[Z06] What push rod length are you running for milled (.030) lS7 Heads
Like that title says. What Length and brand of push rods do you guys run when you mill your LS7 heads?
I know stock length is 7.800 so I was thinking of dropping to (7.750)
Depends on the cam base circle, lifters, gasket thickness, etc......but with my heads I had to drop down to a 7.750. But mine are only flat milled around .010 and the rest of my port work was angle milled from WCCH.
As Lane_Change stated, it depends on a lot of variables. I have a Lethal cam and ended up with a 7.750 pushrod with my .030 milled stock heads. You really should measure but I bet the 7.750 would be close with stock head gaskets and similar base circle cam like the Lethal.
Thank you both, and yes I know the mechanics of this, and all the variables, just wanted to get some solid feedback from those that have already done this. Thanks again.
Ernie.
Ernie.
I did 7.775 so .025 shorter and these worked for my lethal cam setup. Make sure you order the right ones as it took the place I ordered from 3 times to get it right
Head work via TPS
I run the Manley Nex-Tek Springs. They were rated good and Ragin recommended them with the cam. I run PAC's on my LS6 and they seem good too. I would run what the cam manufacturer suggests as they have a larger experience base. Good luck Amigo. You will love the car with the bigger cam. Everyone loves the sound of a cammed up car....
