C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 low dust brake pads
Old 05-14-2012, 09:07 AM
dcsteg
dcsteg's Avatar
Default Z06 low dust brake pads
Who makes/sells the best low dust replacement brake pads for the Z06?
I have a 2011. Not sure if there is any difference between the years.
Old 05-14-2012, 10:05 AM
EdsC6Z06
EdsC6Z06's Avatar
St. Jude Donor '05-'06-'08-'10
Ceramic pads create less dust, but generally don't stop as well either. I think several companies make ceramic replacements.
I hate the brake dust but I track my car occasionally and don't want to lose any braking power.
Old 05-14-2012, 10:29 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Carbotech 1521 compound is the (BEST) This pad will prefrom like stock on the street and cut your dust at least in half of the stock pad. I recomend going with the 1 piece design. You can order direct from me at 216-780-8825. There is no diffrence in years 06-13
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
F $290 R $246 Less forum pricing.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 05-14-2012, 02:55 PM
Vette5.5
Vette5.5's Avatar
Good thing you didn't try ceramics for road track days, as know some who've tried it, and wasn't pretty. Almost made it one lap before all braking went out, then spent the next day pulling everything apart, sanding off all the glaze. To the original question. Adam of Carbotech chimed in, and can surely fix you up.
Old 05-14-2012, 03:07 PM
Mookster
Mookster's Avatar
The less dust the less performance..dustless pads just dont bite well
Old 05-15-2012, 06:08 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
I've got 50K miles on my "street" posi-quiets. They're rotor friendly and ideal for street only.
The best thing.... you avoid the "Corvette tax" at $129 for all 4 corners!
Old 05-15-2012, 06:51 AM
dcsteg
dcsteg's Avatar
OK..I forgot to mention...I don't track the car so loosing the stopping power of the stock GM pads is not a concern if I replace them.
I just want some good street friendly low dust pads.
Thanks so far to those who replied.
Old 05-15-2012, 12:21 PM
mewalker2
mewalker2's Avatar
There are a few threads on this already, with many different opinions on pads. I recently swapped out my stock padlets for a set of Posi Quiets also, and have been VERY pleased with the low dust and no more low speed squeal. Just remember, no track days with them, they are for STREET USE ONLY!
Old 05-15-2012, 01:00 PM
Maligator
Maligator's Avatar
so the posi quiets are not a ceramic pad, still metallic, but have a lower dust property?????
Old 05-15-2012, 01:22 PM
sam90lx
sam90lx's Avatar
They have both, you want Ceramics. Mine will be in Friday, cant wait!
Cheap enough for sure and good reviews but as others have said...not for the track.
Old 05-18-2012, 05:40 PM
sam90lx
sam90lx's Avatar
My Centric Posi's are on and though it is too soon to comment on the dust, the braking is just fine! Will update on the dust next week but anything has to be better that the oem's plus damn cheap to boot. These are the Ceramic's by the way.
Old 05-18-2012, 11:27 PM
dmuellenberg
dmuellenberg's Avatar
I went with the semi metallic Posi Quiets last summer and have been happy with them. They still have brake dust, but not nearly as much as the oem pads.
Old 05-19-2012, 08:40 AM
Undy
Undy's Avatar
After the Hawk ceramic pads destroyed my rotors in 25K miles I went with the semi-metalic posi quiets. After 50K miles my rotors are still in great shape. NO MORE CERAMICS FOR ME. The next set of posi quiets (if available) will be semi metallic again. The semi metalics dusted less than the Hawks I had too.
Old 05-19-2012, 10:40 AM
zx1421
zx1421's Avatar
Why one piece pads? I would think a ton of engineering when into the pad-letts. What do you think the advantage is to a single?
Old 05-19-2012, 11:51 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
More pad material making contact with the rotor would be the first thing that comes to mind.
Old 05-20-2012, 01:28 AM
triblk6spd
triblk6spd's Avatar
I run the straight up Hawk Ceramic pads. VERY little dust and very little initial brake bite. I can live with that!
Old 05-20-2012, 02:36 AM
LS9Drew
LS9Drew's Avatar
Anyone use Hawk HPS Pads or Stoptech Street Performance? Hows the brake dust and stopping power on both?
To Z06 low dust brake pads
Old 05-20-2012, 08:17 AM
Jimmyz28
Jimmyz28's Avatar
I put the Hawk Ceramics Padlets on mine over a month ago. Much less (85%+) dust than the stockers, just not dustless like the Akebono pads on my Z51. Stops extremely well on the street. Everyone knows that ceramics are not for the track so I don't get all that commentary.
This was my choice: Hawk HPS Ceramic Padlets
Old 05-20-2012, 10:31 AM
Prime Target
Prime Target's Avatar
Location: Murrells Inlet, SC (formally New Windsor, NY)
Spray your wheels with Armor All wheel protectant. No brake dust at all. Hell of alot easier than changing the pads out if all your looking for is to eliminate dust on the wheels. I've been using the stuff since it came out and it works great.
Old 05-20-2012, 11:05 AM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
I will have a great option by Monday. We're offering Centric C6Z front and rear ceramic pads for $150 delivered to your door and these are VERY low dust.
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Quick Reply: [Z06] Z06 low dust brake pads
