C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Corvette Z06 Drift
Old 04-02-2012, 10:17 AM
Corvettegermany
2nd Gear
Corvettegermany's Avatar
Default Corvette Z06 Drift
Hi Guys,
I have a question, I want to start some drifting in my stock Corvette Z06.
I have heard that I should not be a good car ford drift, but why isn't it good for drifting ?
And what tires would you use ?
The regular 18" in front and 19" in the back ? Ore also 18" in the back ? And which size ? 245/40?
Thank you very much for you kind reply and help.
Best regards,
Christian
Old 04-02-2012, 11:49 AM
LanceFitzgiben
LanceFitzgiben's Avatar
really half-*** response here but the guys out here that drift one have some sort of knuckle mod so that they can get more lock out of the steering. Otherwise the car has more tendency to rotate around. Then again, Tiff Needel didn't seem to have any troubles drifting a stock one in his review.
For tires I would certainly not stay with 19's in the rear, as they will break the bank in a hurry. I'd also run something narrower than the 325's, something closer to a square setup.
That's the best I can respond with my very limited knowledge. There's a lot more to drifting than meets the eye. Most all of it is driver.
Old 04-02-2012, 12:31 PM
0Bobby @ LG Motorsports
Former Vendor
Bobby @ LG Motorsports's Avatar
Who said they don't make good drift cars?
Old 04-02-2012, 01:28 PM
Uncle Meat
Uncle Meat's Avatar
When someone talks about drifting a Corvette I always think of this video...
U.M.
(*WARNING* Some colorful language at the end of the vid)
Old 04-02-2012, 01:45 PM
Former Vendor
U.M.
Darius ftw!
Old 04-02-2012, 01:59 PM
160KTS
160KTS's Avatar
You certainly can drift it, but it's not the easiest thing to fully control sideways.
Old 04-02-2012, 02:40 PM
HeyDanNiceShot
HeyDanNiceShot's Avatar
I'm pretty sure the Z06 is the ultimate "steer with the rear" car. HOWEVER, being a carbon/aluminum frame, getting it wrong is going to mean getting a new car.
Old 04-02-2012, 03:40 PM
EyeMaster
EyeMaster's Avatar
I find the turning radius (wheel lock) to be a limitation for drifting with the Vette.
To Corvette Z06 Drift
Quick Reply: [Z06] Corvette Z06 Drift
