C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] NEW! 6000k Low Beam Replacement Bulbs **Brighter, Whiter & Cleaner** ON SALE $74.99
Old 05-10-2011, 06:57 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default NEW! 6000k Low Beam Replacement Bulbs **Brighter, Whiter & Cleaner** ON SALE $74.99
We have had countless requests by forum members to source a reasonably priced low beam replacement bulb to update the OEM HID bulbs in their C6's. As many of you notice, the 4300k HID's that are stock in C6's are not far from the yellow tinted appearance of a halogen bulb.
Corvette Mods solution? 100% plug and play replacement bulbs that work off your stock OEM ballasts!
These replacements are rated at 6000k, which is more of a clean white color over the stock 4300k yellow tinted lows. AND they are brighter
You don't need any special skills to perform the swap either!
Price a single OEM replacement at $300 and up and our 6000k replacements are a bargain!
For a limited introductory time we have these marked down from $99.99
ON SALE $74.99
Click here to order:
http://www.corvettemods.com/Corvette...de_p_5597.html
Pair these up with our switchback DRL LED's and HID Fog Light conversion kits for a perfect lighting upgrade
Click this link to go to our Fog HID conversion sale thread!
http://forums.corvetteforum.com/c6-p...77-99-a-3.html
Old 05-10-2011, 09:17 PM
show723
show723's Avatar
This was one of my favorite mods that I did to my Z. The 6000k has the hint of blue, classy yet attention-grabbing, but not overly obnoxious like many of the ricers around. 6000k lows with 4300k fogs, love the look. I'll have pics up here soon. Thanks corvettemods!
Old 05-11-2011, 12:48 PM
0corvettemods1
Former Vendor
Old 05-30-2011, 04:10 PM
MyOwn69
MyOwn69's Avatar
Answer this, please!
I bought the fog HID upgrade from you and you had stated that they were to be "close" to matching the stock low beams.
Well, I LOVE the HID fogs but I don't think the color temp of the fog kit is really that close to the stock lows.
Where do these replacement "lows" fit in on the color temp scale (compared to your fog kit)?
Again, LOVE the fogs - so tell me what's up with this new option.
Thanks!
Old 05-31-2011, 10:53 PM
MyOwn69
MyOwn69's Avatar
Thanks!
An answer, please!
Old 05-31-2011, 11:14 PM
0corvettemods1
Former Vendor
An answer, please!
Sorry for the delay, we've been slammed!
The hid fogs are rated within 200k of your oem lows. The difference in color is due to the difference in lenses (projector lows vs reflective fogs) the addl reflection in the fog housings make them appear more blue. These 6000k lows will offer a brighter, whiter look which will make the fogs appear to match better. I think the stock lows look too yellow to begin with. These upgraded lows look awesome and more modern!
Old 06-08-2011, 08:21 AM
DaOtherOne
DaOtherOne's Avatar
How hard are they to install?
Do you have installation instructions?
Old 06-08-2011, 08:23 AM
0corvettemods1
Former Vendor
An hour tops for installation. There is an access panel in the wheel well to allow you to replace bulbs. We can send instructions if you PM us with your email address.thx
Old 06-30-2011, 06:24 PM
Turbooo2u
Turbooo2u's Avatar
The stock fogs on the Z are really lousy. Are your upgrade fogs much better and are they easy to install? Thanx.
Old 06-30-2011, 07:47 PM
0corvettemods1
Former Vendor
10x better! Install is very straight forward. No cutting or soldering required!
Old 08-28-2011, 10:20 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Are these really brighter than the factory bulbs, Or is it just a color difference? I installed a set a couple of weeks ago, It seems like they are not as bright as the factory bulbs. Any more information on the brightness of the replacement bulbs?
Old 08-28-2011, 10:23 PM
0corvettemods1
Former Vendor
They are slightly brighter. They are also a different color temp. Did you somehow change the height adjustment when you did the install? That may be the reason they appear less bright. I can say that they are not dimmer than stock though.
Old 08-28-2011, 10:33 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
No I did not change the height adjustment, I do think they shine down lower. I really do not thing I should have to change the adjustment with just bulb replacement. Do most have to raise the headlight adjustment with the bulb replacement?
Old 08-28-2011, 10:36 PM
0corvettemods1
Former Vendor
No, I am not recommending any change to the adjustment. Just seeing if its possible they were unintentionally moved off center when the replacements were installed.
Old 10-22-2011, 02:29 PM
DrtyHarry
DrtyHarry's Avatar
Will it be a problem using 6000k bulbs in the fogs? Don't want to have any heating issues...will 6k in the lows and 6k in the fogs be ok?? Same bulb and temp, right? Or is 6k for the fogs too hot? Thanks!
Harry
Old 10-22-2011, 03:42 PM
0corvettemods1
Former Vendor
Harry
No, it won't be a problem. No heating issues at all with 6k, we sell that temp all of the time.
Old 11-04-2011, 04:05 PM
0corvettemods1
Former Vendor
To NEW! 6000k Low Beam Replacement Bulbs **Brighter, Whiter & Cleaner** ON SALE $74.99
Old 11-07-2011, 05:27 PM
Witt748
Witt748's Avatar
This may be my favorite mod that I have bought so far for the $$$, the lights are great. I like them so much I want to check to see if I can get replacement headlight bulbs for my DD
Old 11-07-2011, 05:36 PM
0corvettemods1
Former Vendor
Yes! We can get sets for any car. Send me a pm with your car info and we will get you setup...
Old 11-27-2011, 09:53 AM
chasboland
chasboland's Avatar
These look like they might be a good mod.......on the fence..... Need more reviews. Bueller, Bueller???
Quick Reply: [Z06] NEW! 6000k Low Beam Replacement Bulbs **Brighter, Whiter & Cleaner** ON SALE $74.99
