[Z06] 2-pop rivets and wcch saved my engine
A BIG THANK YOU TO RICHARD AT WCCH !! while installing my ls-7 heads from WCCH that looked so awesome .. Wonderful Job Richard!! I noticed 2 of the air bleed holes were riveted closed and my vent crossover tube wouldn't hook up. So I called WCCH thinking for some perf. reason they did this. As always Richard answers his calls talks to me like a friend and is full of info.. Still helps out AFTER the sell, returns calls and don't do business only from e-mails like others I know. He explained that GM rivets these closed and don't need the rear block offs with o-rings like ls-3's. While shooting the bull he mentions a guy that destroyed his $150.00 EA. titanium intake valves in 50 miles, eat down to the retainer locks. LASH CAPS NOT INSTALLED.. WHOOO!! never saw these on my heads. went and pulled the cover and intake rocker NO LASH CAPS!! And Richard waited for my return call and was so happy we discussed this. Stated if he gets caps they are returned in a labeled bag. Bought heads used and rockers and caps were kept by seller and under assumption thought heads were ready to go after all the cash I spent.. WRONG!!! I was going to fire up this weekend and this is a Fresh R.E.D. sleeved Forged Katech short block assy and THANKS to Jason (Katech) another good vendor that you can depend on. Paid a little more but good dependable people and service after the sell is worth it to me. Words of wisdom, if to busy to talk or return calls deal with those that will.. Thanks Again Richard At WCCH and to all the honest helpful vendors and members on this forum that help soooo much! Very Appreciated and hope this is useful for someone else!!!!!
WCCH needs to have a note on every LS7 head or any heads that uses TI valves to remind people about those lash caps. Not sure why after all those problems with other people that they are still not doing it. I destroyed my LS7 due to not having those lash caps installed. and I have seen 3 others with the same problem.
so you are saying that valves that require lash caps do not come with them, nor the note of their being required.
-superlame
I've had my share of lsx, non-ls7's and have not once needed or used a lash cap, It would have definitely bitten me.
-superlame
Don't y'all think that if YOU took the heads off YOU should remember to put the lash caps back in the right location and the heads on the correct side relative to the water transfer tube?
It's not the machine shops faults if y'all forgot how it came apart. You want the machine shop to send you a how-to manual as well ? I guess there's more to wrenchin' than just turning a wrench....
a little note would have saved that shop few thousands dollars since they paid to fix my engine.
no one asked for full instructions. just a little tiny note saying check lash caps!! thats all. full instructions would be nice though :P
