[Z06] Valve train related premature wear or failures assoc. w/ royal purple oil ?
Just curious.... I seam to have a reoccurring issue that is either Oil or cam related. I'm not quite ready to let the cat of the bag on this until I get some CSi reports back on the parts.
any input from past users of royal purple would be great.
I don't happen to use RP oils because they refuse to specify the HTHS number. This is exactly the number on needs to judge if any particular motor oil is acceptable for track use (i.e. when really hot).
no gauling of related parts that come into contact with this part, so the search is on.
Received 4,553 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Sorry about your issues. To me it is another example of the "boutique" oils that are more hype than substance. There is absolutely nothing wrong with the factory fill Mobil 1 5W 30. Why spend more money and risk problems. I don't like it in trannys or rear ends either.
Good luck with your car
I have always had good luck with RP. I did however switch to all Amsoil fluids in my Hummer. I may switch over to Amsoil in the Z this summer as well and see if I can tell a difference.
Did your motor pop?
Premium Supporting Vendor
AMSOIL Motorcycle Oil “White Paper” (1 MB pdf file)
AMSOIL Gear Lube “White Paper” (2 MB pdf file)
Neither are engine oil (or tranny fluid for the poster above), but I suspect the results would be similar.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
I'm leaning towards Joe Gibbs ( which I use for break in oil), Mobile 1, or Redline. Quite honestly, I figured they were all the same one way or the other. Mobile 1 definately cheaper than RP. I actually thought it was just internet forum blah blah blah....initially.
(Edit: new information) Motor did not pop....Its just fine. Just getting premature wear on valvetrane. I'm waiting for a reply on the parts from the MFG before I share my experiences with everyone. I've talked with the supplier of the heads/cam, my engine builder and the rocker company.
My goal is some evidence based research that others ( including me) can benifit from. I've been the guinea <sp> pig on several aftermarket LS7 products on my past motor and I'm hoping others do not have to go through the same.
I don't want to come off as a finger pointer by jumping to conclusions. I just want a product combination that is reliable for a 80% street 20% track LS7 making 57x/53x at the wheels.That maintenance is a bit too excesive for a hydraulic roller motor IMHO.
when I have more info I'll make a more complete post.
In the meantime I'm riding my titanium IBIS road bike to and from work 26 miles round trip. I needed to work off the beer gut anyhow.
I talked to "Bob the Oil Guy" last year and he said RP was fine in the trans and diff, but he would never recommend it in the motor.
Oil does not seem to be the cause according to the Rocker MFG. I'm having some valve train parts tested on monday while my heads are at the machine shop getting a once over before they go back on.
yes my friends its down to the short block.
Good news is I caught it before anything major happened. magnet on the Peterson oil tank and drysump lines came up clean. Filter caught it all.
I do have one thing to say. I would NEVER do a C6Z cam swap for 50-60 Hp. you people are crazy
Mine had to come out, pic's to follow soon.
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
RP is a little too gimmicky for me. Getting owned by BP in that advertising lawsuit was the nail in the coffin. I wouldn't run RP in my lawnmower.
http://www.imakenews.com/lng/e_article001398592.cfm
U.M.
U.M.
Cheers, Paul.
The Consigliere
Received 5,444 Likes
Sounds like you're definitely approaching this the right way; step by step.
Keep us posted on what you learn.
Sorry to see you have to go thru this. In the end, perhaps we'll all benefit by having more knowledge.
Thats the goal. I stopped pointing fingers a long time ago. My goal is to figure out why things went south and make sure it doesn't happen again. If I can help some fellow CF members out in the process, all the better.
