C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Motor Mount Leak
Old 03-05-2011, 11:33 AM
sshaggie
Cruising
sshaggie's Avatar
Default Motor Mount Leak
Question 1 - Stock C6 Z06 LS7 mounts, 50k miles, is this a common problem? I originally suspected the oil pan gasket problem as the source of my leak, but I the pan looks clean. Drips seem to be coming down from my passenger side motor mount. The leaking fluid is brown and of a similar consistency to motor oil. Does everything add up to a leaky mount?
Question 2 - Assuming the mount is busted, how critical is it that I replace asap? Are there any bad side effects from driving around with a drained mount?
Question 3 - Anyone had any luck with the Hinson mounts? Seems like a good compromise between factory squish and the Pfadt option.
Thanks guys!
Old 03-05-2011, 01:12 PM
ajbarbato15
ajbarbato15's Avatar
Maybe I am wrong, but I dont think there is any fluid of any type inside of your motor mounts...
Old 03-05-2011, 01:18 PM
TRINIC5
TRINIC5's Avatar
LOL
Old 03-05-2011, 01:25 PM
sshaggie
Cruising
sshaggie's Avatar
I didn't think a leak from a motor mount was likely either, but have found a few threads on it... Here is one:
http://forums.corvetteforum.com/c6-z...installed.html
Old 03-05-2011, 01:42 PM
u1arunit
u1arunit's Avatar
Some motor mounts use viscous fluid to dampen vibrations.
Old 03-05-2011, 01:52 PM
frc
frc's Avatar
LS7 engine mounts have fluid in them. It does look like motor oil.
Old 03-05-2011, 02:10 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
There is fluid in the crappy stock mounts.
http://forums.corvetteforum.com/c6-z...or-mounts.html
Old 03-05-2011, 04:17 PM
sshaggie
Cruising
sshaggie's Avatar
Thanks for confirming frc! I guess this is better than an oil pan leak, at least it gives me an excuse to get some better mounts. Now what else to do while I've got the car apart...?
Old 03-26-2011, 09:17 PM
sshaggie
Cruising
sshaggie's Avatar
Following up on this thread. Got the time to change the mounts today. Went with the poly replacements from Hinson.
Here is the culprit!
Busted Mount
Here is stock vs. the new Hinson mount.
Old vs. New
And here are a couple pictures that show what kind of clearances you need to swap the mounts.
Passenger Side
Driver Side
Job took about 5.5 hours from start to finish. Overall feel has slightly more NVH at idle, but very mild. I haven't had the chance to do any hard acceleration yet, but am looking forward to it!
Old 03-27-2011, 12:48 AM
Charley Hoyt
Charley Hoyt's Avatar
I had the same problem. When I called around to get quotes for changing them I found out that they are covered under the 5 year / 100k mile powertrain warranty...that was a pleasant surprise.
Z31/ZO6 GUY (09-05-2021)
Old 03-28-2011, 12:55 PM
frmd808
frmd808's Avatar
Default Hinson Mounts
Please provide some feedback on how you feel about these mounts. I am about to order some new mounts and I want to decide what to go with. I do not want major vibration especially I have a fully build 427. Mild is fine with me.
Old 03-28-2011, 10:43 PM
SilverLS7
Cruising
SilverLS7's Avatar
Default Nice
Nice write up Jeff. Glad we got it knocked out this past weekend.
Old 03-29-2011, 08:38 PM
A-Z
A-Z's Avatar
And???
To Motor Mount Leak
Quick Reply: [Z06] Motor Mount Leak
