[Z06] How Many Z06 Owners Are Running Solid Stainless Exhaust Valves?
#424
Thanks again guys, but I can't take the credit.
There were many before me, who made similar posts, and during a time when I was even denying that the problem was as big as it was.
But after awhile, it became obvious to anyone following this matter, that it was, indeed a problem. Updates attributed to GM themselves seem to me to indicated as much.
Those ahead of me on this matter, may or may not have been as vocal as myself, but they paved the way.
Like the rest of you.....I'm just glad that there even is a fix, or more accurately, a means of effective protection, against a $15K bill, for those of us out of warranty for one reason or another. Be that reason time, mileage, mods or tracking.
Think about it. This problem would be a whole lot worse, if there were no known method to mitigate it, and no known way for owners to protect themselves.
Yes, it is expensive. It takes some automotive skill to do. But it apparently works very well.
Finally, I'm thankful for this forum, and the vendors on our forum, and off, who can offer an effective manner for dealing with the valve issues of the LS7.
Thanks to it, and them, this issue will no longer have the "advantage" of consistently catching us off guard, and without having the information and opportunity to take steps to protect ourselves.
#426
ABS BLock leaking They have some service port on them and cannot be fixed only replaced. That part is not available today.
Found my PS pump leaking also. We are waiting for that and will replace it today.
CMS is doing an asskicking jog
DH
DH
#430
Any one check their geometry that is where the rocker strikes the valve stem.
The hole for the guides could be the issue, that maybe the missed machined that GM hasn't named. New guides will wear as well if this is the issue.
z51vett
z51vett
#431
new guides will indeed wear even on "perfect" heads, but having new bronze guides + solid stainless steel valves seems a bit more stout than the stock 2-piece hollow setup.
#432
ABS block. That's what I was afraid of.
#433
My witness marks were fine.
#434
Sharpie coloring applied
Rocker arm shown, no brown half moon "skid marks" indicating "bad juju".
My witness mark on my WCCH heads.
#438
Also, I added SS MPSTR as his car is at CMS now having his new WCCH heads installed.
Congrats SS MPSTR.
#440
