[Z06] Low oil pressure at idle
My '08 Z06 oil pressure at idle when fully warmed up is 13-19. I live in FL so outside temps are usually 90+ during summer. Level seems fine and no warning lights are on. Should I take it in to the dealer ? I believe normal range is 20-80 depending on conditions. Will they even care if there is no light on?
MC
MC
MC
MC
What oil are you using? 5w30 M1?
I'm using 5w40 Rotella T6 and I'm hitting 40 psi at 200deg oil temp. I believe you're still (technically) within spec so I don't know if GM would do anything, but it does sound low.
What's your high rpm pressure?
SoCal Events Coordinator
St. Jude Donor '12
My new 427 vert has low oil pressure at idle also and even at freeway speeds its only about 50 psi. seems low compared to my 09 Z06 427
HOT idle (210*) is 30 psi with Mobil1 0w40. Its been that way since new, motor has 13K on it now. I would assume and know from my first motor that will be lower with Mobil1 5w30. How much lower ?????
DH
DH
Cars very with heat and conditions. If its been like that for a little while it would have already been a problem. I would suggest a thicker oil for sure
MC
MC
I experienced similar low pressures when I first got my car in late 2005. The dealer said it was normal per the shop manual. Here is what your dealer will show you when you go in to have this checked. I thought these were shockingly low acceptable pressures and may be contributors to the valve dropping situation.
i know thats what they will show you, hopefully not. you can throw that in the garbage because if these cars have anything lower than 22-23 psi you can bet the future for that engine will not be good. ill even step it up a bit and say 25psi is even a bit low. i have a question did this car your talking about ever have a problem? im gonna say yes but i hope not. i havnt seen one of these live very long with low oil pressure, not one......sad
My 2011 Z06 idles at 28 psi when warm and I've seen it as low as 26 it has less than 4000 miles on it and the oil (mobile 1 5W 30) has less than 500 miles on it.
I run 60-70 psi at idle cold. 48-55 warm depending on outside temps. cruising speed (5th gear 65-70mph 2200rpm) I see avg 52 psi. 6th gear at 70mph I see 45-48psi. amsoil 10w40 high zddp.
