there are plenty of people who either don't hear, or don't care what you are "encouraging" because they aren't interested in what you are advocating.[...]
Altho I did notice in another thread that the factory guides -- probably the root cause of the issue in some fashion -- once deemed crap (at least by association) by this group seem to have been given a pardon, and only the factory exhaust valve remains on the Most Wanted list, a salty desperado to be shot on sight
Anyhoo, I was just checking to see if it was still this solid stem group's position that brand new heads with zero wear should be overhauled with heavy aftermarket valves (as JwT's post tended to imply). I see that it is, and that Fear Factor is still running strong in the ratings (or is this actually a re-run? ). That is all
