Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-13-2011, 12:17 PM   #1
RobVette
CF Senior Member
RobVette's Avatar
Send a message via MSN to RobVette
Default Problems w/Check Engine Light & Traction Control System
Problem has been solved!!!!!
While driving yesterday; the check engine light started blinking and service traction system was displayed on the DIC. I did adjust my driving after these lights came on. After sitting overnight, same problems. Car info: 2009 Z06; M2W, Oil Remaining 47% and odometer reads 3000 miles.
Any suggestions other than maintenance service? Maybe 02 Sensor from bad gas? (prior to the trip, I did fill up w/gas)
RobVette is offline   Reply With Quote
Old 03-13-2011, 12:39 PM   #2
My07C6
CF Senior Member
My07C6's Avatar
If your onstar is working have them run a diagnostic scan.
Otherwise you can go to advance auto or many other parts stores and they will scan your car for free.
My07C6 is offline   Reply With Quote
Old 03-13-2011, 01:35 PM   #3
Jasil
CF Senior Member
Jasil's Avatar
Mine does that pretty often but only at a stop and never when I'm driving.....go figure. The minute I start moving it goes off again.
Jasil is offline   Reply With Quote
Old 03-13-2011, 03:45 PM   #4
RobVette
CF Senior Member
RobVette's Avatar
I'm in Germany so the on star is not active.
Old 03-13-2011, 03:51 PM   #5
Bill Dearborn
Bill Dearborn's Avatar
The reason the TC message shows up is there is a problem that is preventing the ECM from doing its part of the traction control function. Just a run of the mill emission system issue wouldn't do that. That probably means your problem is in the throttle control area. Some of those issues will also throw the car into limp home mode as well. You will need to get somebody to read the codes but a cheap scanner should be able to read the ones that concern you.
Bill
Bill Dearborn is offline   Reply With Quote
Old 03-13-2011, 09:42 PM   #6
TheKomoman
CF Senior Member
St Jude Donor '13
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Check your batt & alternator. Those kinds of warnings are what the car will start throwing when the battery is low on charge. These cars are hard on batteries.
TheKomoman is offline   Reply With Quote
Old 03-14-2011, 12:18 AM   #7
twinger01
CF Senior Member
twinger01's Avatar
Also check ur gas cap cuz that could b ur check engine light.
twinger01 is offline   Reply With Quote
Old 03-14-2011, 01:22 AM   #8
Bill Dearborn
Quote:
That will definitely cause a code to be set and the check engine light to light but it will not generate a Service TC message. There are only a certain number of OBDII codes that will also generate a Service TC message. He needs to focus on the failure not on non failures.
Bill
Old 03-14-2011, 10:25 AM   #9
JoesC5
CF Senior Member
Quote:
Bill
Sometimes, things that do not seem to relate can cause codes to be thrown. When I installed a Vette-Air scoop and the Attack Blue air filter my car DIC would say "service traction control" and "service active handling". Sometimes it would cause the CEL to come on. All it was, was that the MAF was receiving turbulent air. After I removed the Attack Blue filter and made a diffuser for the Vette-Air, the problem was resolved. Plenty of posts on problems when people went with aftermarket air breathers.
JoesC5 is online now   Reply With Quote
Old 03-14-2011, 04:01 PM   #10
RobVette
CF Senior Member
RobVette's Avatar
After a short drive tonight; I heard a clicking sound so I removed the plastic valve cover and noticed one spark plug cable OFF. Plug in the cable then went for a drive; now both (engine light & traction control) lights are off. And it's running & driving like a Z. Yesterday my co-polit said he heard a clicking sound but when I checked; it had stopped.
Thanks everyone for responding; this forum is awesome.
Old 03-14-2011, 07:03 PM   #11
RobVette
CF Senior Member
RobVette's Avatar
What would we do without GM warning lights and CF members.
Old 03-15-2011, 12:34 AM   #12
Bill Dearborn
A misfire will definitely set the Service TC message.
Bill
Old 03-15-2011, 02:17 AM   #13
RobVette
CF Senior Member
RobVette's Avatar
Bill, since you mentioned it; i believed a misfire did occur before those lights came on. Then we started reading the manual and forgotten about the misfire!
Old 06-14-2011, 02:07 PM   #14
blackjet
Junior Member
Drove 15 miles to work this am, everything ok, hop in at noon to go for lunch, running on 7cylinders, ticking on left side, "service traction control" message and CEL light on and all plug wires looked ok. Got on CF, did a search, found this thread, took cover off and found the problem: plug wire off coil pack! Problem solved, thanks to CF. 2010 Z 8800 miles.
blackjet is offline   Reply With Quote
Old 06-22-2011, 01:20 AM   #15
want2buy
Junior Member
want2buy's Avatar
Default C6/05 DIC problem
On our 05, the DIC is nothing but a bunch of dots and daskes. Does any body have any ideas on what might be the problem or how to correct it? I tried to disconnect the battery and see if it would reset but after about 1/2 hour, re-connected the battery and nothing changed. Never lost power to clock or any memory setting. Any ideas or suggestions would be appreciated.
want2buy is offline   Reply With Quote
Old 06-23-2011, 09:09 AM   #16
Chevy Cust Svc
CF Senior Member
Chevy Cust Svc's Avatar
When was the last time you replaced your battery? Sometimes it takes more than just disconnecting it.
Thanks,
Laura
GM Customer Service
Chevy Cust Svc is online now   Reply With Quote
Old 04-19-2013, 05:21 PM   #17
jayvee01
Junior Member
Default Fuel Gauge & Engine Maint light
Filled up with gas. Got in car and 'service fuel system' msg came on. Turned off engine, and checked filler cap was snug. Got home and
looked on the Vette forum and promptly purchased container of Chevron Techron additive.
Let set over night. Next day while driving to work the fuel gauge popped back and forth several times and end up on 'full' - where it should be. Engine service light is still lit. How do I reset this light?
Thanks a lot and thanks for all the previous info.
jayvee01 is offline   Reply With Quote
Old 04-28-2013, 06:17 PM   #18
talionstallion21
CF Senior Member
talionstallion21's Avatar
This happened to me today. Started my 08 and it was idling very rough and the exhaust smelled funny. Service traction control and CEL came on, so parked it. Went on here and found "check your spark plug cables". One was off the the coil pack. Started it up and ran much better and no smell from exhaust but CEL is still on. Does this take awhile to reset??
Thanks to the forum for good data base of info.
talionstallion21 is offline   Reply With Quote
Old 06-23-2013, 05:50 PM   #19
CliffB-99
CF Senior Member
CliffB-99's Avatar
Quote:
Same thing happened to me today. Service Traction Control & Service Active Handling messages came up and engine sounded like crap. Plug wire off the coil pack .
I really don't want this to happen again when I go to Vettes on the Rockies next month. Should I replace the plug wire that slipped off? How do you keep them from coming off?
CliffB-99 is offline   Reply With Quote
Old 12-12-2013, 02:21 PM   #20
Dallasb84
CF Member
Same thing just happened to me. Service traction light was blinking and I checked my plug wires. Bam! Lights still on though.
Dallasb84 is offline   Reply With Quote
Reload this Page Problems w/Check Engine Light & Traction Control System
Tags
1980, c6, check, chevrolet, control, corvett, corvette, engine, fbody, light, problems, service, system, traction, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas Pedal problem Andrew6@TheDoubleAA C6 Corvette General Discussion 13 09-29-2013 05:36 PM
Service Traction Control Yellow 2000 C6 Corvette General Discussion 9 07-31-2013 03:00 PM
Traction Control corvettejack C6 Corvette General Discussion 4 06-11-2013 10:06 AM
Traction control corvettejack C6 Scan & Tune 0 05-31-2013 08:07 PM
ABS light and service traction control AC62NV C6 Corvette General Discussion 6 05-30-2013 01:52 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
