[Z06] Another dropped valve.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
There is a poster over on C6 general that just had a valve drop in his modified Z06, see here http://forums.corvetteforum.com/c6-c...hos-fault.html
I expect he will be here soon.
Because with all the bs it's not obvious that there is a real issue to a lot of folks, myself included. There is no rhyme or reason to the valve issue modified not modified high mileage not so much mileage. I had decided to just take my chances, that is until GM told me to have the valves addressed.
The LG response to that thread is fascinating and that response should be posted over here. First time I have seen or heard of a top level vendor talking about GM in connection with LS7 valves...
To contradict myself, it does become less obvious when you have top shops that use stock valves and guides on large cam applications without failure. I think you can attribute this to those shops studying their cams valve stress and by using top of the line valve springs. These shops are the minority though, I believe with most shops that will throw any cam in without doing head work, you're rolling the dice.
There is a reason so many cammed LS7's send their heads to WCCH. Sure adding heavier SS valves may not sound like the best idea, but for a lot of applications it's the safest bet. Even then you can't just beat on your big cammed car for 100,000 miles without changing your springs and checking for play with the valves. I think I will replace my springs every 10,000 miles.
So to clear up the fog, large cammed LS7 send your heads to WCCH, (there are other shops, but Richard does great work so I'll promote him )... unless you are doing your cam at a shop with a solid track record of their own cams with no headwork and no failures.
Stock under warranty, enjoy your car and stop reading these threads...
Stock outside of warranty... .
Nothings 100%, especially when modding, but this is about as safe as you can get.
Hi Guys,
We are the shop in question. It is unfortunate that the LS7 has developed exhaust valve problems in the last few years. GM still has not fixed the problem. Now that we know there is a problem, we recommend new exh valves with most high lift cam packages.
The kit, installed two years ago, did come with a valve spring kit and all the springs were still intact and in good condition.
We offered to discount the labor for sure. GM bears most of the responsibility because the Exh valve issue happens even on stock LS7 engines. The Stock valve is a 2 piece, Hollow Stem valve that seems to break. Even at that there is a less than 1% failure rate on these valves so it could even be a supplier problem.
Either way, it is unfortunate that this sort of thing happens. Especially when it happens in our shop. This is only the second failure like this on our dyno since 2006 Z06 production started.
Again, No one likes to be in this position. And LG Motorsports hates that it happened to anyone. That is why we are doing what we can to keep the car owner's cost down on this.
We are working on an assesment of the damage so we can arrive at a price that will not hurt the customer or LG Motorsports wether it is a crate engine or another option.
We always try to do the right thing. This time we are doing the right thing for a clear GM issue.
But our responsibility is to the customer, not GM.
Lou Gigliotti
LG Motorsports.
Lou Gigliotti
LG Motorsports.
At least certain members of this board cant quote LGs denial of the issue anymore...they will have to stick to Katechs response...but we all can read through the lines of Katechs response! well at least some of us can!
Hopefully someone comes up with a solution or theory before my warranty expires!
I don't know Katech isn't exactly saying there isn't an issue, they have my car right now and are doing the heads for me. I elected to do them as a direct result of art spong head of GM quality control telling us it needed to be done. Actually he looked at me like I had two heads when I told him it had 30k miles on it
Yes very interesting! well maybe just a bit interesting...cause seriously I cant believe anyone would be in denial of a head problem in this engine when we see weekly failures on such a small forum of owners.
If you read that post, Lou also stated that is the 2nd failure only of an LS7 in the 6 or 7 years they have been modding and racing them.
What the debate is over is just how wide-spread a problem it could be or not...and also, what is the root cause?
2 questions there are no real solid answers to. Again lets be clear about it.
This post (and the one in C6 Gen about it) are nothing new, motor with large cam fails by dropping a valve. nothing we don't already know.
Cam this motor, and you better do it right and go through everything.
LG never flat out denied there was an issue, what they (Anthony) did say was you can't expect to mod a motor, or cam it, especially with a large cam and not check or modify the rest of the components in the head (ie valves). He said basically the same thing about Mobil 1 5W30..people can't expect to run the factory oil at temps over 260 day in and day out..it was not set up for that.
Again, not saying SOME don't have an issue (clearly some do), but look at this particular shops experience as one piece of data. I think most out of warranty will find it worth it to drop the ~$3000 for a full WCCH job with new bronze guides, new OEM exhaust valves and katech ti/mo intake valves (or ~$2400ish if you take out the port/polish/milling) rather than wondering if you are in this small batch with issues.
If only those with cashed motors could provide anything along the lines of actual specs on guides, springs condition, surviving valves condition, rocker conditions etc., then we would know much more.
im a hot rodder at heart, through and through. i bought my 08 zo6 because of what it is. if a want something faster ill get a zr1 or build a race car. i see many guys modding these cars and i know for a fact they cant drive the car to its full potential in its stock form anyway.....then they mod, blow it up and cry cry cry.......waaaaa waaaaa. then they get towed into my Chevrolet dealership.....and i offer a tissue...
The thing that gets me mad is shops who tell you that you don't need to have your heads done even when they are installing a big cam that isn't there own.
Maybe things have changed but last year I talked to four shops about having a large cam installed. Three of the four mentioned nothing about upgrading heads, (with the exception of new springs). One of the shops even tried to talk me out of it . The fourth shop said they wont do a cam on an LS7 without sending the heads to WCCH.
I just really think this issue should be brought up to potential customers before they stick an aftermarket cam in an LS7. Yes the customer should do their research, (and it's hard to miss all the LS7 valve talk online), but I still wonder about some of these shops... And I cringe when I see somebody at a car show with a cam installed by one of those three shops without any head work done. When I ask about it they tell me the shop never mentioned it.
Read more: http://www.hotrod.com/techarticles/e...#ixzz23T9mGAYL
