C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] whats a good range for the air fuel ratio
Old 03-02-2011, 11:32 PM
jtearp
jtearp's Avatar
Default whats a good range for the air fuel ratio
What is an acceptable range for the air fuel ratio?
Old 03-03-2011, 12:18 AM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
I assume your talking at WOT? What is the engine set up and what type of fuel?
Old 03-03-2011, 12:22 AM
jtearp
jtearp's Avatar
Frans96ss - yes I mean at WOT. Stock bottom end with the following:
cam - 248/260 .658/.660 114
ported heads
fast 102 intake
ported throttle body
1 7/8 long tubes with high flow cats
Old 03-03-2011, 12:26 AM
nspec
nspec's Avatar
i think its suppose to be 12.1 WOT and 14.9 Idle
Old 03-03-2011, 07:54 AM
KLLRVET
KLLRVET's Avatar
generally at wot a good a/f is 12.9-13.1. From what I seen, the LS7 seems to like 12.5-12.6
Old 03-03-2011, 10:53 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
12.2-12.8. Some cars like it richer, some leaner. Mine is dialed in around 12.6.
Old 03-03-2011, 11:05 AM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
ported heads
fast 102 intake
I prefer to keep the LS7 stuff around 12.5
Old 03-03-2011, 11:06 AM
1.8t
1.8t's Avatar
Also depends on where you are measuring the a/f at. If measuring from a w/b 02 bung in the header, I always shoot for ~12.5ish. I do favor conservatism in my tuning though.
To whats a good range for the air fuel ratio
Quick Reply: [Z06] whats a good range for the air fuel ratio
