C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2011 Z06 fogged headlamp...warranty item?
Old 01-10-2012, 11:22 PM
JMB
JMB's Avatar
Default 2011 Z06 fogged headlamp...warranty item?
Just noticed today when I got home from work that my right side headlamp is extremely fogged inside with no apparent breakage in the seal from the outside or cracked lense cover. With the car less than 1 year old it will be replaced via warranty? I picked up the car last March 2011.
Old 01-11-2012, 03:10 AM
Stevenyc777
Stevenyc777's Avatar
That's weird did they tell you how this could happen?
Old 01-11-2012, 06:21 AM
ospreycorvette
ospreycorvette's Avatar
Yes, warranty, I had the same issue.
Old 01-11-2012, 07:43 AM
JMB
JMB's Avatar
Nope!
Thanks, good to know....now the hassle factor
Old 01-11-2012, 10:28 AM
greendot
greendot's Avatar
Old 01-11-2012, 10:53 AM
btrapps
btrapps's Avatar
Default Headlight
I think I am what you would call an expert in this area Let me share my thoughts with the group on what causes this. I own a manufacturing business that produces vents for automotive applications. Some of these vents are placed on lighting applications that allow air and gas to pass but block contaminants and moisture. I recently just got back into the Z06 world so I am not aware of the vent that is being used on Corvettes but I suspect it is a vented application from one of our competitors. You definitely can have the light replaced under warranty.
Old 01-11-2012, 08:18 PM
JMB
JMB's Avatar
Good to have this reinforced!
Old 01-11-2012, 08:41 PM
rapidroy
rapidroy's Avatar
I had a much smaller problem of a film on both my lenses, and they were both replaced with no hassles from the dealership at all.
One small heads up: to replace the lens, the front clip needs to be removed and the affected fender needs to be loosened so it can be raised enough to get to the screws and connector to remove the old unit. When they put mine back together the guy didn't line things up correctly, so be sure and check how the front clip lines up with the fender before you leave.
Good luck.
Old 01-11-2012, 09:03 PM
JMB
JMB's Avatar
Awesome! Now this is exactly the type of feedback I am looking for so that I know what can go sideways when they perform the work, THANKS!
Old 01-12-2012, 10:41 AM
90sundevil
90sundevil's Avatar
Too bad both did not need replacement, then you could have gone to black.
Old 01-12-2012, 06:56 PM
JMB
JMB's Avatar
Maybe you didn't notice....they are black!
Old 01-26-2012, 01:31 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
Has your concern been resolved? Was the dealer able to assist you? Please feel free to contact me with an update.
Tricia, Chevrolet Customer Service.
Old 01-26-2012, 01:52 PM
cashs_mom
cashs_mom's Avatar
I had that issue on my C6 coupe on both headlights. The dealership replaced them gratis even though they were technically out of warranty. I would say that with a less than year old car, they should definitely replace them.
Old 01-26-2012, 02:21 PM
JMB
JMB's Avatar
Tricia, thanks for the follow-up! My local dealer had to order the replacement part (under warranty) and I am scheduled for installation this Saturday.
I was also rather surprised because the dealer also told me that there was a recall notice on my car for replacing the rear glass hatch struts (may come apart from the glass during collision causing the rear window to fly away from the car) which they also ordered but I never received a recall notice for this....I'm wondering if others have?
Old 01-26-2012, 09:18 PM
VNAMVET
VNAMVET's Avatar
The whole front clip has to be taken off.
I had the same issue and when they replaced the headlight and the front bumper, the rubber that surrounds the headlamp did not fit as stock. I can actually see through the space and see the ground!!
The headlight used to be flush with the bumper, but not sits 3/8" inch above it.
Check yours...before and after. Take pics!!!!!!!!
Old 01-27-2012, 06:49 PM
JMB
JMB's Avatar
Pic's taken, thanks for the tip!
To 2011 Z06 fogged headlamp...warranty item?
Quick Reply: [Z06] 2011 Z06 fogged headlamp...warranty item?
