Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-24-2011, 01:27 AM   #1
parsonsj
CF Senior Member
Support Corvetteforum!
parsonsj's Avatar
jp@iimuchfabrication.com
Default Steering angle sensor model year differences?
Hey guys,
In an effort to fix my steering column (the tilt column pins fall out), I recently picked up a MY '10 column. My Z06 is an '07, and I swapped in the new(er) one tonight. The columns were identical and it bolted right in, but my first inkling there might be trouble was that the steering angle sensor (the one at the bottom of the column) was different. Both have 4 wires, but I had to swap in the new harness and use the new sensor -- no way to put the 07 sensor on the '10 column.
With everything installed, it all seems to work. Telescopic memory, all the turn signals, etc.
BUT: the service active handling light is on, and competitive mode isn't available. Am I out of luck? Is there a way to "reset" the EBCM and have it "relearn" the steering angle sensor?
Any other ideas?
thanks!!
jp
parsonsj is offline   Reply With Quote
Old 10-24-2011, 01:02 PM   #2
parsonsj
CF Senior Member
parsonsj's Avatar
Anybody?
Another angle: can anybody with a '10 Helms manual identify the four wires going to the sensor? I could compare that to my 07 manual.
thanks!!!
Old 10-25-2011, 07:43 AM   #3
millhouse1
Junior Member
2009-2012 use the same sensor. 2007-2008 use a different sensor.
09-12 part # is 25858802. 07-08 # is 15231656.
millhouse1 is offline   Reply With Quote
Old 10-25-2011, 10:59 AM   #4
parsonsj
CF Senior Member
parsonsj's Avatar
Cool, thanks for that. Anybody know if the function is different?
My 07 book tells me that SWS pin 1 is a 5v reference, pin 2 is Low reference, pin 5 is Signal A, and pin 6 is Signal B.
Any got a '10 book? I could check to see if the harness wires match.
Is there some sort "calibration" procedure I could try?
Old 10-25-2011, 01:30 PM   #5
parsonsj
CF Senior Member
parsonsj's Avatar
Here's the 07 schematic. Note that Signal A and B go directly to the EBCM. If the newer sensor is only packaged differently -- and the signals themselves are the same -- it should work.
Old 10-25-2011, 01:57 PM   #6
Vito.A
CF Senior Member
Vito.A's Avatar
Send a message via AIM to Vito.A
You might try to connect the old sensor and see if the light resets. If that works, then the challenge would be adapting it to the new column.
Vito.A is offline   Reply With Quote
Old 10-25-2011, 02:16 PM   #7
parsonsj
CF Senior Member
parsonsj's Avatar
Quote:
I've thought about how I might do that, so yes, I'll see if that's possible. The difficulty is that the connector is different (though both have 4 pins). Worse than that, the column that the sensor inner race mounts on is different.
A schematic of the newer sensor would be very helpful.
Old 10-25-2011, 06:34 PM   #8
parsonsj
CF Senior Member
parsonsj's Avatar
Pulled the code: B0710 Steering position signal.
Old 10-27-2011, 09:44 AM   #9
parsonsj
CF Senior Member
parsonsj's Avatar
Just to complete this conversation with myself , I pulled the 2010 column out and "rebuilt" the 07 column with the 2010 tilt mechanism. That put back the 2007 steering shaft and end bearing, letting me use the 07 SWS.
All now seems well. The DIC is silent, Competitive Mode is back, and hopefully, the pins won't fall out any more.
Old 02-24-2013, 05:02 PM   #10
JerryTX
CF Senior Member
Sorry to dig up an old thread but I was looking for advice on replacing the sensor, any tips or tricks? Does the column have to come out, if so where does it unbolt? Mine is a caged c6 so I'm going to have to remove the seat to have any chance of seeing up under the column.
JerryTX is offline   Reply With Quote
Reload this Page Steering angle sensor model year differences?
Tags
2000, 2007, angle, b0710, c5, chevy, code, corvette, jp, number, part, performance, position, sensor, steering
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steering Column Swap/Weights ltborg C5 Tech 1 03-20-2014 10:05 PM
'70 steering column bracket spacer 1970greenLS5 C3 Tech/Performance 2 03-02-2014 10:13 PM
Need 08 C6 coupe manual steering column/ steering angle sensor wiring Schematic red12secz28 C6 Tech/Performance 12 11-07-2013 01:07 PM
Steering Column and Angle Sensor question JerryTX Autocrossing & Roadracing 0 03-02-2013 04:40 PM
Help On Swapping Out A '99 Steering Column!! Ironman433 C5 Tech 1 01-05-2013 03:06 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
