[Z06] GM response to LS7 valve guide issue summary confirmed
#604
Hello all,
LS7 Valve guide issue summary:
• Affects a small, number of '08, 09 ’10 and ’11 Z06’s
• GM discovered the condition through our cylinder head warranty data involving a very small percentage of our vehicles.
• Through inspection of returned heads, it was determined that a machining error in the valve guide had occurred at our head supplier.
• The quality issue has been contained as of Feb 2011 with 100% inspection of all heads.
• The most common customer complaint has been excessive valve train noise.
However if the condition is not addressed, it could result in engine failure. To date, where this condition has been observed, it has occurred early in the vehicle life.
What customers need to know: They should drive and enjoy their vehicles without fear. If their car demonstrates this condition, they are likely to hear unusual valvetrain noise first. If you have a concern regarding this issue on your personal vehicle feel free to contact me through private message on this forum and we will work to assist in resolving your concern. Feel free to contact me through Socialmedia@gm.com please put attention Evan in the subject. As always, vehicles that have modifications to the powertrain or the calibrations, are no longer covered by GM's warranty.
Sincerely,
Evan, Chevrolet Customer Service
Sincerely,
#606
Hello all,
Sincerely,
Sincerely,
#607
Hello all,
Sincerely,
Sincerely,
#609
QC issue with the supplier. Just as I suspected.
#610
32k miles on my 09'.
It would be great if GM could give a better description other than a noisy valvetrain, as these motors seem to all have valve train noise. A "noisy valvetrain" is subjective, and depends on how good your hearing is.
#613
Hello all,
Sincerely,
Sincerely,
Is there any way to narrow down if you have a vehicle that could be affected other than listen to an already noisy valve train? That is quite a big time line.
If you have had your engine and or heads replaced recently is it safe to say that the problem is gone and even if you own a 2008-09-10? Have new long blocks been inspected or still an older batch that wasnt?
Are vehicles that are out of their current powertain warranty out of luck if the vehicle fails or will it be covered under some type of extended coverage? Your post admits fault and blame on GM's part for all those years. I cant see how GM could not accept a full warranty replacement in or out of warranty.
#618
Hello all,
Sincerely,
Sincerely,
#619
same questions as some others, what will GM do about warranty?
are there any specific production dates effected in regards to 2008?
As others have said LS7s seem to be noisy engines, how is one to know what is normal and what is not???????
