Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-27-2012, 06:16 AM   #1
walhan_qtr
CF Senior Member
Support Corvetteforum!
walhan_qtr's Avatar
WalhaN walhan_qtr
Send a message via MSN to walhan_qtr Send a message via Skype™ to walhan_qtr
Default New PB: 441ci C6 Z06 N/A 9000+DA!!
just thought I will share this vid of my new PB. Still didnt break into the 10s just yet.... I was close.
My best et was 11.02@128.9 with a sh!tty 1.82 60ft.
~9000DA
From DragTimes.com my corrected numbers are:
Stock and Mildly Modified Naturally Aspirated Engines
9.765 @ 144.706 MPH
Extensively Modified Naturally Aspirated Engines
10.016 @ 140.902 MPH
not sure how accurate that is....
still figuring things out. managed to pull a 1.74 60ft and a 1.76 but the 1.82 was my best et/trap even though it was actually in a higher DA. the reason is my 1.74 and 1.76 car was knocking and I was at 14-15deg of timing all the way through the whole run. my 1.82 it was a little better at 16-17deg. I think it was mostly due to the heat (it was in the high 80s, low 90s) we adjusted the tune now and its at 19-20deg of timing so It should help a little bit.
clutch feels great. no issues at all. Thanks to Gary for the tip on the cool down between each run. clutch was less grabby which was better. still figuring out tire pressure and launch RPM. only had about four runs that day with 3 11.0 runs. best 60ft to date was a 1.72. best trap was 128.96, and best et is 11.02....
I think I am very close from getting my 10sec slip. I am starting to get better and better with my launch, but it still sucks. I also need to work on my shifting. ever since I broke my first transmission I started to doubt myself and cant shift as fast as I used to. but thats not a big deal from what I have been told and doesn't affect et that much (unless you are really slow lol)
the car def has a 10.8 if not even better... hopefully will be able to get it next week.....
DA is a lot higher from when I get my 11.1 run (6800DA compared to 9000) wish I had the car tuned that day I would have probably gotten my 10sec without a problem oh well......
I will start spraying after I get my 10sec slip which I hope will be very SooN
Quick Info:
441ci H/C/I C6 Z06
bolt-ons
RPS BC3 clutch
Stock Suspension/ Stock Trans/Diff
only weight reduction is no passenger seat, but with my roll-bar it was basically like a stock Z06.
3265lbs
sh!tty driver
Edit: the inside vid is for my worst run that day but its the only good inside vid I have. I had a guy asking me how it bogged in the run while it looked like it span on the other vid... so thats why.
also car is only making 490whp uncorrected, its probably even less in those runs.
__________________
- 07 Silver Z06
441ci, Darton Sleeved LS7, GM DR H/I, Nitrous Outlet, Mantic, E85. (615whp/582wtq) (10.9@127 N/A)
- 09 Blk Z06
427ci LSX, DP F2, Brodix BR7, Holley, ZR1 TR6060, McLeod, Pfadt. (1204whp SAE @ 26psi)
- '14 Red Z51 C7,
H/C pkg, Ported Intake/TB, ARH 1 7/8, Nitrous Outlet Plate Kit. (589whp/629wtq)
SOLD
- 97 1030whp Blk Supra
- 06 427ci F1X Blk C6
- '10 H/C/I Blk Camaro
- 07 Bolt ons Blk C6
- 98 Bolt ons White C5
walhan_qtr is offline   Reply With Quote
Old 06-27-2012, 09:05 AM   #2
ZO6er
CF Senior Member
ZO6er's Avatar
congrats
ZO6er is offline   Reply With Quote
Old 06-27-2012, 09:15 AM   #3
6Speeder
CF Senior Member
6Speeder's Avatar
Good job. High DA is a beetch. You'll get your 10.
__________________
Porsches for breakfast
Ferraris for lunch
6Speeder is offline   Reply With Quote
Old 06-27-2012, 09:59 AM   #4
LS9Drew
CF Senior Member
nice man!
LS9Drew is offline   Reply With Quote
Old 06-27-2012, 10:23 AM   #5
FSTFRC
CF Senior Member
FSTFRC's Avatar
Good driving and great times considering the altitude! Congratulations... I'd like to see what your car would run at one our of local tracks!
FSTFRC is online now   Reply With Quote
Old 06-27-2012, 10:36 AM   #6
Sébast19X
CF Senior Member
Sébast19X's Avatar
Congrats !!! Nice run !!!
Impressive with this ****** DA !!!!
Seb
__________________
'08 Z06 Black & Ebony 2LZ & Cup wheels
GOING for N/A: 9.7x with my Iceman Cam, manual transmission, & passenger seat in
GOING for Nitrous: 150+mp/h
Best N/A E.T : 9.921
Best N/A mp/h : 140.2
Best 60' : 1.450 still in progress
Sébast19X is offline   Reply With Quote
Old 06-27-2012, 11:04 AM   #7
06LMBZ
CF Senior Member
06LMBZ's Avatar
Awesome runs
06LMBZ is offline   Reply With Quote
Old 06-27-2012, 11:34 AM   #8
StreetRacingGuy
CF Senior Member
StreetRacingGuy's Avatar
I would think that you should use the extensively modified index in your case (bigger cubes, heads, intake, exhaust, CAI, etc etc etc).
10.015 @ 140.836 MPH
STILL...nearly a 9 at sealevel at great mph (140 is hauling the mail)!
if you could get a 10.8 at similar mph, that would translate to about a 9.80 at sealevel which is on par with the fastest NA Z06 cars around!
StreetRacingGuy is offline   Reply With Quote
Old 06-27-2012, 01:29 PM   #9
meatheadgn
CF Senior Member
meatheadgn's Avatar
Great runs and great video. I raced the LS6 Cobra last Wednesday with UNREAL's Mustang and our DA was about 6800.....9000 ft. really, really sucks.
You should have a 10 sec. slip in no time. The pain of running at high altitude tracks is tough.
I look forward to seeing how it runs with a little shot of sprayed automotive adrenalin.
meatheadgn is offline   Reply With Quote
Old 06-27-2012, 02:05 PM   #10
SilveradoSS500
CF Senior Member
SilveradoSS500's Avatar
your shifts are fast for sure but practice wrist shifting
SilveradoSS500 is offline   Reply With Quote
Old 06-27-2012, 02:30 PM   #11
pit-man
CF Senior Member
pit-man's Avatar
Great run man Play with the tire pressure & clutch release/throttle to get rid of that little bog. The resulting lower sixty foot will give you 3-5 tenths better ET.
Love the inside camera..hitting the gears really good.
pit-man is online now   Reply With Quote
Old 06-27-2012, 03:31 PM   #12
walhan_qtr
CF Senior Member
walhan_qtr's Avatar
WalhaN walhan_qtr
Thanks everyone....
Quote:
I would love to to run at some of the nice tracks with better air and lower DA. I am seriously thinking about it, but I would like to find a track that is a lot closer than Texas. not sure yet, but will probably be looking for one and probably plan on going next week... we will see
Seb
I dont know about impressive. but I guess its not too bad. I know I can do better especially knowing that I ran 2 1.7X 60ft in that same day....
Old 06-27-2012, 03:36 PM   #13
walhan_qtr
CF Senior Member
walhan_qtr's Avatar
WalhaN walhan_qtr
oh yea I am def in the Extensive modified N/A engines lol I just copied the whole thing. I really dont know how the correction works. I would think at sea-level things will be a lot different. but I might be wrong. only way to find out is to go and try it I guess
here you only see high 6000 DA in April and October. the rest of the months it will always be between 7500-10000
I told myself I will not start spraying until I get my 10sec slip N/A.... hopefully it will be soon though... I cant wait any longer to see how it will run on some juice
Old 06-27-2012, 03:44 PM   #14
walhan_qtr
CF Senior Member
walhan_qtr's Avatar
WalhaN walhan_qtr
Quote:
I think I will just stick with this... I tried changing the way I shift and it only made it worse. I know this is not the right way and I tried to follow Rangers method, but again only made it worse......
I am tring but the problem is every day its different. I wish there will be a privet event where I can practice better and record and observe everything. this was just a test and tune and only managed to do about 4 runs (maybe 5 I will have to check) and the next week the car acts different (I think due to the different weather and track prep) and I gotta start all over again.
I am sure if it was someone with more experience he will probably need a run or 2 to figure it out. with me its just kinda luck LOL. I really dont have a lot of experience, and it takes me longer to figure things out especially tire pressure, clutch release and all that... even the burnout!! it seems like the burnout changes everything too. if I do a 2-3 sec burnout it will hook different than doing say 4-5sec burnout. so I need to try and be consistent this is really just not for me. I will keep trying but I know I wont be setting any records or anything LOL
one thing I am still fighting is not flooring it asa I let the clutch out. no matter what, I just floor it right away. I know Ranger and some of the fast guys say its wrong but I just cant do it. my instinct says FLOOR IT FLOOR IT lol so yes I still have a lot to deal with... all this is making me
Old 06-27-2012, 05:24 PM   #15
robz
CF Senior Member
robz's Avatar
Thought the driving looked good just need more seat time on the launch. Don't change shifting, work on the 60'.I have a house in conifer but never raced out there. At least you can enjoy 'gods country' after a day at the drag strip.
Rangers methods are for stock clutch and stock powered cars.
robz is offline   Reply With Quote
Old 06-27-2012, 05:29 PM   #16
robz
CF Senior Member
robz's Avatar
Keep the burnouts short.
Pump the clutch as you go up to the line.
One pass every 25 minutes.
You are dumping clutch too much . Try and ride out a little more and get on the gas a bit sooner. Your car bogged down badly.That will get you in the 1.6x's.
What is your tire pressure?
Old 06-27-2012, 05:38 PM   #17
robz
CF Senior Member
robz's Avatar
As you figure things out more you need to come up with a standard launch technique that you start with every time. Then on the following passes you can adjust for track conditions, weather, etc. You need to time your burnouts and extend time time between runs. If you keep everything consistent then you will only have to make small changes to account for different days.
You're on the right track.
Old 06-28-2012, 12:15 AM   #18
Sébast19X
CF Senior Member
Sébast19X's Avatar
Quote:
Originally Posted by walhan_qtr View Post
Thanks everyone....
I would tell impressive for that kind of DA. You gain 28 mp/h in 3.817 sec from 660' to 1320'. At +10 000 DA this kind of gain are impressive !!! IMHO.
__________________
Old 06-28-2012, 12:15 AM   #19
Sébast19X
CF Senior Member
Sébast19X's Avatar
9.x sec car for sure at sea level .
__________________
Old 06-28-2012, 01:02 AM   #20
tail_lights
CF Senior Member
tail_lights's Avatar
Great runs man!!!!! That DA is nassssty!!!! Keep up the good work, that 10 is right around the corner! And no, my buddy still doesn't have his Maxima back yet........
tail_lights is online now   Reply With Quote
Reload this Page New PB: 441ci C6 Z06 N/A 9000+DA!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
