C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Front tires wearing faster than rear ones...
Old 09-24-2013, 04:35 AM
2019 ZR1
Support Corvetteforum!
2019 ZR1's Avatar
Default Front tires wearing faster than rear ones...
I have a 2013 Z06 and run it pretty good. It seems like the front tires are wearing faster than the rear. I keep the pressure at 30 on all 4 tires all the time. Anyone else notice this??
Old 09-24-2013, 06:19 AM
PUREVOL
PUREVOL's Avatar
Front tires wear more bc of the weight in the front. I don't spin my tires or do burnouts but I do take corners & exits fast.
Old 09-24-2013, 06:57 AM
Oleman
Oleman's Avatar
Alignment may be set up to help this as well. I changed my 09 to the Pfadt specs and wear much better than with stock settings.
Old 09-24-2013, 07:02 AM
Turbooo2u
Turbooo2u's Avatar
Same here. Fronts wearing before rears.
Old 09-24-2013, 07:36 AM
GOLD72
GOLD72's Avatar
Received 1,105 Likes on 718 Posts
Very typical for all C5 & C6 corvette models and not just the Z cars. Less aggressive alignment specs will help.
Old 09-24-2013, 07:57 AM
JwT
JwT's Avatar
This would be considered normal for any car. Tires are rotated because the effect of turning the car wears the front tires more than the straight running rears. There is no rotation option our big a$$ tires so the fronts wear faster.
Old 09-24-2013, 09:29 AM
VetteVinnie
VetteVinnie's Avatar
Received 1,677 Likes on 1,069 Posts
There is no more weight in the front than there is in the rear. These cars have a 50/50 weight distribution.
Check the alignment and go less aggressive. I run a slightly less aggressive front camber than stock on the streets. I ran my front Nitto Invos for over 20K miles, and they still have good tread on them. I was on my second set of rear Invos when I changed all four to MPSS. I will get it realigned before a track day (with a different set of tires).
Old 09-24-2013, 12:01 PM
Oleman
Oleman's Avatar
With the alignment chnage I will have to get a set of rears before fronts wear out. This was just the opposite before I changed.
Old 09-24-2013, 01:59 PM
2019 ZR1
2019 ZR1's Avatar
Ok, I will try this.. Where is the best place to take it.. I thought about the dealer. I have a buddy that is the head mechanic at the dealer so I think I might be ok with taking it to dealer. Thanks guys!!
Old 09-24-2013, 03:10 PM
keevo54
keevo54's Avatar
I have never had a rwd car where the front tires wear faster than the rears.
Old 09-24-2013, 04:09 PM
u1arunit
u1arunit's Avatar
Were you able to rotate the tires on the other cars?
Old 09-25-2013, 10:01 AM
onargaroberts
onargaroberts's Avatar
I don't know what "run it pretty good" means but if it involves heavy braking into corners and trail braking, then this is not that surprising. The car is well balanced and it's weight evenly distributed while standing still but under heavy braking there is a lot more weight on the front than the back. And if you continue to drag the brakes down to the apex the front tires are both turning and braking while the rear tires are almost along for the ride. If clockwise road courses are involved in "run it pretty good" you'll probably also find that it "seems like" the left front is worn more than the right front.
Old 09-25-2013, 05:24 PM
Captain Buddha
Captain Buddha's Avatar
I melted the fronts pretty good doing road course "work" on my previous '13 Z06...especially the time I didn't wait for a cool-down between sessions...it was worth it though...driving on "greasy" tires builds character and skill...and scares the crap out of your passenger! LOL
Old 09-25-2013, 06:35 PM
keevo54
keevo54's Avatar
no.....just a heavy foot
Old 09-25-2013, 10:33 PM
u1arunit
u1arunit's Avatar
Aaaahhhh...
Old 09-26-2013, 12:43 PM
truckplay
truckplay's Avatar
front tires on vettes always wear faster than rears, unless you drive like me
seems like I get tires every 2nd oil change
Old 10-17-2013, 04:22 PM
z 06 happy
z 06 happy's Avatar
When I first picked up my new 2008 Z06 I spoke to the dealership's alignment mechanic who told me that the factory set standard front alignment spec was set for aggressive driving. I advised the mechanic that I had no plans to drive the car hard. With that he adjusted the alignment specs to be less aggressive in wearing on the outside edges of the front tires. Currently my car has 10,700 miles on the odometer and the front tires show no signs of abnormal wear. Have 5/32s left while the rears have 4/32s. Both the inside and outside edges of the front tires show no sign of wear.
To Front tires wearing faster than rear ones...
Old 10-17-2013, 04:30 PM
GMuffley
GMuffley's Avatar
Use the Pfadt street alignment specs rather than the factory settings.
Old 10-17-2013, 05:19 PM
1Sikstik
1Sikstik's Avatar
My fronts wear on the very inside corners. My rears also wear on the inside more and I just replaced them because of this problem. Was told this is normal wear for my car from the local dealer and a reputable tire shop. My LS3 narrow bodied vette never wore tires like this. Not satisfied that I have to live with this.
Old 10-17-2013, 05:27 PM
jimman
jimman's Avatar
I set mine to zero camber to prevent the inside wear. Two things cause changes in this, suspension sags with time, increasing negative camber and most alignment shops I don't believe ever heard of the work calibration.
Quick Reply: [Z06] Front tires wearing faster than rear ones...
