C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] use Castrol Syntrax Limited Slip 75W-140
Old 02-01-2021, 03:07 AM
Fred65
2nd Gear
Fred65's Avatar
Default use Castrol Syntrax Limited Slip 75W-140
hello,
Has anyone ever used Castrol Syntrax Limited Slip 75W-140 for the rear differential of a C6 ZO6?
thank you in advance,
Sports
Old 02-01-2021, 08:42 AM
RobRobinette
RobRobinette's Avatar
I haven't but why not just use the LS fluid GM recommends?
Old 02-01-2021, 11:37 AM
Fred65
2nd Gear
Fred65's Avatar
because I have 2 cans left and it's good oil.
RobRobinette (02-02-2021)
Old 02-02-2021, 10:53 PM
Navy Blue 210
Navy Blue 210's Avatar
75W-90 is the spec, 75W-110 is the heaviest I would even consider using.
75W-140 will increase friction & heat with no benefit.
To use Castrol Syntrax Limited Slip 75W-140
Quick Reply: [Z06] use Castrol Syntrax Limited Slip 75W-140
