C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Katech Track Attack Z06 ready for delivery
Old 03-02-2012, 02:35 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default Katech Track Attack Z06 ready for delivery
Katech customers are very loyal.Once they realize the high level of craftsmanship and pride Katech employees have, they come back for repeat business. In this instance a customer came to us for a Street Attack build. Katech Performance built him an engine based on the existing LS7 platform; he then preceded to road race the car. After attending several Katech Track Attack events and logging over 40 hours, the customer was hooked on road racing and the engine was ready for a rebuild. Instead of going to another engine builder the customer came back for another build, a full race Track Attack LS7.
A build of this magnitude fits well with Katech, as we are experienced with building cars of this stature. Katech became famous in endurance road-racing by winning 24 hour races such as Daytona and Le Mans. This is no small feat as engines have to be extremely durable, yet maintain great power throughout the duration of the race and beyond.
To bring the build to the next level and turn this Corvette into a full Track Attack Z06 Katech scrapped the LS7 and went with a completely different engine. A strong block had to be selected, so we went with a RHS LS race block which has priority main oiling and allows the main bearings to see oil before it goes to the cam and valvetrain. This block is made of a heavy-duty A357-T6 Aluminum, which is much stronger than the softer material used in the factory LS7 block. The RHS cylinder case has added crank clearance if a customer wants to increase stroke up to 4.600”. A Callies Compstar crankshaft and H-beam rods were used with forged pistons that are cooled by oil squirters. The camshaft of choice for this engine is GM stage 3. It has been proven to provide a stable valvetrain and make great power. An ARE pump and pan are used to combat oil starvation experienced in high lateral-g turns. To supply air and fuel LS7 cylinder heads and a FAST 102mm intake are fed by a huge billet throttle body and injectors. This combination made 644 HP on Katech’s engine dyno and is track ready.
Mike Kasatkin, Marketing dept.
Katech Track Attack LS7/RHS
RHS Block
Callies crankshaft
Callies H-beam rods
Forged 2618 pistons
DLC pins
Piston squirters
Katech HCS/HCP "red" oil pump
ARE Stage 3 dry sump system
Head studs
Main studs
GM Stage 3 camshaft
WCCH LS7 heads
Bronze valve guides
Katech Ti/Mo intake valves
LS7 exhaust valves
Katech Ti retainers
Trend Pushrods
Halltech CF112 air intake system
FAST LSXR 102mm intake
NW102mm TB
ATI damper
Katech billet fuel rails and installation kit
Katech aluminum valve covers
Katech coil relocation
Katech billet belt tensioner
Katech LS9X clutch
Katech remote clutch bleeder
Turn One power steering pump
Previously equipped:
Brembo GT brakes
Moton coil-overs
Pfadt sway bars
Pratt & Miller C6RS seats
Halltech GT2 hood
__________________
Contact:
(e) zach@katechengines.com
Old 03-02-2012, 02:55 PM
sky1
sky1's Avatar
Wow what a piece.Nice build and great looks!
Old 03-02-2012, 03:01 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Nice cam choice, although I may be a bit biased in that opinion!
Old 03-02-2012, 03:32 PM
BigMike NY
BigMike NY's Avatar
RHS LS Race Block
Old 03-02-2012, 05:53 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
SWEET!
I am looking forward to seeing it run Sean!
JIm
Old 03-02-2012, 06:00 PM
wstaab
wstaab's Avatar
Valve springs used?
Rocker arms?
Picture of the Turn One PS pump and pulley?
Old 03-02-2012, 07:45 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Received 3,404 Likes on 1,374 Posts
Me too Jim. Now I just need to get away from work long enough to pick it up. The anticipation is killing me!
Old 03-02-2012, 08:20 PM
kentz06
kentz06's Avatar
Sean, that is a thing of beauty that Katech has built for you! So have you installed a full cage in your car?
I decided to not install the GM Stage 3 cam due to concerns about street drivability. Let me know how it acts once you have a few miles in.
Enjoy!
Dean
Old 03-02-2012, 08:36 PM
kentz06
kentz06's Avatar
So Everett, did you have a Stage 3 cam in your Mosler when I drove it at TA, or did that arrive later?
Dean
Old 03-02-2012, 08:51 PM
4GS7
4GS7's Avatar
Goddamn, I need that exact car. Plus your spoiler and a set of Forgelines.
Old 03-02-2012, 09:00 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Dean, will do. I have to admit that its a bit odd going from the exedy to ls9x clutch for better driveability but then going to the stage 3 cam. Jason swears it isn't bad with how Vector tunes them now.
Old 03-02-2012, 09:43 PM
4GS7
4GS7's Avatar
I thought Katech did all of their tuning in-house.
Old 03-02-2012, 09:48 PM
Everett Ogilvie
Dean
I used to drive it on the street and it only took a brief time to get used to it. I would never go smaller.
Just wait till you drive it next time.....
Old 03-02-2012, 10:57 PM
Mookster
Mookster's Avatar
Must be nice to be baller-sha with unlimited funds
Old 03-02-2012, 10:58 PM
Gering
Tolero Apto Victum
Gering's Avatar
Old 03-02-2012, 11:06 PM
Short-Throw
Short-Throw's Avatar
Sean,
Take your time, the car is at Autobahn going through some 'easy ' testing to make sure it's up to snuff.
Would like like me to bed in your brakes again?
The car looks great and the build sheet is a smorgasbord of high end products!!
Mike
Old 03-03-2012, 07:48 AM
DaOtherOne
DaOtherOne's Avatar
That car is going to be fast
To Katech Track Attack Z06 ready for delivery
Old 03-03-2012, 10:20 AM
tim414
tim414's Avatar
St. Jude Donor '12
Nice.
My fav color (now) to boot.
Old 03-03-2012, 11:05 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
why a rebuild after 40 hours?
Old 03-03-2012, 02:41 PM
Werks
Werks's Avatar
You do realize that 40 hours of racing use is like doing 2x 24hrs of LeMans races back to back. Even finishing one of those is an accomplishment for a built motor, let alone two. Jason can speak better about this but 40 hours of racing use is probably an equal amount of stress as 30-40k miles of street use.
Quick Reply: [Z06] Katech Track Attack Z06 ready for delivery
