C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Procedure For Changing CLUTCH FLUID?
Old 09-07-2012, 01:38 AM
JonathanFla
JonathanFla's Avatar
Default Procedure For Changing CLUTCH FLUID?
How can i do this my self in my 2006 z06 ?
Turkey basterd to retract fluid lol ?
and whats the best brake fluid to use
also i herd i have to pump the clutch how is this done??
Old 09-07-2012, 01:52 AM
Prime Target
Prime Target's Avatar
Location: Murrells Inlet, SC (formally New Windsor, NY)
The Ranger method. Here's the link. All the info you need to keep your fluid like new...
http://forums.corvetteforum.com/c6-z...-and-cure.html
Old 09-07-2012, 01:58 AM
JDaniel
Senior Badass!
Support Corvetteforum!
JDaniel's Avatar
St. Jude Donor '08-'09
Old 09-07-2012, 10:14 AM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
I am now using Castrol SRF in my clutch fluid and it is holding up very nicely.
Old 09-07-2012, 12:07 PM
tim414
tim414's Avatar
St. Jude Donor '12
I buy the DOT 4 fluid from Wally World. I only change it now when it looks black/thick appearing. I have had zero issue doing this way.
Yes, turkey baster works. I use a 60cc syringe. Make sure you hold your finger over the tip of what ever your using to remove it. That fluid will play h3ll on your paint. I always use rag/towels and cover the fender to ensure this does not happen.
I always remove old fluid from the corner of reservoir. Don't know if it makes a difference or not, but I do not want the line to get air pocket.
Old 09-07-2012, 04:25 PM
dmuellenberg
dmuellenberg's Avatar
Really - you never heard the term 'pump the clutch' before? Push the clutch in, let it out, repeat several times.
Old 09-08-2012, 03:18 AM
JonathanFla
well yeah just didn't know if there was a sertant way to pump..?
just i be looking at fluid make sure no bubble. and how many time should i pump clutch.?
Old 09-08-2012, 03:39 AM
tim414
tim414's Avatar
St. Jude Donor '12
NONE, Just change the dam fluid and again later.
Old 09-08-2012, 05:19 PM
Mr. Gizmo
Mr. Gizmo's Avatar
A turkey basterd is the preferred method. I saw a turkey basterd used to inseminate a cow when we went on a junior high school field trip to a 4-H club event. This guy put a glove on that went up clear up to his shoulder then inserted that turkey bastard. Those turkey basterd's are versatile. Clutches to cows.
Old 09-08-2012, 11:37 PM
dmuellenberg
About 10-12 times should do it.
Old 09-09-2012, 12:01 AM
jnv255
jnv255's Avatar
Is use the dot 4 (prestone) from walmart. The Ranger method is how I do it. I use like a big *** ear dropper instead of a surenge. Suck out the fluid, wipe it out with a shop towel, wipe the rubber cap, poor new fluid back in, replace cap, and then I pump the clutch about 40 times.. I repeat the process until the fluid is clear after pumping the clutch. I check the color of my fluid all the time, almost everytime I fill the gas tank. I'm a bit OCD about it, but that's not a bad thing. I got my car used with very low miles, but whoever had it before me I guess never changed it, when I got it, it didn't like 7k rpm shifts, looked at the fluid and it was black.... (clutch dust.) changed it and no more problems. Went ahead and put a Centerforce DYAD clutch in it not to long after that too.. I full throttle shift at the track on bias plys, which is something the stock clutch doesn't like
To Procedure For Changing CLUTCH FLUID?
Quick Reply: [Z06] Procedure For Changing CLUTCH FLUID?
