[Z06] Anyone heard the 2011 Z06 Exhaust?
#41
I need to throw my car on a dyno soon...previous owner claimed 572rwhp. With the bullets on my car it seemed I had less torque down low. Who knows! I want to get the burns system for lightweight but I love my snap crackle pop
#43
I know this thread was resurrected, but I just swapped out my 09 exhaust for the 2011 exhaust. It sounds much more exotic, and throaty.
Sort of - In 2011 they changed to an x-pipe and ZR1 style (similar to muffler mod) mufflers. Although the ZR1 and Z06 mufflers have different part numbers
In 2012 they added two additional cats so the crossover pipe is different in length.
#44
So, to make my 2007 sound like a 2011, I should replace the H pipe with an X pipe and modify the bi-mode mufflers to have no perforations on the loud pipe and to have perforations on the quiet pipes?
#46
There were 904 Z06's made in 2011. Those mufflers are going to be hard to come by.
#49
I opted to buy a set of 2011 Z06 mufflers rather than modify my 2007 Z06 mufflers. I will swap them after I complete my adjustable exhaust activation RPM project, hopefully before Carlisle (would it be a good idea to have it done there?), and will try to make a before/after video.
Written in marker: L.G.P. 10-27-10
left stamping: GM 82006362 TA 2300
right stamping: GM 82006380 TA 2600
#50
I had the 2011 mufflers installed during Corvettes at Carlisle today (just the mufflers; the H-pipe was not replaced with an X-pipe). Below is a video of sound clips I took before and after, inside and outside, on the same stretch of road, shifting well below redline but high enough to be representative. The difference is more subtle in the recording than it is in person, but this is the best I can manage with my Canon SX30. With the 2011 mufflers, the exhaust note has more tone, in a musical sort of way; it really sings. In open mode, the 2011 is considerably louder and, unlike the 2007, does exhibit drone above 2000 RPM. In quiet mode with the flaps held partially open by the same amount, the 2011 sounds much better than the 2007, so I changed my activation setting from 2000 RPM to 2500 RPM. I'm really pleased!
0:00 - 0:13 = 2007 mufflers with flaps open (outside)
0:14 - 0:27 = 2007 mufflers with flaps open (outside)
0:28 - 0:37 = 2007 mufflers with flaps open (outside)
0:38 - 0:50 = 2007 mufflers with flaps open (inside)
0:51 - 1:03 = 2011 mufflers with flaps closed until 2500 RPM (outside)
1:04 - 1:17 = 2011 mufflers with flaps open (outside)
1:18 - 1:36 = 2011 mufflers with flaps closed until 2500 RPM (inside)
1:32 = drone magically vanishes when flaps close (to partially open) despite same throttle input
I found a few 2.5" but no 3" X-pipe take-offs in Installation Alley, so I ordered an X-pipe section to convert my H pipe and will update the video when I have that installed unless it sounds just like this, in which case I may not bother:
Last edited by bjmsam; 08-25-2014 at 05:00 AM. Reason: added video times since description not visible when embedded
#51
I swapped out my 2009 H pipe and mufflers with the newer X pipe and mufflers.
Knowing how they sound now, I wish I would have kept the H pipe with the newer mufflers. I think it would sound much more aggressive.
#53
2011 is much different
If you do some searching on this subject you will find alot of posts related to it.
Here are the differences.
Please do not argue or dispute as please, please trust me.
It has been documented.
Just do the search.
2011 and newer X pipe
2011 was only year with only 2 cats
2011 has more HP and torque stock from factory than any other C6 Z06
2012 and 2013 have 4 cats
2011 sounds very much like the C6R with a very nice "burble" and popping on downshifts.
It sounds great.
Sorry if I made anyone mad.
Just do the search.
It sounds great.
#54
Thanks for sharing your opinion based on first-hand experience! It sounds very, very good as currently configured with the 2011 mufflers and the 2007 H-pipe so I am admittedly on the fence about proceeding with the X-pipe conversion.
#56
Your observation that modified early mufflers drone less than 2011 mufflers is interesting and unexpected considering none of the internal pipes are perforated to take advantage of the baffling (it could have more to do with the length of the internal piping, which may function as a partial-wavelength resonator). With the valves open, the drone seemed to me exactly the same below 2000 RPM after replacing unmodified 2007 mufflers with 2011 mufflers. I still have the 2007 H-pipe, so perhaps the X-pipe makes things worse in that regard. As I mentioned earlier, with the valves held open, the 2011 mufflers do exhibit drone above 2000 RPM where the unmodified 2007 mufflers did not at all, so certainly "more" by that definition. In closed mode with the valves held partially open to allow a bit of volume and tone, the 2011 mufflers sound to me significantly better than the 2007 mufflers; neither exhibit any drone whatsoever, and both sound better than either with the valves fully closed.
#57
Hey man, when you are right you are right...I am with you on this and Hib Halverson proved it with the conversion he did on his 2012. Bottom line is 2011 exhaust is the best and adds more HP; undisputable.
Just do the search.
It sounds great.
Just do the search.
It sounds great.
#58
You already stated that in post 40 of this very thread. Who is arguing or disputing anything?
Its good that Hib used the factory x pipe and its got me looking at the Corsa x pipe but I'm not sure if their #14173 is equivalent to the 2011 item or not, in spite of the fact they list the part for 2006-2001 inclusive. Hopefully the information is out there already and I just have to dig it up.
#59
I'd just like to point out that, while I like extra power as much as the next guy, this thread is titled, "Anyone heard the 2011 Z06 Exhaust?," not, "Anyone dyno'd the 2011 Z06 Exhaust?"
#60
But I am really enjoying how it sounds with the H-pipe and am concerned about Erick's comment regarding the X-pipe so may hold off for a while.
I have not seen any threads discussing early mufflers with an X-pipe (I would like to hear that combo!) but suspect an H-pipe after two cats would make more power than an X-pipe after four cats.
