View Poll Results: Supercharger VS. Cam/heads/pistons
Voters: 22. You may not vote on this poll
[Z06] C-6 Z-06 rear end gears.
6th Gear
I am finally having some work done on my 2007 Z-06. I知 having the head issue squared away with new heads and I知 having a mild cam, new headers and an exhaust cut-out switch installed. I知 also having a new intake installed and all the bolts, fasteners, plumbing lines, and gaskets upgraded. My question is this, what rear end do I want to put it the car? Mind you it will never see a drapstrip nor racetrack, however most miles I put on it will be highway or driving around the Lake where I live to and from corvette shows. I知 thinking 3.73 or 3.90 as 3.55 isn稚 that much different than the stock 3.42痴 and 4.10 is too extreme. It already has a close ratio shifter with a ball on it. Any suggestions would be greatly appreciated! Also what does every think about LMR doing the work? I realize that they are expensive but I want it done correctly and if anyone knows a better or more inexpensive option I would gladly entertain that. Rat痴! I guess also, thoughts on a supercharger over a cam and emissions testing. Thank you all.
3.90's and 4.10's are your ONLY option for the rear end unless you upgrade to a race unit which is in the $8-10K range.
Glenn Bland (01-06-2022)
All I'll add is this; the guys I've talked to say that the 3.90 diff makes 5th and 6th gear more useful, without really subtracting anything from drivability or fuel mileage. But it's not cheap. I kinda agree with keeping stock gears. If you will never see a strip or HPDE, there's really not much point in it. My .02....
double06 (01-07-2022)
Received 4,713 Likes
Welcome to the forum! For your type of driving, I would stay with the stock gears
The following 3 users liked this post by Pb82 Ronin:
Mine would hook if you rolled into the throttle and didn't floor it til after 4k. Now that it's H/C/I no chance. I would do a 3.90 if you're going to run a sticky tire at all times. If not I'd leave the stock gearing. A cammed ls7 can get out of shape in a hurry even with the stock gear on street tires
I have had the 4.10's since early 2018 and it is the best mod for driving the Z, IMO. It still gets mileage way over 20 mpg, third gear is a blast, and you can now use all six gears when doing cruising on the back country roads. It was big bucks at the time, but I sure enjoy it. I don't even try, but if the shifter was bolted right to the trany like my old Z/28 was I'd be back to the original no lift shift. Honestly it really makes driving it a lot more fun. BTW the 3.90's throw the speedometer off, a fixable issue. The 4.10's ring gear is the same number of teeth as stock so no issues arise.
There is no better seat of your pants bang for the buck mod than 3.90's
Do it
Do it
Cone killer (05-02-2023)
I致e been thinking about 3.90 gears for a few months now, but curious to hear a rough estimate on what people have paid for the swap (labor.) Anyone aware of the average cost for install?
