C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] wild to mild quit working, suggestions?
Old 10-09-2011, 02:41 PM
Madsen
Madsen's Avatar
Default wild to mild quit working, suggestions?
Wild to mild switch quit working. have had it on for about 25k miles.
the battery on the switch seems to work as it turnes on the light on the button. all wires are still connected and not loose.
anyone had this happen?
thanks in advance
Old 10-09-2011, 02:52 PM
ArrogantZ
ArrogantZ's Avatar
thanks in advance
Same issue! I'm probably goin to throw out the mild to wild and hard wire a switch to the center console
Old 10-09-2011, 02:53 PM
Oskee
Oskee's Avatar
Have you checked the voltage in the fob switch ??? I had the same problem voltage was low even though the green / red light would come on. Replaced the battery and problem went away. Hope this helps
Old 10-09-2011, 03:30 PM
Madsen
Madsen's Avatar
THANKS i WILL GET A NEW BATTERY ASAP
Old 10-09-2011, 07:15 PM
XxWarEaglexX
XxWarEaglexX's Avatar
I sort of had the same problem with my viper car alarm. The light would show but, wouldn't arm the alarm. Changed the battery in the remote and it started working again.
Old 10-09-2011, 08:53 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Chuck it and buy a $4.95 switch from Radio Shack.
Old 10-09-2011, 09:40 PM
Zoxxo
Zoxxo's Avatar
Z//
Old 10-10-2011, 10:56 AM
Mdm23
Mdm23's Avatar
Pull the fuse. Wild is the only way.
Old 10-10-2011, 01:32 PM
JJC5
JJC5's Avatar
Good move....hard wired works great.
Old 10-10-2011, 04:20 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
My M2W came with two remotes. Are you having the identical problem with both remotes?
Old 10-10-2011, 09:02 PM
jwbert
jwbert's Avatar
Default Batteries
I had the same problem with both remotes, batteries were low in both even though the red transmit light came on. New batts, no probs
Old 10-11-2011, 08:37 AM
Jet Stream Blue Z06
Jet Stream Blue Z06's Avatar
Can you hear the switch click when you press the remote? Mine stopped working and I found that a vacuum line came off one of the actuators in the rear. Easy fix.
Old 10-11-2011, 03:10 PM
skudlw
skudlw's Avatar
you need a new battary for the fob. Light will still work with a weak battary. Mine did the same and when I replaced the battary, all was well. Get it from Radio Shack.
Old 10-11-2011, 03:26 PM
rpm94
rpm94's Avatar
You can replace it with mine. Had it on the car for only 2 months then got the Akrapovics installed. Don't know why I did it but I just had to have the price Akrapovic exhaust controller. It looks cool, but no way worth $350.00.
I am a dumb ***.
Anyone want my 99% new M2W controller? $55.00 shipped to your door (continental US only). If you want to go Paypal, you got to pick up the fees (minimal).
I will post this in the For Sale section, but this post was relevant.
Old 10-11-2011, 03:42 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
thanks in advance
You say the M2W quit working - what do you mean???
Are the valves closed and your M2W won't open them?
Do the valves open when you accelerate and the RPM goes up past where they should open normally?
Or, are they open all the time?
If they are open all the time the problem is most likely NOT your M2W switch.
The valves require engine vacuum to close them, so if they are open all the time you've probably got o loose, broken, or split vacuum tube somewhere.
Bob
Old 10-11-2011, 04:49 PM
ferravette
ferravette's Avatar
I had the same thing happen to one of the remotes. Wound up throwing it out. What i did was program one of the home link buttons and that works all the time.
Old 08-14-2013, 10:42 PM
tt350z
tt350z's Avatar
How do you program your home link button to it?
To wild to mild quit working, suggestions?
Old 08-14-2013, 11:38 PM
FNBADAZ06
FNBADAZ06's Avatar
You need a 2006 built in October or earlier to use Home Link, but here's the instructions on how to program....
http://nakidparts.com/sitebuildercon...rfiles/m2w.pdf
Old 08-15-2013, 12:37 AM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I am a dumb ***.
Well, at least you're not in denial.
Old 08-15-2013, 12:58 AM
SSMOKE
SSMOKE's Avatar
Same with me, vacuum line came off of the actuator. EASY FIX.
Quick Reply: [Z06] wild to mild quit working, suggestions?
