[Z06] H/C seat of the pants difference
#42
I can see both sides of the dilemna as UNREAL has the supercharged car and I have a H/C/I/Tune/Headers car. I have the Lethal cam in mine which is easy to drive and does not present any difficulty in driving around. I keep the NT05R's on car all the time. It made about 580rwhp corrected as we are at about 4500 ft.
When UNREAL had the Mamba cam in his car it was the best sounding cammed up car that I had heard. It made me wish I had not put the smaller cam in mine. UNREAL made about 10 more hp with that cam than I did comparing car to car.
IMO a H/C/I car will never match the power of a "properly set up" blown car without a shot of nitrous and perhaps not even then.
I do however love the sound of a cammed up car so that is what I went with.
UNREAL made the choice that he did as he did not want to live with a lopey cammed up car everyday so he went the supercharger route and with his mods should be making a ton of power.
Different strokes......all are good options.
#43
That is a completely different topic which can be argued considerably! On a 90* at the track, both cars line up at the tree, the nitrous car will linger back, let that supercharger car soak up that heavy air build up those IAT's (assuming air to air intercooler), tough call. My little LS1 forged 346ci motor went 9.30's @ 146mph in my 3400lb camaro back in 2003!
#44
I just dont see my car hooking at all if it makes over 600 rwhp. Even if its on DR. If it does im sure ill be having to call a tow truck because of something breaking. Man what a tough decision! The only reason i have considered a blower is its easier to remove come time to sell the car and the better driveability. The h/c sound alone is making me want to go that route.
#45
#47
MeatheadGN and I will line up once my car is running for a trip to Mexico. HC/N2O vs HC/Blower should be fun.
In the end that is what it is all about, having fun. All the options are great. Heads/cam, cam only, n2o only, blower. Heads/cam blower. There isn't a bad combo.
#48
You will still be making enough power with a lot of cam only setups to fry your stock clutch. I would personally not recommend anyone do a cam setup without taking care of your heads too, esp with a larger cam, I would say definitely do your heads too. I know there are a lot of cam only cars running just fine, maybe they just have better luck than others. It was worth the extra money for me to do my heads just for the piece of mind, not just the HP. Although I'm not sure H/C setups are as reliable as people originally thought.
#49
What do you mean by taking care of heads too?
Adding a cam doesn't require a head job or are you talking about springs?
Yup. I drive mine pretty hard, just not dumping the clutch from a stop. I don't expect my clutch to last longer. As long as you have street tires it should hold out for a while, who knows how long for sure though.
#50
Heads too...
Doing a valve job, bronze valve guides, and some switch the exhaust valves to heavy duty solid 1 piece stainless steel. But the valve is much heavier which isn't optimum for the high revving LS7.
I would upgrade the valve guides, valve job and mill for more compression.
#51
I mean what Clark says below:
Heads too...
I chose SS, I know Katech recommends lighter valves and obviously they know their stuff, I just decided to go with what my builder and WCCH preferred.
