C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Body creak noises
Old 02-13-2010, 06:53 PM
StoleIt
StoleIt's Avatar
Default Body creak noises
I have done a search and seems several Z06 owners have this problem. I haven't diagnosed mine yet but I definitely get loud, annoying, noises from the rear of the car when on an uneven surface or going onto/off of a gradient.
Some details on it Here
Has anyone brought their Z in to get this fixed? I assume (hope) it would be covered even if the vehicle is out of warranty (mines an 06).
Anyone has this issue resolved? It's fairly embarrassing to have friends, family, etc for a ride and the car makes more noise than a Model T when I back out of the driveway or turn into an elevated parking lot.
Old 02-13-2010, 07:30 PM
PatriotZ
PatriotZ's Avatar
Location: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Try the sway bar end links...pretty common and should be a warranty....check them and see if they wiggle from side to side....if they do then that could be the problem....I had the same issue and new end links fixed it....
Old 02-13-2010, 09:28 PM
StoleIt
StoleIt's Avatar
My 06 isn't under warranty anymore. This wasn't a recall was it?
Old 02-14-2010, 02:33 AM
MChicado
MChicado's Avatar
I had both noises--banging/knocking and popping/creaking sounds from uneven surfaces at slow speeds. I found a few things to correct that addressed most ALL of my bangs, knocks, pops, and creaks.
1.) I changed out the total JUNK OEM sway-bar end-links
2.) I torqued both lower cradles (front and rear)
3.) I torqued ball-joints and tie-rod ends that had a nut
I just got my weather seal grease yesterday--I'll do the weather seal on the back hatch to address the last few noises I hear.
V/R,
MC
Old 02-14-2010, 08:42 AM
jswatek
jswatek's Avatar
Mine was rear hatch weather seal.
Old 02-14-2010, 09:10 AM
Dicecal
Dicecal's Avatar
I just got my weather seal grease yesterday--I do the weather seal on the back hatch to address the last few noises I hear.
V/R,
MC
What end links did you use?
Old 02-14-2010, 09:11 AM
lar66BB
Support Corvetteforum!
lar66BB's Avatar
Rear Hatch weater seal.
Old 02-14-2010, 12:18 PM
BlaznZ06
BlaznZ06's Avatar
What weather seal grease are ya'll buying?
Old 02-14-2010, 12:40 PM
Joezone914
Joezone914's Avatar
On the Z it is typically the rear hatch seal rubbing. Open hatch & go over uneven pavement to verify. If it is lubricate.
Joe
Old 02-14-2010, 03:44 PM
Adam D
Adam D's Avatar
Joe
Im sure this is the same problem I have... What lubrication did you use?
Old 02-14-2010, 03:56 PM
FU
NCM Lifetime # 982
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Use di-electric grease on the weatherstripping.
My 06 had a squeek , drove me nut's (not a far drive).
The rear hatch hinges needed to be tightened.
Old 02-14-2010, 04:00 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Had the same issue over a year ago.
http://forums.corvetteforum.com/c6-z...creak-tsb.html
Grease the rear hatch locking mechanism liberally.
Oil won't do it. WD40 won't do it. Use grease. Same grease you would use for suspension parts.
I have not heard a peep out of mine in over a year now with just one application.
Old 02-14-2010, 06:30 PM
PatriotZ
PatriotZ's Avatar
Great Avatar
Old 02-15-2010, 01:05 AM
Joezone914
Joezone914's Avatar
di-electric grease
Joe
Old 02-15-2010, 01:24 AM
MChicado
MChicado's Avatar
pfadt links that come with their sways.
MC
Old 02-15-2010, 01:35 AM
MChicado
MChicado's Avatar
Some just use di-electric grease while others opt for the more expensive fix--DuPont's Krytox grease (ecklers carries it)
http://www.ecklers.com/product.asp?p...24&dept_id=123
MC
Old 02-15-2010, 09:43 AM
BlaznZ06
BlaznZ06's Avatar
Thanks everyone for the grease recommendation.
To Body creak noises
Old 02-16-2010, 04:31 PM
StoleIt
StoleIt's Avatar
Tried adding some Dialectric grease and went over my driveway with the hatch up and the noise still persists.
Hopefully tomorrow I will have it on a lift and can take a look at the rear suspension.
Old 02-16-2010, 07:19 PM
911's Avatar
I needed to apply grease to the hatch hinges to cure the problem
Old 02-17-2010, 06:12 PM
StoleIt
StoleIt's Avatar
Think I found the problem...
Yea...had it on a lift today to check out any possible culprits for the noise and change the oil. Thats the C clamp that holds the rear sway bar to the cradle.
Quick Reply: [Z06] Body creak noises
