[Z06] Tire discussion Runflat vs non-runflat
Michaelinmech ,before attempting to set skid pad records you should get an oil change or at least add whats missing !Hard cornering when missing oil is not very recommended.Secondly i hope you dont think we re naive enough to believe 1.27 g force with good year runflats....What a joke.
Michaelinmech is not the person attempting to set skid pad records. Please reread and forward your comments to the one claiming 1.27 g skid results with GY Runflats on the street.
Actually if the curve has enough banking, the pavement and tires are hot enough and you are carrying enough speed, the G's onr can achieve is amazing. With GY run craps it would be possible IF all the conditions are met.
I remember when the C5 Z06 came out and they got 1.05g, and it was a huge deal back then. Anything about 1g was reserved for super cars and race cars only.
Now look at what they are doing. 1.1g, 1.27g. And there are a lot of cars approaching 1g now.
We live in a great time of advanced technology. Even with super sticky rubber, anything past 1.5g is almost unobtainable, unless we produce a tire that actually digs into the road.
We are coming to the end of the line of what the modern design of a tire can do. They can't get much lower in profile, not much more grip to be had, and there are several tires on the market that do just about everything very well (RE-11).
I wonder what the next revolution of the tire will be.
From the owners manual.....
While in Track Mode 1 or 2, the
maximum G value achieved
during the current ignition cycle
can be displayed by pressing
and holding the PAGE button.
The maximum G display will be
shown until the PAGE button is
released. The maximum G value
display will be identical to the
normal G value display, except
the maximum G gauge digits
(X.XX G) and corresponding
G gauge bar will overwrite the
current G value.
current G value.
The primary problem with the Goodyear EMT Tires is they age very fast. After as little as one year they become hard and perform poorly.
If you ever drive a C6 with a set of Michelins you will wonder why they ever mount Goodyears on this car.
At 1 year, 1/2 tread remaining and 11,000 miles, I replaced my stock gen 1 Goodyear runflats with 295 and 345 PS 2's. My personal feeling is that the Michelins are a much better performance tire but, unlike most people on here, I don't think the Goodyear is anywhere near as bad as they claim. The Michelins are a little quieter and ride a little better but I don't feel that it is a "night and day" difference. I would never consider the Goodyears "JUNK" as described by a lot of forum posters. I also feel that I would have gotten about 20,000 miles out of my runflats. I have just replaced my rear PS 2's with Cups. The PS 2's have 46,000 miles on them and have slightly less than 1/4 tread left but are hard as rocks and don't have much grip left in them.
Gary
Gary
Gary
Gary
current G value.
current G value.
Larry
After 153,000 miles and 12 punctures I'm staying with the runflat. My friend called one day during the start of his vaction trip with his 03 Z06and told me what I could do with the tire repair kit that came with the car. Driving far left lane 75 mph in heavy traffic right front tire goes down and before he could get to sholder the side wall was shredded. 80 mile flatbed ride two days to get replacement tire somewhere in AZ. To each his own
I think the only reason I can only pull a 1.27g is the meter is maxed out, it's probably higher!
Banking is everything
#33
I haven't figured out how to get a pic of it when it is happening. That's why the speedo is at zero.
The key to maxing out the g meter is not letting the car slide, as soon as you lose grip or slide the g's fall off.
It doesn't feel any faster than that of a tire with less grip, true-fully, it feels safer because it's not sliding.
Good tires and a well tuned suspension setup = 127g+
#36
lately I've found when I get an e-mail to a thread I've subscribed to, it doesn't always go back to the first post after I've posted/been to the thread, so I miss some of the posts. Thanks for calling my attention to the earlier post and to JoesC5 for the response in #25.
#37
#38
Received 8,989 Likes
Bill
#39
Check here, WG long course: http://www.comscc.org/events/track-records/
#40
You don't need banking to max out the G Meter. You can do that on a flat turn. If you are cornering slightly below the point where the front tires start pushing and flick the steering wheel into the turn a little more you can peak the G Meter. The car can't hold that peak for more than a moment but it definitely allows the driver to get a high peak reading.
If you don't use the flick of the steering wheel you can't get as high of a reading even if you use the throttle to add more speed to the point the front tires start pushing. Turn 9 (the so called Off Camber left) at the Glen is an easy turn to see this happening since the speed is lower than some other turns and the flow of the turn allows you to keep the HUD in your field of view.
Bill
