[Z06] What is it with the #7 cylinder?
Just had a friend lose his LS7 to a cracked piston that ended up putting a hole in the block. It's a 2008 with an LPE 630 package. Shop told him that the #7 runs lean on these. Fact or fiction?
Stock valves, BTW, and no sign of valve failure. My guess is detonation.
Elaborate please.
Received 8,926 Likes
#7 running lean is an inherent problem with all LS motors and not because of the fuel system it is mainly because of the intake design #7 gets more air Vince so that will cause it to run lean also. And people that get matched sets of injectors are advised to stick the higher flowing ones in the number seven and eight positions etc...
It is possible, the PCM does control fueling to both banks individually. But it can't (not during normal closed or open loop operation) trim fuel to individual cylinders. If the o2 sensors sees rich or lean conditions for say the left bank, it will trim the fueling as it sees it. So each cylinder on that bank gets less or more fuel based on the o2 sensor in that bank. So if say number seven has a air flow imbalance, and if the o2 reports a rich condition, and the PCM reduces fueling to that bank, it is possible that it can be a bit lean. However this would only be during closed loop operation, in PE fueling during > than X throttle position, the PCM fuels based on a PE mulitplier. A stock Z with stock engine calibration is inherently rich. If a "tuner" reduces PE fueling there again number 7 "could" go lean if conditions are right. I personally have not seen any issues in my shop. Detonation is more than likely the culprit that caused the problem, that is where I would put my money.
This is a problem that has been apparent since the ls1 intake was introduced and those are also port injected. If you wish, jump on tech and search for cylinder 7 lean threads.
Nothing new and something tuners have been dealing with for years now.
Also, if you search some of the threads here about engine failure you will also notice a trend about which cylinders tend to go first. There is something there to look into.
slapping those stock hollow things with .688 worth of lift would not be a good combo ..thats why I went Delwest Ti I/E.
must have been an early 630 package as most of the heads coming out of LPE lately have had ferra solid SS exhaust valves, my father stepped up to the Inconel solid exhaust valves.
So all this talk about the Fast intake versus stock, is there something to that? Is the design improved in those that can help alleviate this problem?
Well, detonation is something to consider however, this is definitely not the first time I've heard/read about a ls-series engine having a cylinder #7 (or a rear cylinder) failure due to a lean condition.
That is one of the reasons I went BS3 when I was initially piecing together the build for the camaro. Individual cylinder programing for fuel and spark... among other trick features.
Was this Chris's car Vince? Was he running nitrous on it? I think somewhere I read he was running the bottle. I would go back to who tuned the car if nitrous played a roll in this failure.
No nitrous (at least not that I know of). That's just rumor and speculation. Yes, Chris's car.
