C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6 Emblem Z06 Center Console
Old 08-11-2012, 01:07 AM
Paul 68
Paul 68's Avatar
Default C6 Emblem Z06 Center Console
Bought a C6 Rear Bumper Emblem, broke the tab off the back and stuck it to back part of the center console. Kind like the waterfall emblem on the C6 Convertible. They should do this from the factory.
Old 08-11-2012, 10:41 PM
dp201
dp201's Avatar
Good idea. What type of adhesive did you use to attach it?
Old 08-12-2012, 12:06 PM
Prime Target
Prime Target's Avatar
Location: Murrells Inlet, SC (formally New Windsor, NY)
looks good!
Old 08-13-2012, 06:22 PM
Paul 68
Paul 68's Avatar
It's the rear OEM C6 flags, comes with adhesive tape mount, just need to break off the plastic tabs. But like someone posted in the C6 section, that it better to get the flags that mount on the front nose, since it slopes same as rear of the console. The rear C6 flags I used, I didn't realize till after that the tip at the bottom of the flags, slightly bend up to go with the contour of the rear bumper. Not sure if I am going to change it, or just leave it.
Old 08-13-2012, 06:23 PM
Paul 68
Paul 68's Avatar
Originally Posted by Prime Target
looks good!
To C6 Emblem Z06 Center Console
Quick Reply: [Z06] C6 Emblem Z06 Center Console
