Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-28-2011, 11:53 AM   #1
Hercules Rockefeller
CF Senior Member
Hercules Rockefeller's Avatar
Default Simple question: Will pulling ABS fuse affect other active handling systems?
Like the title says, I want to know what will happen if I pull the ABS fuse in my car. Will it just disable the ABS system, or will it take out traction control and/or other active handling features?
Hercules Rockefeller is offline   Reply With Quote
Old 09-28-2011, 12:22 PM   #2
sengli
CF Senior Member
Isn't active handling based on the ability to brake different wheels independantly? I would think by defeating the ABS it would take out the active handling. I know the bosch module for ABS/ handling went out in my Z recently due to a lightning strike at the house. And that module I beleive handled both functions.
sengli is offline   Reply With Quote
Old 09-28-2011, 12:27 PM   #3
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Quote:
Welllll......I'd say just go out to your car and pull the fuse and see what happens!!!
Butt.....I've done that for you. When you pull the ABS fuse you get lights illuminated in the IPC and the following messages in your DIC:
  • Service ABS
  • Service Traction System
  • Service Active Handling
  • Service Vehicle Soon
And the AH/TC button on the console doesn't do anything.
So......yes, pulling the ABS fuse affects AH and TC.
Bob
__________________
BEZ06 is online now   Reply With Quote
Old 09-28-2011, 12:56 PM   #4
Bill Dearborn
Bill Dearborn's Avatar
All of those features are controlled by the EBCM. When you pull that fuse you cut power to the EBCM.
You also lose Dynamic Rear Proportioning which determines how much brake pressure should be applied to the rear wheels. Before 2001 the proportioning was handled by installing a spring controlled proportioning valve near the master cylinder. Since then the EBMC does the job.
Bill
Bill Dearborn is offline   Reply With Quote
Old 09-28-2011, 01:01 PM   #5
CF Senior Member
Thanks guys, just what I wanted to know. So if I want to run w/o ABS, I have to run with it all off. Last question: the car isn't going to go into "reduced power mode" or any other low performance mode when it detects a failure of the active handling system, correct?
Thanks again.
Old 09-28-2011, 01:18 PM   #6
BEZ06
Formerly beezeye
BEZ06's Avatar
Thanks again.
I don't think you'll have any problems.
When I attended Spring Mountain we did a number of wet skidpad exercises with the ABS fuse pulled. They weren't at speeds of more than 40 or 45 mph, but there weren't any messages to limit speed.
However......if you ever do those type of braking drills with and without ABS, you would NEVER want to drive without ABS and the control it gives you when braking hard and have to maneuver.
The ABS on our cars is VERY GOOD!!!! I won't drive without it on my car on the street or on the track.
Bob
__________________
Old 09-28-2011, 01:47 PM   #7
Bill Dearborn
No. If you are doing hard braking you might get more rear wheel lockup since there won't be anything limiting rear wheel brake pressure. You will also lose Engine Drag Control and the Red Brake Light on the IP will be lit since Dynamic Rear Proportioning doesn't work.
Bill
Old 09-29-2011, 12:01 PM   #8
CF Senior Member
Well I have an adjustable brake bias valve in my setup, and I wanted to tune it in the absence of any electronic control systems to the point where the front tires would just barely lock up before the rears.
Additionally, while the ABS works very well at most tracks, there is a problem I frequently have with the system at Buttonwillow, in a corner called the buttonhook (I believe). It's basically a right hand hairpin with a braking zone that has a dip on the right side of the track. When braking hard through this dip, if you don't lift just the right amount at just the right time, your right front wheel will lose traction and trigger the whole damn ABS system, increasing your braking distance WAAY to much. I almost missed the corner last time I was there. I'd rather just temporarily lock/chirp the right front tire for a tenth of a second than have the ABS think I'm driving on icewater, increasing my braking distance by over 10 yards.
Old 09-29-2011, 01:19 PM   #9
jvp
jvp's Avatar
Send a message via AIM to jvp
Uhhh... I don't doubt your track experience, but I question your explanation of it. The ABS in the Corvette monitors wheel slip independently and activates accordingly. Something else is at play here. Disabling the ABS in that section is going to be more than a quick lock-up: you're going to flat-spot your very expensive tires and potentially slide further than you already do. Remember: rolling friction is much higher than sliding friction.
My guess is that the ABS reaction is causing you to panic a bit and you then let off the brake pedal, which will lengthen the stopping distance.
I'd be really, really careful with this experiment.
jas
__________________
"It's not a car, it's a Superman suit. You don't drive your Corvette, you wear it. And when you're wearing your Corvette, nothing can hurt you." All Corvettes are Red
jvp is offline   Reply With Quote
Old 09-29-2011, 01:45 PM   #10
veech
CF Senior Member
veech's Avatar
Doesnt Pulling the Handbrake up just enough to trip the Light disable the Abs too? did on all my other Gm's
veech is offline   Reply With Quote
Old 09-29-2011, 02:03 PM   #11
Bill Dearborn
jas
Could be that or it could be he doesn't increase brake force when the wheel starts to ABS. When the ABS starts to modulate the wheel that means that wheel has lost traction and can't contribute as much stopping power as it could if it still had traction. You have to make up for that by increasing brake pressure at the other wheels.
If he pulls the fuse he will get the same thing except that wheel will lock up, pull the steering and provide less stopping power. A sliding wheel has less friction than a wheel that is close to lockup so the only way to make up for that is to press the brake harder to get the other three wheels to brake more. That is why threshold braking is difficult at times. Do you threshold brake just one wheel or do you let it slide and threshold brake the remaining wheels?
Bill
Old 10-02-2011, 02:31 AM   #12
CF Senior Member
jas
Well this could be, but it sure doesn't feel that way. I could be mistaken about the "right side" only bit, the dip could extend to both wheels, but it's definitely a bigger dip on one side of the car. Anyway, my experience it that if I don't lift off the brakes just right at the dip, the wheels will want to lock, at which point the ABS kicks in, but the problem is that it stays on well after the dip has passed, I'd say for a good quarter of a second, when in fact the dip flies by in a few hundredths of a second. It doesn't sound like much, but it makes a big difference in braking distance. I know that a locked wheel gets much less traction than a static friction wheel, but if the wheel is only going to lock for a few hundredths of a second under low load, I'm not that worried about flat-spotting. What I am worried about is an over protective ABS system that drastically reduces the braking power to the wheels long after the low traction event has passed.
Quote:
Really?!
Reload this Page Simple question: Will pulling ABS fuse affect other active handling systems?
Tags
abs, active, affect, c5, corvette, disable, disabling, fix, fuse, handling, locations, problem, pulling, pump, system
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
