C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Anyone using Mobil 1 High Mileage
Old 11-09-2011, 12:00 AM
Lawdogg
Lawdogg's Avatar
Default Anyone using Mobil 1 High Mileage
Has more anti-wear properties than regular Mobil 1. Opinions on using for our low mileage Z06s?
Old 11-09-2011, 12:36 AM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
I know the M1 0W40 (Eurpean Blend) is spec'd for C6 Zs in Europe, and this 0W40 Mobile one oil also has more anit-wear additives and seems like a better choice, since GM calls for it in Zs in Europe.
That being said counselor I don't know how the Eurpoean blend matches up versus the M1 high mileage oil for a low mile Z, that will be driven the way it was meant to.
Old 11-09-2011, 11:41 AM
Lawdogg
Lawdogg's Avatar
Thanks Mopar. The reason this came up, is that I know of an engine builder that uses the Mobil 1 High Mileage in the LS motors he builds. Just wondering if anyone else has an opinion or info on using this in our motors.
Old 11-09-2011, 02:44 PM
Vito.A
Vito.A's Avatar
Some of the folks are using the Shell Rotella T6 synthetic for the higher ZDP.
Old 11-09-2011, 04:30 PM
160KTS
160KTS's Avatar
This, along with Mobil 1 0w40 is going to be a better oil for wear on our cars than a high millage oil. I run Amsoil because of their higher ZDP or Penzoil Ultra if Amsoil isn't available. I have run 0w40 and would run it again. When you only do two oil changes a year you don't exactly change oil often!
Basically, if you want Mobil 1, use 0w40. If you're willing to venture away from it, do your research and buy the best possible oil available.
Old 11-09-2011, 04:36 PM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
I have been running the Mobil 1 Extended in my 09Z. I had a Blackstone lab test done at a 5000 mile oil change. They checked the "additives" and suggested going another 2K miles. I had 3-4 HPDE days, the Mojave Mile once or twice and the Silver State Classic at the 110 MPH class on the oil and their tests indicated all is well.
I do like the idea of the Mobil 1 0W-40, particularly if it is spec'd for the Euro Z's.
Old 11-09-2011, 05:16 PM
Lawdogg
Lawdogg's Avatar
I'm convinced. 0/40 Mobil 1 it is.
Old 11-09-2011, 06:17 PM
Mopar Jimmy
St. Jude Donor '06
Seems to be really good oil!
Why do you oil experts think that GM spec's it for its Eurpoean Zs and not American Zs?
Old 11-09-2011, 06:46 PM
Mark923
Mark923's Avatar
USE IT...I checked on the difference with Mobil several years ago after the Extend Per became available.
They said the Extend Per Mobil 1 had about twice the amount of wear resistant stuff, so I started using it in all my vehicles at that time.
As a side note about why I've used Mobil 1 since 1979, the following occurred after the first oil change to Mobil 1 5w30 that year.
1. Changed oil at 8000 miles in my Honda to Mobil 1.
2. Started engine that warm day after the change to Mobil 1 and couldn't figure out why it immediately went to 1250 RPMs...
3. Let engine warm, tapped gas pedal to be sure auto choke on Carb was not engaged, and watched RPMs settle back to 1250...just an engine without a computer telling it what to do.
4. Had to back-off the Carburetor idle adjustment screw to get the idle back to the normal 750 RPMs.
That was a lot of friction reduction in the engine, so I've used Mobil 1 in all my cars since. In simple terms, it works! And to my delight, my first Corvette in 1992 came from the factory with Mobil 1 already in it.
Old 11-09-2011, 06:53 PM
Gary '09 C6
Gary '09 C6's Avatar
...also, is the formulation identical for the same-grade of oil sold in the US vs Europe ?
Old 11-09-2011, 06:58 PM
Mopar Jimmy
St. Jude Donor '06
From what I have seen and read yes, and the oil sold in the U.S actually says European blend or forumula on the container.
Old 11-09-2011, 07:24 PM
jgaches
jgaches's Avatar
FNBADAZ06 posted this link up a while back. Good info.
http://www.mobil.com/usa-english/mot...duct_guide.pdf
Old 11-09-2011, 07:42 PM
track junkie
track junkie's Avatar
I am using Mobil 1 high mileage 5W-30 in my low mileage 2009 Z06.
Old 11-09-2011, 07:46 PM
AzDave47
AzDave47's Avatar
The Mobil 1 5w-30 has lower phosphorous and zinc and makes (theoretically) it easier for the cats to live to their DOT/EPA full life.
Old 11-09-2011, 07:53 PM
mirage2991
mirage2991's Avatar
with the new EPA mendates, 5w30 is used to get better gas milege and also to help with cat efficiency by having less phosphorus content. This is why I would NEVER use 5W30 for anything BUT daily driving...none the less I think I will be going to the 0W40 next time around, just to get that ppm back up where I think it should be.
Old 11-09-2011, 08:10 PM
Mopar Jimmy
St. Jude Donor '06
Great info gentleman, thank you!!
Old 11-09-2011, 08:29 PM
atljar
atljar's Avatar
I run a 50/50 mix of Castrol TWS 10w-60 and Mobil 1 5w-30. Mostly because I get the TWS at an absurdly cheap price through work, but either way oil temps drop about 20º with this mix compared to straight 5w30. I know many say dont mix oils, i ran my C5 the same way HARD up to 140k miles without any issues, its now sold and still going strong.
It was designed to have a good cold flow viscosity and really high sheer. As for the additive pack, if it runs a 15k factory interval for BMW M cars, then must have something working well.
Cold idle pressure is about 65lbs to 95 or so in upper rpm, once above 100-110 degrees, idle is about 55lbs, 70 or 75 lbs in upper rpm
To Anyone using Mobil 1 High Mileage
Old 11-09-2011, 10:14 PM
Gary '09 C6
...yes, thank you all !
Old 11-10-2011, 12:37 AM
1QUICKSSB
1QUICKSSB's Avatar
I used the M1 high milage 5w30 in my goat. It has more additive packs for anti-wear and detergents. It is also a bit thicker than any other 5w30 on the shelf. The UOA that I have seen on BTOG have been good.
Old 11-10-2011, 06:28 PM
VNAMVET
VNAMVET's Avatar
My 35,000 mile 2008 Z06 has used the "original' Mobile 1 5-30 since new.
Mabe that's why I have had to replace 16 lifters and a few thousand miles later, a new camshaft and three more lifters...........?
BTW, a daily driver, never raced or tracked and have only hit the rev limiter once or twice.
On second thought, mabe that's the problem..........
Quick Reply: [Z06] Anyone using Mobil 1 High Mileage
