[Z06] Z06 OEM and Aftermarket Parts Weight List
#321
again i'm new to this system and to be honest, not really in any other forums expect this one, so still not sure what the layout is
#322
Oh ok. I am still new to the forum and how it works. What I suggested was copied and pasted directly from your very first post in this thread with adding my numbers to it. I had thought you could go and edit your first post accordingly with the new numbers and don't quite understand when you say new sub category as my suggestion was C&P'd directly from yours then "edited". I haven't gone through every page, but I am now guessing there are updated versions throughout the thread? or do/can you simply edit the first list. That's the one every "new" veiwer will see first and I assume would be easier to find.
The original list as it appears in Post # 1 has been implemented by means of an Excell Spread Sheet.
See Post # 267 and beyond for details.
#323
Aha, I got it!
#324
oh totally understand now. I probably gave you stuff you already had by then lol. That excel sheet is awesome and the pics are very helpful. noticed a few seats and this will def help me choose the ones for me . I will download it again when i get home instead of my job's PC and take a really good look at all sections. really well done
The idea behind this list came from blaine123, who hasn't been active on the forum since September 20, 2011. His last visitor message was 'Yeah I'm still in Iraq ...', back in 2010. So who knows what has happened to him. Let's hope that he's safe, but at times I'm fearing the worst ..
Anyway, over time the updates became scattered all over the place indeed, keeping a good oversight had become an issue.
A couple of months ago I volunteered to take over from the OP, without any intentions to highjack this thread. No one else but the OP can update post # 1, including me. Only the originator of a post can update his/her own post, nobody else can. And with just, of course.
Your initial confusion is quite understandable. For that reason I will, from now on, include a link to the weight list every time that it is updated.
Like I suggested, I finally decided to add your "Kooks X-pipe w/o cats" to the Remark field of the "Kooks 1 7/8" long tubes w/ cats" cell. It's not that buying an X-pipe alone wouldn't make sense, but I believe that that won't happen too often either.
Link: Z06 OEM and Aftermarket Parts Weight List
#326
Supporting Vendor
St. Jude Donor '09
Braille GU1R: 6.6lbs (Halltech Race Unit)
Braille ML30C 9.3lbs (Used by Corvette Racing in the C7.R-Halltech street unit.
Braille 340R 9.1lbs
Braille 340R 9.1lbs
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
#327
The parts that are listed in Post # 326 and Post # 327 have been added.
Thanks for the contributions, guys.
Note - Surprising that these seem to be a tad heavier than the CCW Corsair C10 18"x13". The listed weight - 23.4 lbs - was copied [into the spread sheet] earlier, from Post #1, and I have not been able to trace its accurary.
The Braille 340R and the Braille ML30C were added previously already.
________________________________________ _________
Then, there was a PM that I received from Larry (aka 8850) last week.
Below is an excerpt of our conversation:
Hi Ron,
I weighed my front and rear sway bars. Front with factory bushings, no end links, weighs right at 10.7#. Rear with only factory bushings 6.7#. Not sure how the weights got up to 32# with end links but maybe they do weight that much. Not sure I'm helping but that's what my scale says. Larry
My reply:
Hi Larry,
Your question/remark makes sense.
I have tried to sort it out and it appears to be a little complicated. The complicating factor that I observe every now and then (in the original list by post # 1, plus subsequent updates via later posts), is WHAT exactly has been weighed and by whom. Because I was in doubt myself about the sway bar weight as shown in the spread sheet, I had added the link to the source of information in the form of remark: Post # 22 in the Comment column, meaning that what was sourced by Post # 22 need not be 100% accurate per se.
Of course I trust the numbers that you have mentioned here for 100%, so that's not the issue.
Do you mind if I copy/paste your PM to the "Weight List" thread and try to elaborate on it there? This way other forum members may be able to chime in.
Best regards,
Ronald
Reply by Larry:
Sure, go ahead and use what ever info you need or would like to post.
Keep in mind that I don't have a calibrated scale. I do have two scales that measure fairly close to each other. A digital bathroom scale that I used to hold the front bar in my hand and do the subtraction without the bar. Both were fairly close as I took the average. My other scale has some hysteresis in it so it varies somewhat from one weighing to the next but again I feel close as it compares to other items I've weighed and compared.
Really appreciate all the time and effort you are putting into keeping this spread sheet up to date for us. Larry
Larry, your contribution still has my attention. I watched long periods of the 12H of Sebring last weekend (via live streaming, www.imsa.com) and I was too tired too busy with other things to sort this out. Don't despair however, I will come back to your topic later!
Hi Ron,
My reply:
Hi Larry,
Best regards,
Ronald
Reply by Larry:
#329
#330
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I certainly wish you only good luck with the cam swap, but if you do have the opportunity in the future to weigh the cradle I would greatly appreciate it.
#331
I asked a vendor on a well known auction site about the weight of the C5 cradle he was selling. He was kind enough to answer me, quoting the weight as 44 pounds. I can't vouch for the accuracy of his scale, but if that piece is that stinking heavy then it makes sense why Chevy went to the expense of making the later C6Z part in magnesium.
#332
Source: Hydro Wins Automotive Award for Magnesium Engine Cradle for Corvette
#333
Updates after March 18, 2014 - Z06 OEM and Aftermarket Parts Weight List
Still pending - Post # 328 and related work.
#334
The magnesium engine cradle of the Z06 weighs 23.92 lbs / 10.85 kg.
#335
I recently purchased some Weld RT-S wheels and race tires.... here is what the scale told me:
17 x 4.7 front skinnie forged Weld Wheel RT-S = 15.4 lbs
17 x 11 rear forged Weld Wheel RT-S = 21.4 lbs
In the below link is the exact design wheel that is being referred to above.
http://weldracing.com/17-in-s71-5x4-75.html#2
For tires, on the rear I have:
MT ET Street bias-ply 26 x 11.5 x 17LT tire = 23 lbs each
The below link shows this exact tire:
https://www.mickeythompsontires.com/...?item=ETStreet
For the Front skinnie tire, I am utilizing the fairly new:
M&H 185/55R17 radial front skinnie tire = 17.8 lbs
The below link shows this tire:
http://www.mandhtires.com/M-H-Drag-R...T#.U1kuKk1OXIU
For a bonus weight.... I weighed my current C5 Z06 front wheel with the ET Streets mounted and the combined weight was 42.2 lbs
Therefore, based upon the above:
My front wheel/tire combination will weigh: 33.2 lbs
(Stock OEM is approximately 50lbs I believe)
My rear wheel/tire combination will weigh: 44.4 lbs
(Stock OEM is approximately 62 lbs I believe)
Therefore, this combination versus stock is reducing approximately 70lbs of driven rotational weight..... I will tell you, based upon experience, this equates to over a tenth in et and even as much as 2 tenths and 2 mph improvements.
Note: Going with a bias ply tire instead of the radial would have given me approximately 5lbs off per wheel off the front combination I believe, give or take a little.
I will say, these Weld RT-S wheels are really well built and sexy as all hell. (But, unfortunately, not cheap either....)
Hope this helps somebody in some small way in making their wheel/tire combo decision.
Edit:
A change I have done, is that I am now running the Hoosier 315/35-17 Drag Radial.... the weight of this is 25 lbs exactly on my scale. Hence, my above rear weight has gone up 2 lbs per wheel/tire on the rear.
(One other note, this was a bathroom scale I used.... I have no idea how accurate it is, but I assume within a lb or two. I hope. )
Edit:
#336
Edit:
Edit:
I have used the following link for the Hoosier Drag Radials: www.hoosiertire.com/specdrag.htm
#338
#339
Yet, a few new updates have been incorporated earlier this week:
- Lindgren Supercars tunnel plate
- SKF wheel hub & bearing assembly
- Burns Stainless MhB exhaust, 4.5" and 6.25"
Furthermore, I have incorporated a pdf document in the spreadsheet titled "2006 Corvette Vehicle Dismantling Manual".
This manual contains weight specifications of many OEM parts, so rather than copying all the specs, which is a tedious and error prone chore, I have decided to do it this way.
You can find the icon of the manual in the first worksheet. Double click it and Acrobat Reader will open it for you.
Last but not least, because I cannot always verify the source of information that is posted in this thread and because I am a curious person by nature myself, I have purchased a professional and calibrated weighing scale recently! It's a KERN IFS 30K0.2DL and it can weigh parts up to 35 kilograms. See the attached image.
Spreadsheet link: Z06 OEM and Aftermarket Parts Weight List
