[Z06] Are we faster then the new CTS V?
#81
Great question!!!! I know the z06 will beat a cts-v in the 1/4 but i would like to know by how much. I have a 2013 427 Convertible and my friend has a 2011 cts-v coupe with auto. 1/4 times are all over the place on the c6 z06, iv seen from 11.3-12.2 most show around 11.7. For the ctsv i see from 12.-12.3. The Z wins unless u miss a shift and can't find the gear on your second try lol. . With that said if the Two cars race from 45mph to 125mph the caddy will get smoked. I think the cts-v is very fast for what it is just not a z06. I Noticed below someone stated the c6 GS and the ctsv is a even or close race in the 1/4, i think the cts-v with beat a base stock c6 in the 1/4 thats my option but could be wrong. Im guessing the z06 will win by 3-4 cars over the cts-v
#82
C5 Z06 Bone-Stock Times
1--11.783 @ 116.90--1.818--J-Rod---------'02
2--11.818 @ 117.26--1.783--Ranger--------'02 11/03 Slip
3--11.844 @ 117.91--1.761--Gary2004Z06-'04 12/07 Post 229, Slip
4--11.93x @ 119.xx--1.xxx --Esoteric-------'0x
5--11.97x @ 118.80--1.90x--GMHTP--------'04 03/04
6--11.99x @ 117.61--1.xxx --02Z06Racer---'02
7--12.048 @ 115.92--1.866--pwrshfd-------'02 12/03
8--12.074 @ 119.18--1.860--02EBzEE------'02 10/11 Post #36
9--12.08x @ 115.95--1.83x--Pray ----------'02 01/06 Slip
10-12.09x @ xxx.xx--1.79x--UVETTA -------'03
12.131 @ 120.65--1.970--zapp109-----'04 03/09 Slip, Post #384
12.205 @ 117.96--1.91x--Nat04Z06 ----'04
12.21x @ 112.xx--1.87x--Blue Angel----'02 07/04
12.227 @ 115.09--2.011--ZR WON -----'01 04/04 Post 6
12.22x @ xxx.xx --1.77x--holedgr-------'02
12.25x @ 117.xx--1.xxx --J Z06 --------'04 05/06
12.27x @ 115.16--1.957--SpeedFreak81-'03 07/07
12.2xx @ 1xx.xx --2.xxx --My1stZ ------'03
The LS2-LS3 cars are about the same. You probably need to have actually raced your car to do low 12s in a C5z tho, where an a/t Caddy just stomps on the gas and does it but power to weight this is a better comparo. I don't think you need to be gifted to do 12.0 in a C6Z so it is easily the faster car but the thing doesn't drive itself. Also if you are on aging runflats like me it isn't the same machine any more.
#83
stop picking on us slow viper drivers.
I had an anti-race with a C6Z06 recently. I am totally disinterested in street racing, as was the Z driver. The Z was in the right lane at the light and had to merge into my lane. I took off in my usual way...slowly. The Z was neck & neck at about 30 mph. I was in 5th gear at 45 and the Z was stll alongside. I slowed enough to allow the Z to merge safely. Must have been very disappointing to all those that were behind and expected more.
#84
I had a 873RWHP single Turbo Cobra (322CI Big Bore/Stroker) a few years back that idled like a stock car and pulled like a freight train, the area under the curve was insane! I could melt my 315 MT Drag Radials on command pretty much on any gear!
#85
Your numbers dont make any sense at all.
Something wrong with the mph you re posting .No one runs low tens at only 103 mph.Thats more in line with a 13.8 second run.
