C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Johnny O'Connell Stage 1 Signature Series Suspension Kits C6 Z06
Old 04-19-2012, 11:15 AM
CCA Corvette Parts
Premium Supporting Vendor
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
Default Johnny O'Connell Stage 1 Signature Series Suspension Kits C6 Z06
Johnny O'Connell
Stage 1
Looking for the most bang for the buck in your Corvette Suspension
Upgrade, then look no further than the the Johnny O'Connell Stage 1
Suspension Kit.
This kit comes with everything you need to Upgrade your Corvettes
Suspension to track level performance, while still keeping the drivablilty
of a street car. Upgrading these components will give your Corvette
a better balanced, better performing and more easily managed
suspension on the street as well as the track.
Each Kit Includes:
- (4) Tuned Johnny O'Connell Shocks
- (F/R) Johnny O'Connell Sway Bars
- Upgraded Sway Bar End Links
- (4) Sway Bar Bushings
Get your Stage 1 Package
with
CCA
Johnny O'Connell Stage 1 Corvette Suspension Package
Regards
Chip
__________________
..................Click for
Old 04-19-2012, 10:12 PM
scamilleri1228
scamilleri1228's Avatar
Default Let me know how much$
Will this make any differenc in my steering? My brother has a lotus and I'm hoping to make my z feel closer to the road. I know it may Bamako things a little stiffer but I want make the car feel more like that lotus
Old 04-20-2012, 01:21 PM
SmokeyD
SmokeyD's Avatar
I took Pfadt coil overs off and im finishing up this weekend with JOC set up.
Old 04-20-2012, 02:29 PM
CCA Corvette Parts
It will flatten out the body roll and make the turn-in alot sharper
Peace
Chip
Old 04-21-2012, 12:48 PM
CCA Corvette Parts
All PM's replied
Order confirmations Monday AM
Peace
Chip
Old 04-21-2012, 01:19 PM
1QUICKSSB
1QUICKSSB's Avatar
The JOC Kit made my Z feel so much more stable on turn in, and on the highway. The car is just a little stiffer, but worth the more controlled feeling that you get in return.
Old 04-21-2012, 05:47 PM
CCA Corvette Parts
Tks for the post
Peace
Chip
Old 05-02-2012, 02:43 PM
RWspinning
RWspinning's Avatar
What kind of shocks does Pfadt use in this package? do they manufacture their own or are they bilsteins/ koni's?
Old 05-02-2012, 05:20 PM
Pfadt Racing
Pfadt Racing's Avatar
With this particular Johnny O'Connell shock we teamed up with the OEM shock supplier ZF Sachs for the construction. They are built to our quality control and damping specification, but on the outside look extremely similar to the factory shocks... but really the magic is on the inside. You can expect the same excellent shock life expectancy out of our JO shocks as you would the OEM shocks, but they're going to certainly perform better.
Our coilover products on the other hand are build in house by our engineering staff in Salt Lake City.
Old 05-02-2012, 06:03 PM
CCA Corvette Parts
Tks for the post guys
Peace
Chip
Old 05-06-2012, 06:21 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
Are the coilovers shocks made out of aluminum or stainless steel? To my knowledge, SS is much more durable. Specially if the roads are bad.
Thank you very much.
Old 05-07-2012, 04:02 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
bump
Old 05-07-2012, 04:24 PM
CCA Corvette Parts
bump
Tracking down the answer for yuou now
Peace
Chip
Old 05-07-2012, 06:36 PM
Pfadt Racing
It really depends which specific piece of the coilover we're talking about, we pick the appropriate material for the appropriate application, but really focused on optimizing our design with lightweight components where ever possible. We use a high strength aluminum alloy for the bodies and spring perches because of it's excellent combination of strength and low weight. All Non aluminum components are treated with an appropriate corrosion eliminating process, such as chroming, heat treating, or the use of stainless steel. The parts that need to be strong are more than tough enough to provide excellent service life.
If you have any specific questions about our coilover products please shoot me a PM and we can make sure to get your questions taken care of!
Old 05-07-2012, 11:31 PM
1000yardman
1000yardman's Avatar
I just made a trip 1200 miles from Las Vegas to Whitefish Montana with newly installed Jonnie O package.My Z,brand new Lingenfelter built 449ci.RHS block,All Pro heads making 627RWHP 620RWTQ.Went through several mountain passes and I could not be more impressed!! With only a very very slight difference in stiffness,the turn in,the body roll,and most importantly the planted feel of the rear,has been vastly improved!The harder the cornering the flatter it responded.Some of these road conditions were not good,poor patch work,and winter torn,which prior would have had me far less confident at speed.Can not wait to try it on our newly paved road course and comp tires!Biggest most noticeable bang for the buck I've spent in a long time!
Old 05-08-2012, 06:12 AM
ChevyCobb
ChevyCobb's Avatar
Do these shocks change the ride height at all?
Old 05-08-2012, 08:30 AM
CCA Corvette Parts
Tks for the post
Sounds like a killer trip
Peace
Chip
To Johnny O'Connell Stage 1 Signature Series Suspension Kits C6 Z06
CCA Corvette Parts
No
Peace
Chip
Old 05-08-2012, 09:29 AM
1000yardman
some grueling no mans land spots but some killer canyons and I only got pulled over once LOL no ticket written,could not help demoing this motor and suspension in spots OMG POWER EVERYWHERE
Old 05-09-2012, 11:59 AM
CCA Corvette Parts
I only got pulled over once...
Peace
Chip
Quick Reply: [Z06] Johnny O'Connell Stage 1 Signature Series Suspension Kits C6 Z06
