View Poll Results: If you have had catastrophic engine failure or a dropped valve: please check one
Voters: 21. You may not vote on this poll
[Z06] Poll on LS7's with dropped valves or catastrophic engine failure
#61
2nd Gear
First motor blew round 19k miles, not sure what happen but guys at GM try to say I float a
valve or over reved it. After fighting for while they replace whole motor and sent back to bowling green. Still cluessless as to what happen? They didn't tell me what cause or tell me the problem. 100% stock
Now at 35k or roughly 16k miles later on new motor, one morning went to start car up to check oil before going out and heard a taping noise. Tow to GM and found out the tapping
noise was a broken intake valve seal causing it to float up and down on valve. Guess I got lucky and caught it before valve drop. Worst part was GM rep void my warranty cause I had a killer bee intake no tune. No way will I pay GM for another stock engine
#62
Right. I misunderstood what you meant. Still, have not heard nearly the issues out of the GT500 or Viper (or any other car in the 500+hp league). What are the odds that multiple people have had bad engines one after the other if the odds are less than 1% of ONE faulty engine? Either we have quite a few forum members who should have played the lotto and bought a Veyron instead, or that <1% is inaccurate. Not trying to dog the car, but the facts cannot be denied.
#63
maybe in order to participate in a post a member should be more than a newb, literaly...at leat one post a month would be nice, not one every 16 months...mind you into a "touchy" threat...almost like someon taped you on the shoulder to "go and vote"...no posts about those 2 grenated motors either, nor even participating in any of the other preceding discussions...
#64
Put me down for "Stock motor, dropped valve"
Will be interesting to see the result
Statistics so far as of june 30,2010:
There have been 1082 viewers of this poll as of the moment I write this reply.
There have been 18 engines that have had catastrophic failure.
*This represents about 1.6% engine failure rate assuming all 1082 that viewed the post and of those 1082 those with catastrophic failure actually voted.
There have been 10 of those that are totally stock that have had catastrophic engine failure (No Tune and No Mod)
*This represents slightly less the 1% engine failure rate assuming all 1082 that viewed the post and of those 1082 those with catastrophic failure voted.
*It seems a tune has no impact on engine failure as there are more failures on stock tunes then there are tuned motors - this statement would assume half the viewers of the poll have tunes and half still remain with the stock tune.
1% engine failure rate or 1 in 100 - seems pretty high.
This should make the folks from GM that monitor our forum take notice.
Here are my blown motor pictures:
http://s1134.photobucket.com/albums/...lown%20Engine/
I have since built my new motor up in hopes that it doesn't blow up. I replaced the springs and valves along with some other goodies.
Here is my original story. I have had heard that this issue is a lot bigger than just 10-20 motors.
http://www.digitalcorvettes.com/foru...20#post1949920
Here is my story, its long and confusing, but its facts. I will never go to Munday Chevrolet or buy another GM product because of this..so thanks GM for screwing me out of $17k. I have since screwed you out of $100k by talking people out of not buying a GM product because you fail on customer service.
#65
John from Australia , 07 c6 z06 drooped valve 30k miles 2 hrs on a track 20k later
#66
I have not (yet) had a failure, consequently I did not vote. However, there is little doubt that my 2006 Z06 was destined for a failure had I not had my faulty guides replaced as a preventive measure. While at it, EVs were replaced with SS.
I am hoping to sell the car this summer, and am unsure whether my preventive work, which I will clearly disclose, will be seen as a positive aspect or not by potential buyers. I tend to think potential buyers will view it negatively. Hopefully I am wrong.
#67
DH
#68
[...] Now at 35k or roughly 16k miles later on new motor, one morning went to start car up to check oil before going out and heard a taping noise. Tow to GM and found out the tapping noise was a broken intake valve seal causing it to float up and down on valve. Guess I got lucky and caught it before valve drop. Worst part was GM rep void my warranty cause I had a killer bee intake no tune. No way will I pay GM for another stock engine
In any case, I don't think the broken seat/seal alone would cause a valve to drop. Of course whatever beat that seal up could have beat up the valve as well.... (an exhaust valve dropped in the engine below, with little or no valve guide wear).
[...] Here the #4 intake valve seal was in three pieces and the exhaust valve seal clearly worn on the bottom. It sure looks like the valve spring is pounding the seal's base. Hopefully one of our engine builders reading this can explain whether this pounding can happen. I guess if there is valve float it is possible.
#71
It's not like you have something to hide, but your average buyer isn't going to know about the issues be likely will be unhappy that you tinkered with the motor.
#72
If they know enough to ask, they'll be pleasantly surprised that you took care of it. If they don't, I wouldn't bring it up any more than I would bring up other maintenance specifics unless asked. "Well maintained and here are the records".
If the car were otherwise stock, I wouldn't bring it up unless the prospective buyer knew enough to bring it up.
And if he did, then he'd be pleasantly surprised to see that the matter was taken care of.
If it had a skip shift plugged in, C5 Z06 axles, a ZR1 X pipe, DRM Bilstein shocks with poly bushings, aftermarket tunnel plate, Hawk brake pads, I probably wouldn't say anything either.
Some of the above stuff, the owner may honestly forget that he installed it, if it was long enough ago.
The rest, is not going to matter unless the owner is asked. I sell a used car, I sell it as is.
Unless the buyer specifically asked has it had any engine work done to it, or similar question, I wouldn't bring it up.
#73
valve failure on exported '07
Hey!
I'm from Sweden and i have an US '07 Z06. 2 days ago we did the "wiggle test" on my valves after discovering a rattle from the engine at 1400-1600 rpm.
All intake valves on the passanger side was wiggleing... even with the springs mounted so car was sent off for head-renovation.
Mine is stock motor and has gone 26000 miles (42000 km).
#74
Hey!
I had similar results with 9k miles. They were measured at spec level or below on driver side.
Suggests temp is not the culprit (many knowledgeable posters have posited that exhaust gas temperature is the problem). Likely, improper surface finish on the valves..
#75
I love this discussion. Many of the folks with no problem, bury their heads in the sand and say, "Must have been operator error...." The folks that have had a problem understandably say...."GMs fault!"
I am going to call for a Karma Tsunami and say to all that think this is a Audi Unintended Acceleration of much todo about nothing, may you be the ones that get the 1% failure rate from now on out.
For those that are seriously concerned and either have opted to spend insurance money on an extended warranty or on rebuilt heads, may you be the ones to be in the 99% from here on out.
After a year or so of this we can retake a poll and see how the "unintended acceleration" crowd feels at that time.
I did the max GMPP thing and the motor is staying dead stock to keep it in force as long as possible and I will enjoy my car in the meantime with less stress.
Enjoy and never forget to wave.
#76
I heard my valve train get louder and knew exactly what was wrong and was going to tear it apart that weekend but i kept driving the car like a dumbass .
It dropped an Evalve that night sitting at a traffic light .
#78
I just bought my 07 Z; one owner 34100 miles, I drive it daily and i am very gentle with it. These threads are ruining my joy. Car does have a tick noise 1200-1900 rpm but it goes away when I slowly rev up. All LS engine make that noise,some louder some quieter.
I barely hit 1400 rpm in the city; mostly at 800 in 6th gear 40mph. I can't imagine a valve would break driving like a NORMAL HUMAN BEING.
