C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] TR6060 vs T56
Old 02-14-2011, 03:06 AM
rattt g
rattt g's Avatar
Originally Posted by JJC5
That's the first time I've heard that. The clutch packs in a limited slip differential are there to make it a "limited slip."
we just took apart an 08 rear that broke at the track, and we found out that there was no clutch pack in there just the spider gears, come to find out only the t56 cars have the clutch pack rears
Old 02-14-2011, 08:29 AM
3LZZ06
_"SCOTT"_
Support Corvetteforum!
3LZZ06's Avatar
Hmmm...
This is news to me as well, I thought I had heard of some early 08's having the clunking in the rear due to the clutch packs and the updated rear lube cured the problem.
I could be mistaken though...
Old 02-14-2011, 08:32 AM
PhysiPhile
PhysiPhile's Avatar
If there isn't a huge difference, then why did GM make the change? Why not just wait till the next generation. Changing transmissions gives the perception that the old one's were flawed.
Old 02-14-2011, 08:38 AM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
I believe the development of the new TR6060 was for the upcoming ZR1 which was in need of a more robust transmission. The whole Corvette line just happened to be recipients of the update.
Old 02-14-2011, 09:33 AM
Burnin4
Burnin4's Avatar
Ive owned an 06 and an 08....I wont own another pre 08 Z, mosty for the total package not because of the t56.
Old 02-14-2011, 10:53 AM
Rock36
Rock36's Avatar
Well one major reason for the change is the sheer volume of new cars that have a TR-6060 in them already. This volume alone would dictate the corvette make the transition to a TR-6060.
TR-6060 can be found in:
2007+ Mustang Shelby GT500
2009+ Dodge Challengers
2009 Pontiac G8
2009+ CTS-V
2010+ Camaro SS
2008-2010 Dodge Vipers
and probably a few others...
The TR-6060 is a better transmission, no arguement, just not THAT much better. And it certainly doesn't mean the T-56 is crap or prone to failure. It is just an updated new transmission. It isn't like the T-56s are falling apart.
If my sources are correct. The TR-6060 is rated for 600 ft-lbs, and the T56 is rated to 550 ft-lbs. Both substantially strong enough to handle stock and modified Z06s. Other differences or improvements over the T56 are:
- Reduced friction in the shifter system courtesy of a new cam and anti-friction plunger to control the side load shift detents.
- Forward and rearward shift detent grooves are broached on the front of the main-shaft with a spring-loaded anti-friction roller, for more precise control of shift detents and positive shift feel.
- Anti-friction ball struts, sintered hubs and fine-pitch splines on all synchronisers for reduced friction between components - delivering improved shift feel and reduced shift efforts.
- Wider, two piece gears with machined clutch teeth for more precise gear engagement and reduced potential for gear block-outs."
Again, based on the OPs question. He decided that his budgets fits getting a 2007, and there is no reason IMHO that the T56 should be a deal breaker if a 2007 fits his budget. The T56 is still a good transmission, it just isn't the newest transmission.
FWIW, and someone correct me if I am wrong, but the TR-6060 is some 40lbs or so heavier than a T56.
Old 02-14-2011, 12:02 PM
0TJ@RPMtransmissions
Former Vendor
TJ@RPMtransmissions's Avatar
06 Z06 differentials have "spider gears" and bronze clutches
07 up Z06 differentials have "spider gears" and carbon cluthes
09 and up Z06 differentials have the cooler pickup fitting in a new location
those are all the differences...
if you took a differential apart and it had a "torque biasing" differential, which is what I believe you are trying to say, it was installed aftermarket.
Old 02-14-2011, 01:08 PM
160KTS
160KTS's Avatar
2009 Pontiac G8
2009+ CTS-V
2010+ Camaro SS
Your information is great, finally someone who gets it. You shouldn't be afraid of having a T56. I'm going to throw a cam in my already 500whp Z and quite literally the transmission (and engine) are the last things I am worried about breaking. And of course there are slightly different parts than the T56 from your 98 Fbody or your SVT Cobra.
And yes, I do believe they are physically heavier too.
Old 02-14-2011, 01:29 PM
MTIRC6Z
MTIRC6Z's Avatar
Would the ZR1 differential have the same carbon clutches as the Z06?
Which pieces in the ZR1 are billet vs. the forged pieces in the Z06?
Lastly, when you do your L-5 treatment on a ZR1 differential, do you change the clutches?
Oh, and that "cooler pick-up fitting in a new location" sure makes it PITA to put a ZR1 differential in an '08 or earlier Z06, particularly when you don't notice the difference until you go to slam everything back together
Cheers, Paul.
Old 02-14-2011, 04:20 PM
NORTY
NORTY's Avatar
Originally Posted by soroZ
Yea actually I'm having the same dilemma in regard to buying my z06, but I decided that the car is going to be all performance so I'm going for an 06 which is less quiet on the inside but also lighter weight which is what i really want, not to mention cheaper. I've already decided that i'll have to rebuild the t-56 pretty soon down the road.
Another question I'm planning on tuning my z06 for a 100 shot as soon as I get it, how far will it be before the tranny goes? cause I know nitrous gives the tranny a lot of torque to deal with.
the T-56 should handle your car w/100 shot easily. You might take a look @ your clutch setup however...
Old 02-14-2011, 04:24 PM
NORTY
NORTY's Avatar
1st gear in either car will be tall, that is just the way it is in the Z06. It is pretty cool getting to 60mph in first gear.
Liter bike riders laugh at this... (They do 100+ in first...)
Old 02-14-2011, 04:30 PM
Former Vendor
Cheers, Paul.
The ZR1 has the same carbon clutches
They have different part number springs
The aluminum and steel parts of the center rotator are billet
The spider gears are 4340
we use the ZR1 clutches in the stage 3 ZR1 differential builds
The ZR1 pinion support is stronger as well
Old 02-14-2011, 05:19 PM
  #33
TAILWAG
TAILWAG's Avatar
I have owned an 06 and 08...I have had problems with both transmissions, however, I prefer the feel of the 08.
Old 02-14-2011, 05:22 PM
  #34
soroZ
soroZ's Avatar
so stock the z06 has low 400ft lbs of torque and the tranny is rated to only handle 550? so with a 100 shot and some boltons and maybe a cam I would have to replace the trans????????
Also is the differential different in the various years? if so is it that big of an improvment.
Old 02-14-2011, 09:04 PM
  #35
FastestBusaAround
FastestBusaAround's Avatar
Ya, but we can rev 'em to 14K and need to hit 100+ in 1st - my '05 ZX10R used to do almost 109 in 1st (NOT GPS verified) --
Old 02-14-2011, 09:12 PM
  #36
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
This is the description of the diff in the 08 models. I got it from the Service Manual.
Getrag Differential
The vehicle is powered by either the LS3 or LS7 V8 engine. Motion is transferred from the engine crankshaft/flywheel through the driveline support, propeller shaft, assembly to either the 6L80-E (MYC) automatic transmission or the Tremec 6-speed manual transmission. The splined output shaft of the transmission drives the pinion, which in turn, rotates the ring gear and differential case assembly. The limited slip differential distributes torque/power to the rear wheels via individual axle shaft assemblies. The limited-slip differential is of a conventional separator plate and friction disc type design.
The differential housing, side covers, pinion housing, and differential case halves are constructed of cast aluminum. The internal components incorporate a hypoid gear set, ring and pinion, carrier assembly, and pinion housing assembly. The pinion is supported in a pinion housing by tapered roller bearings. The pinion is positioned rearward of the ring gear centerline.
Pinion position, ring gear position, and carrier bearing preload are determined by shimming procedures.
Each ring gear has specific setup dimensions, A1 and A2 values, stamped onto the side area of the gear. The A1 and A2 values are unique to each ring gear/pinion and are determined during the manufacturers gear/pinion noise and vibration setup and testing. The vehicle speed sensor, in manual transmission applications, detect the rotational pulses produced by the ring gear teeth and send the signal to the vehicle control module (VCM).
The differential assembly is available in 2 gear ratios. The 3.42 ratio axle is used in all manual transmission applications. The 2.56 ratio axle is standard equipment for automatic applications.
Some models have a differential lubricant pump and cooler. Oil is pulled from the sump through an external oil pipe into the pump. Oil is pumped through an external oil pipe to the cooler. The oil is cooled by dissipating heat with transmission oil returning from radiator mounted cooler.
The illustration that goes with this description clearly shows the clutch packs.
Bill
Old 02-14-2011, 09:37 PM
  #37
rattt g
rattt g's Avatar
Getrag Differential
Bill
do you have the link to that illustration? the rear we took apart
had no clutches, and the shop that is fixing it said 08 and up
are not the same as 06-07
To TR6060 vs T56
Old 02-14-2011, 10:23 PM
  #38
160KTS
160KTS's Avatar
No, you don't have to replace your transmission. I personally know cars well over the horsepower range (and weight) on a stock t-56. Your clutch will take a poop long before your transmission even considers it. I am going to put in a cam, in addition to my bolt-ons, and maybe spray. But I also run slicks at the track which woudl cause way more stress. Again, I'm not worried about the trans, I'm worried about the clutch. You should be too. Trans = no breaking. Don't think about if you havea t56 or a tr6060 just remember regardless of which one you have, you have one of the best transmissions built. they will handle whatever you want to throw at them.
Old 02-14-2011, 11:12 PM
  #39
BADZ
BADZ's Avatar
With my power, my t56 is holding 850+ rwhp and about the same amount of tq.
No problems at all.
Old 02-18-2011, 07:46 PM
  #40
Autobahn93
Autobahn93's Avatar
It is probably not a fair comparison but I have just up-graded my T56 to a TR6060 Level 6 from RPM (Thank you Jeremy for the great support and advice) and all I can say is "WHAT A HUGE DIFFERENCE"
It shifts so much smoother and faster than my old T56. I mean I never really had an issues with the T56 but now the shifting is noticeaby shorter and much more acurate. Also no more problems getting the rear gear in when backing out of my garage
PS: I also got the special gearing 5th (.8) and 6th (.63) and I really like it. As I just got my car back today I will report more when I have put some more miles on it.
I love this new transmission!
STANG KILLA SS (09-13-2016)
Quick Reply: [Z06] TR6060 vs T56
