[Z06] Oil tank rivet nut size?
Hey all, don't ask why... I need to replace the oil reservoir nut that's rivet-ed into the frame. It secures the lower oil reservoir tank strap bolts (M10 I think) to the aluminum frame. I went to the dealer and they don't list a separate part number for it. Does any one know what size it is? Where's a good place to get a couple if these and its setting tool?
Thanks.
Thanks.
Not familiar with the way the oil tank's mounted, as never had to mess with it. Do know what a Riv-Nut tool is though, as own one. Mines fitted for SAE though, and surely your application is Metric. Maybe check with outfits like Katech, or LG Motrosports, as work with oil tanks quite often.
