[Z06] Exhaust replacement
Exhaust replacement
Tomorrow I plan to replace the exhaust on my ZO6.
my question is..What do I have to remove to take off the axle back part of the system? Do I have to drop the rearend or will the exhaust come out over the top of the rearend?
Im going to replace the exhaust with a Full LG system from front to back.
Thanks E....
Thanks E....
St. Jude Donor '12
drop rear sway and they will come out with the right twist and angles. it helps to have a second pair of hands to make sure you don't catch a few wires. I pulled mine with no problems on my lift.
I have mine on jackstands.. Thanks Again Ellis
Did my headers and Fusions on jackstands. No problem.
wd 40 all the bolts before you remove them. Getting the stock manifolds out kicked my ***.
BB fusions: right OEM axle back would not remove for me on jack stands. No way no how could I make it happen. So-out came the sawsall. Jack stands suck, but you work with what you have.
Thank you for the help on this. I have droped the swaybar today. I will not be able to get back on it for a few days. I'll let you know how it goes when Im finished..
Thanks Again Ellis
Thanks Again Ellis
I had a shop install my Akras and even on a lift it was a major wrestling match to get the stock axle back out on the right side. I had cautioned them about damaging wires, so they were being very careful but I still couldn't believe how much they struggled to get it done. Patience and an extra pair of hands are recommended.
