C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Escort 9500ix and Blendmount Package
Old 03-08-2013, 02:35 PM
  #41
VictoryLap
VictoryLap's Avatar
Isn't it the redline that actually has better / longer reception?
Old 03-08-2013, 09:11 PM
  #42
Z06hopeful
Z06hopeful's Avatar
Used the BlendMount and the Mirror tap on my 08 Z. Looks GREAT... perfect fit, nice and tight to the mirror , and no wires visible...perfect..
Old 03-09-2013, 08:07 AM
  #43
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Yes, it does have a more sensitive receiver and is good if you only use a detector on the highway. The 9500ix is good for both city and highway and also uses GPS to block out false alarms in the city. The 9500ix is not quit as sensitive as the Redline, personally I like the 9500ix but nothing against the Redline either. We do offer both versions....
Jim
Old 04-11-2013, 05:20 PM
  #44
southerncarparts
Supporting Vendor
use coupon code "escort" when checking out....
Jim
Old 04-12-2013, 08:55 PM
  #45
ZeroDude
ZeroDude's Avatar
I too bought this and wanted to ask where the red and green wires go into or onto the mirror connector. The instructions say to use black on upper row and ping in center of bottom row. I could not get power using this method but admittedly my Detector might be at fault and I might have a faulty mini cord. Can anyone that installed on a 2lz z06 with onstar confirm or let me know which wires worked on escort 9500? odds are I will be cutting into wires so if any one can tell me which colored wires they ended up using for the gren and black o nthe mini cord it will be appreciated.
Old 04-12-2013, 09:03 PM
  #46
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
'09 C6Z 2LZ here...I used this diagram and it worked great. http://www.mirrortap.com/docs/instru.../mt-104-01.pdf
Old 04-13-2013, 12:59 AM
  #47
ZeroDude
ZeroDude's Avatar
I'm guessing I must have received a generic brand as my instructions were not this clear.
Sadly my red wire pin broke so I will have to tap into the pink wire or try to get a replacement cable.
Old 11-19-2013, 08:04 PM
  #48
pkincy
pkincy's Avatar
Thank you!! Much clearer than the much less clear instructions included with the power cord. I, too, was unable to get mine to work but apparently it was because I was trying to put the "quick connect" under the black and pink wires (autodimming mirror on my Z06) rather than over the wire. And under does result in no power.
It still does result in some mystery because red and green while definitely the middle pair in an RJ11 connector has no known connection to + and/or - electricity. Were you or I selling this product we would include your very fine link in the instructions and also identify what wire in the RJ11 was pos and which was negative (from the red and green choices) or we would use the outside pair in the RJ11 which are yellow and black and most of us would assume the black wire of the pair is the ground.
Full Disclosure: I bought the Blendmount and cord from the other vendor on the forum that sells it not SouthernCarParts and SouthernCarParts' instructions could be crystal clear on the power cord. From the other guys it was not at all clear. And the Blendmount itself couldn't be easier to install nor could there be a better solution for mounting the 9500ix.
Old 12-30-2013, 03:34 PM
  #49
BLUEMEANIE
BLUEMEANIE's Avatar
Can someone please post a drivers view of the blend mount in a c6.
Old 12-31-2013, 11:39 AM
  #50
LIE2ME
LIE2ME's Avatar
Received 4,574 Likes on 1,644 Posts
Originally Posted by southerncarparts
We love the Escort 9500ix here at Southern Car Parts. Since its release, the Escort 9500ix/ blendmount-radar-detector-package has been one of our personal favorite products, and has consistently been amongst our most well-reviewed.
I am going to be purchasing a C7 in the next few months and I have heard the rearview mirror wiring in the C7's mirror is not accessed in the same was as the C6 and that is causing problems mounting the 9500ix into the C7 with the blendmount unit. Do you have any info on this?
Thanks...
Old 01-16-2014, 04:23 PM
  #51
southerncarparts
Supporting Vendor
Thanks...
No info yet, but we'll be sure to post on here as soon as we do.
Old 01-22-2014, 10:11 PM
  #52
LIE2ME
LIE2ME's Avatar
I understand the Redline is more sensitive, but at the expense of substantially more false alarms...
Old 01-22-2014, 11:00 PM
  #53
lane_change
lane_change's Avatar
I already have a 9500, how much for just the blend mount itself and the wire tap for power?
Old 01-29-2014, 08:49 AM
  #54
southerncarparts
Supporting Vendor
Hi,
You can order both of those here: http://www.southerncarparts.com/adva...mjkj43&x=0&y=0
Old 08-05-2014, 10:14 AM
  #55
greatgonzer
greatgonzer's Avatar
How does this blend mount work with the Escort 9500IX Mute cord? Where do you place that device? Is there a holder that keeps the mute button up by the rear view mirror?
Old 08-07-2014, 08:19 PM
  #56
want a C6ZO6
want a C6ZO6's Avatar
Already have the Radar Detector, just ordered the blendmount and power cord. Thanks!
Old 08-26-2014, 04:50 PM
  #57
southerncarparts
Supporting Vendor
Thank you!
To Escort 9500ix and Blendmount Package
Old 08-26-2014, 05:28 PM
  #58
greatgonzer
No answer to my question as of yet?....hmmmm.
Old 10-08-2014, 02:52 AM
  #59
Z0666.
5th Gear
Z0666.'s Avatar
I have the 9500IX with the blend mout I love it it's very sleek looking etc happy to have got it....you wouldnt be disappointed
Old 03-24-2015, 09:15 AM
  #60
greatgonzer
How much shipped (87144) for just the C6 Z06 Blendmount for an Escort 9500ix detector. I already have the detector, just need the Blendmount. thanks
Quick Reply: [Z06] Escort 9500ix and Blendmount Package
