[Z06] 2009 Z06 Mods Recommendations
Anbother question to ask all the CF members what kind of Mods should consider to the Z06 and I have listed a few and I am open to plenty of suggestions (again it will be driven on the street not lookiung for cams or superchargers but open to tunes, exhaust (no headers), intake)!
1. Vararam Intake or another suggestion (had this on ym C5 Z06 and it was awesome)?
2. Mild to Wild or should I change the exhaust?
3. Tune? COW Tune?
Any other minor bolt ons?
3. Tune? COW Tune?
3. Tune? COW Tune?
3. Tune? COW Tune?
MGW shifter
air intake and tune Only cause you might lose your 5 yr/100K powertrain warranty if there is a engine problem and GM detects a tune. If you don't care bout the warranty, then
3. Tune? COW Tune?
3. Tune? COW Tune?
No drag racing just a drivber and what I had in the past on my C5 Z06 was the COW Tune, Vararam Intake and Borla Exhaust! I was figuring the same package but are there other options since I am new to the C6 Z06? Will I GO to the track well maybe just once or twice! Are exhaust systems Cat Back worth it (HP) or is it just a sound?
A&A kit, clutch, tires. 600+rwhp, drives like stock, and fun.
mgw shifter, corsa, coilovers and sways. YOu can stop there or then move on to cam and headers.
This is of course if you like your car to be a good bit sportier in terms of how it rides and sounds, it definitley will not be as subdued as it is now. If you want a stock ride then dont go with anything after the mgw shifter except for an intake and tune then call it a day in that case.
The Consigliere
Received 5,444 Likes
Have you seen the recent thread of Ranger's 1/4 mile run in a bone stock Z?
One could argue it's a pretty good testament to leaving the engine stock.
That said, I've certainly modded cars in the past - including a Z - just for the fun of it. Whatever you do, research it hard first with clear goals in mind a eyes wide open to the compromises involved (and there always are compromises).
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Based on this, you may be served best with a CAI and a tune. We have had excellent results with Halltech's new MF 103 and Beehive. (Our prior C5Z utilized the Vararam.) The halltech product is easy to install and is of superb quality. The results at the track confirmed that we made the right decision. As for a tune, I would recommend a good dyno tune as oppose to a mail order tune. This will extract the most potential. If you PM me, I can make a recommendation for that.
Headers, waste of of money for at least $2,500 installed on a LS7 engine that will remain stock, as the shorty factory headers flow REAL good, and on a stock LS7 engine not worth the big $ for small gains, unless your looking to extract every ounce out of the engine, and if that is the case and you have $ to burn, then go for it (if your willing to tune)!!
Now, you do realize you will jeopardize your 5/100K factory drivetrain with a tune, and if your not willing to do that (which I don't blame you) then I would hold off on the CAI until you are willing to get a tune b/c you are not going to feel 10HP, and in some instances CAI has caused people to run slower than they would with a stock air box if the car is not tuned (I am living proof of that). On my car my CAI intake caused my car to run PIG RICH in the 10s air/fuel ratio at WOT, verified on 2 seperate dynos, and I am not willing to jeopardize my GMMP warranty, so back to the stock air box I will be going (until such time I am willing to tune the car).
If you want to preserve your GM 5yr/100K warranty, throw on the above referenced cat back system or mild to wild, and call it a day, and the best mod for you is the driver mod, and learning how to drive this POWERFUL car and be careful with it, its a BEAST, CONGRATS on your 2009 Z, a great year for Z06s.
I read in a previous thread that the stock intake from GM actually out performs most aftermarket ones. They said the design is a factory cold air system that fits up perfectly to the front intake grill maximizing airflow. It also said it would only be beneficial to change the air filter with a nondisposable oiling filter such as k&n. It was infered that most aftermarket ones don't have the same fitting to the front intake and actually disrupt airflow. Anyone have any info on this? Im not saying it is true it is just what I read here previously. Thanks!
Supporting Vendor
St. Jude Donor '11,'13
3. Tune? COW Tune?
3. Tune? COW Tune?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
09 Z06 here. Installed the M2W and the GAGS eliminator. I use the stock air breather with the stock Donaldson filter element(best on the market) but installed a Vette-Air "cold air" scoop behind the grille. I had to make a flat diffuser plate to prevent it from throwing codes, as it was working to good, ramming air into the mouth of the air breather. I have the wings that attach to the top of the radiator shroud, from an Airaid air breather kit, that are to minimize the hot air from the engine compartment from seeping over into the air breather compartment when the car is not moving, that I will be installing next spring.
I believe that getting "cold" outside air to the stock air breather works just as well as any CAI kit for 99% of the uses my car sees. I might not be gaining 10 HP at 160 MPH(at Talledaga), but I believe it's more important to keep from losing 20-30 HP at low speeds(where most of my legal highway driving occurs) because the engine is digesting hot air( and pulling lots of timing), thus my "cold-air" scoop and the Airaid wings.
After my 5 year driveline warranty is up in a year and a half, I might consider a mild tune, just to clean things up a little. No way am I going to tune the car on the ragged edge just to gain a couple more horsepower that I'll never feel, thus a "mild tune".
Oh, and don't forget the "427" GM emblems on the hood.
This morning I killed my deal on the car so I am back on the market looking for another Z06 please read my post in C6 General Discussion. Thanks again for the advice and all well wishes and recommendations!
