Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2011, 02:48 PM   #21
BigMike NY
CF Senior Member
BigMike NY's Avatar
Hi Jason,
I am getting ready to start modifying my BONE stock '08 Z. The initial mods forthcoming are as follows: American Racing Headers w/ x-pipe and hi-flow cats through factory exhaust, Halltech CF112 & beehive, 160* thermostat and of course a custom tune. Which one of your Katech cams would you recommend?
What kind of power can I expect with the above listed mods, cam included?
Thank you
Mike
__________________
*2008 Corvette ZO6*, Velocity Yellow, 3LZ
Cartek Stage 4 Heads & Cam, Halltech CAI (CF112), Kooks Headers 1-7/8" W/ Hi-Flow Cats, Cartek Custom Tuning, FAST 102 Intake, NW Throttle Body, 160* Therm, Factory Catback, Katech LS9R Clutch
BigMike NY is offline   Reply With Quote
Old 07-03-2011, 02:55 PM   #22
RGT
CF Senior Member
RGT's Avatar
Send a message via Yahoo to RGT
Quote:
Originally Posted by Mopar Jimmy View Post
WOW, the Torquer 110 made considerably more HP and TQ throughout the entire RPM band. If I had to choose right now Torquer 110 all the ay baby!
RGT is offline   Reply With Quote
Old 07-03-2011, 10:07 PM   #23
0Halltech
Former Vendor
St. Jude Donor '09
Halltech's Avatar
Halltechsystemsllc
Quote:
Originally Posted by Katech_Jason View Post
Yes
~530
1. Interesting idea
2. We did that. It traded ~5hp for 5tq
13:1 compression
E85
FAST manifold
102mm throttle body
I haven't driven the car yet, but idle/drivability should be very good. Jim Hall loves his.
I tried to pick two of the most idential engines for this comparison. Both Street Attack LS7s without ported heads, FAST manifolds, or bigger throttle bodies.
I was not looking for the highest HP number, but rather a super street manners. The 110 is just about right for most guys and would have put us well over 600 RWHP.
Our car works on the power/weight ratio goal, which we have a 4.2lbs/hp and insane torque. That is a better ratio than the Bugatti Veyron.
Halltech is offline   Reply With Quote
Old 07-04-2011, 01:08 AM   #24
40YRW8
CF Senior Member
40YRW8's Avatar
Jason,
A couple of guys asked about the dip in the torque curve. Do you think that the FAST LSX-R manifold with the longer runners might smooth this out a little or possibly eliminate it? From what I have seen on dyno runs with the FAST, that seems to be about where it has an advantage over the stock manifold. Have you tried one with the FAST manifold?
Gary
40YRW8 is offline   Reply With Quote
Old 07-04-2011, 10:07 AM   #25
Vito.A
CF Senior Member
Vito.A's Avatar
Send a message via AIM to Vito.A
It would also be interesting to see the HP/TQ curves for 1000-3000rpm since that is where the engine operates 90% of the time on the street.
Vito.A is offline   Reply With Quote
Old 07-04-2011, 02:24 PM   #26
Michael_D
CF Senior Member
Michael_D's Avatar
Quote:
I agree. Dyno sheets that do not show this part of the curve are not telling the whole story.
Michael_D is offline   Reply With Quote
Old 07-04-2011, 05:01 PM   #27
Z06Ronald
CF Senior Member
Z06Ronald's Avatar
Z06Ronald Z06Ronald
It would make more due to dyno headers, aftermarket calibration and J607 vs J1349 correction factors.
At the risk of being dumb ... what do these correction factors mean?
__________________
http://www.youtube.com/user/Z06Ronald
< Amsterdam, Netherlands >
Z06Ronald is offline   Reply With Quote
Old 07-04-2011, 06:01 PM   #28
kingpinfarr
CF Senior Member
I've had the Torquer 110 since April, 2k miles. It rocks. Nearly zero compromise in driveability. Running 25-deg advance at idle, it's difficult to tell whether or not the vehicle is bone stock (from idle quality). Pulls hard off the line, but there's a noticeable seat-of-the-pants increase in torque around 4k-rpm. Revs to the sky smooth and quick. For NA applications, no doubt I'd take the 110 everytime.
Only complaint: I think it should be in the $380-$430 range like every other LS7 cam, especially considering it's manufactured by CompCams. Wasn't enough of a complaint to keep me from buying it though.
kingpinfarr is offline   Reply With Quote
Old 07-05-2011, 10:57 AM   #29
Katech_Jason
Premium Supporting Vendor
Katech_Jason's Avatar
Katechengines
Send a message via AIM to Katech_Jason
Quote:
Originally Posted by Michael_D View Post
Jason,
Have you done any further testing / comparisons with these two cams?
What do you think is happening to cause the dip in torque between 3200 and 4400 with the 110 grind? It's still there with the 116, but not as severe.
Did you try advancing / retarding the 116? I'm assuming the posted dyno run is with it straight up?
Just this test. The dip in the torque curve is normal for LS engines and has to do with runner tuning although it is also affected by camshaft as you see here.
We did not sweep test the cam. Often times its installed straight up, but in this test engine for whatever reason it was installed at 110.
Quote:
Originally Posted by BigMike NY View Post
Hi Jason,
Thank you
Mike
Normally we go with the Torquer LS7 110 as it suits 95% of the customers looking to do a cam. By most people's standards for doing a camshaft it's mild, but the 116 is even milder still. The 110 will put you at about 600-610bhp with proper intake and exhaust, the 116 at about 585.
Quote:
Originally Posted by 40YRW8 View Post
Jason,
Gary
Here is our LSXR A-B test. It looks like direct torque curve shift. No changes to the dip.
http://forums.corvetteforum.com/c6-z...t-results.html
Quote:
Just real quick and simple...The dyno is correcting the horsepower for weather conditions so no matter what the conditions of the day are, we can duplicate the performance from day to day. The baseline for this correction factor is different between the two correction factors.
J607- 60F, 0% humidity, 29.92 in-Hg baro
J1349 - 77F, 0% humidity, 29.234 in-Hg baro.
Katech_Jason is offline   Reply With Quote
Old 07-05-2011, 12:37 PM   #30
JOHN*99*
CF Member
Default Which injectors were used?
Do the tests with the Fast LSXR use the the stock LS7 fuel injectors with the OEM style fuel rail with spacers? I have some concern that spacers will effect the fuel spray pattern since the tips are raised in the port.
JOHN*99* is offline   Reply With Quote
Old 07-05-2011, 12:44 PM   #31
Katech_Jason
Katechengines
Quote:
Yes, they did.
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Performance
__________________________________
http://www.katechperformance.com
YOUTUBE
FACEBOOK
MAILING LIST
Old 07-05-2011, 12:53 PM   #32
u1arunit
CF Senior Member
u1arunit's Avatar
Yes, they did.
So Jason, have you not found the spacers to be a problem with the injector spray pattern?
u1arunit is offline   Reply With Quote
Old 07-05-2011, 01:12 PM   #33
Katech_Jason
Katechengines
Quote:
Correct - no problem
__________________
_Jason Harding
YOUTUBE
FACEBOOK
MAILING LIST
Reload this Page Katech Torquer LS7 110 vs 116
Tags
110, 116, 427, c4, cam, camshaft, comparison, dyno, e85, horsepower, jasonkatech, katech, ls7, torquer, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
