C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Busted internal OEM exhaust can!!
Old 04-23-2012, 12:20 AM
LeftLane Z06
LeftLane Z06's Avatar
Default Busted internal OEM exhaust can!!
Well had time today to jack the Z up to find out where this annoying vibration was coming from.It's been confirmed, it's the passenger side exhaust can that has the annoying vibration coming from it.
My Z is a 09, bone stock with a mild to wild and 10k on the clock. Saw a thread, where a member had the same problem and cut the exhaust can open and it looked like a bomb went off inside.
Old 04-23-2012, 12:38 AM
valet_devil
valet_devil's Avatar
Sounds like it's time to do the exhaust mod. A reputable shop will not only make your Z sound meaner but should reinforce the weakpoints in there. Check out this video: http://www.youtube.com/watch?v=eQDewJL4knI
Should run you a little over $200 for the labor.
Old 04-23-2012, 10:28 AM
z51vett
z51vett's Avatar
Is your 36 month warranty still in effect. If so let chev fix it.
z51vett
Old 04-23-2012, 10:56 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Just get some Fusions and leave the old cans in the attic for the future owner of your car.
To Busted internal OEM exhaust can!!
Quick Reply: [Z06] Busted internal OEM exhaust can!!
