[Z06] Well...heads are coming off....
After lots of time spend contemplating i have decided to pull the heads. They come off tomorrow. I will be sending them off to RPM. I have talked to Charlie and he has made me feel confident in my decision.
Once I get all the parts ironed out i will post up. I hope Charlie will be OK with posting findings as i am sure the Forum will benefit from anything they may find.
A few questions:
-I have ARP head bolts 134-3610 ready for the reinstall as well as a new set of ARP header studs. I plan on using OEM GM head gaskets as well.
- What is the recommended torque sequence for the heads? I assume the Torque spec sheet that came with the ARP bolts is good for LS7? I iwll of course be replacing the sodium filled valves, guides, seals, and maybe a new spring kit if need be. Should I replace little things like lifters as well? Anything else?
I will aslo be installing a new Gatorback belt and a set of Hinson transmission mounts to match my Hinson motor mounts.
Any other tips welcome!
A few questions:
Follow the shop manual. Inside out. I think ARP says 25/45/75 ft/lb 3 pass sequence.
good luck! i'm curious to hear how your valves/guides have held up with that cam. oddly enough, mine didnt show any wear when we pulled them off. but i still have a sense of relief from adding all new hardware. nice to see you brought back the creepy avitar.
Excited about this thread, and looking to all the info it provides. With all the threads out there on failures I'm also considering head work on my 07. What year Z and how many miles are on the ticker? Will you be doing a cam as well?
Good luck, please keep us updated and PICS PICS PICS !!
Thanks! Lol!
Yep read both of those.
I have the M11 to 75ftlb and the M8 to 25ftlb using the Ultra Tq Lube. I was mostly concerned w the sequence and TQ for each pass..which they dont specify. I found the sequence i believe. It should be the samf or the LS7?
Will be interesting indeed to see how your heads look, especially at your power level, 4k miles with a blower and 20k on your engine
My car is also an 07 with 20k on it, but I am bone stock.
I don't recall see any LS7 Failures (at least ones we've tracked here) that had blowers on them..they all seem to have cams, or are stock, tracked etc..
Yes that sequence is correct.
Did you get the ARP clean out tap? You need to clean your threads out. Just something to remember.
Im going to pick up my heads today. Ill snap photos of any irregularities.
PLEASE, provide valve guide wear measurements.
Also, model year, miles on engine, brand and weight of oil, and how the car was driven, as well as any warm up procedure. Also, anything else you can add.
Thanks.
Thanks.
Like I said I hope RPM will post up the conditiin of the heads in general.
As far as condition and other general info: 2007 w LPE616 kit (689 lift cam)(been on the car since 5000mi) stock rockerw w Comp trunion kit also A&A V3 kit w a 3.8" pulley making 6lb. I have been running the Amsloil High Zink 5-40 amd I ALWAYS warm.the oil to 140deg before going past 2500rpm or into boost. I dont track the car at all...at most a.few 150mph plus pulls from 50mph. As of now.the car runs PERFECT..no noises, good power, no nothing. Im only doing this to put my mind at ease and to find out cor myself what all.the fuss is.about.
Also please provide type of fuel used, what type of socks you wear when driving, how much you weigh, approximate distance from the sun during engine warm up, how many hookers have ridden shotgun, how many dead hookers have been in the trunk, what was the current phase of the moon when operating at engine temps over 150*, the name of your first pet, how many times you’ve driven north of the Mason-Dixon line, and how many times you go number 2 in a week. This should give us plenty of data to analyze guide wear.
I would be surprised if there isn't excess wear. Every single local car I know of that has had the heads off have had severely worn guides.
Katech has already stated from what they've seen, the problem with the guide wear seems to be accelerated on cam'd cars, or non stock motors.
