Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-02-2009, 08:22 AM   #1
Capt_South_USMC
Junior Member
Capt_South_USMC's Avatar
Default RWHP conversion to engine HP?
Quick question:
I know mustangs generally have a 15% parasitic loss from the crank to the wheel. A Z06 is probably more efficient. What is the equation to figure out engine HP in a C6 Z06.
My Z06 has 570 RWHP
How much is that at the crank?
Capt_South_USMC is offline   Reply With Quote
Old 12-02-2009, 08:34 AM   #2
Painrace
CF Senior Member
Support Corvetteforum!
Painrace's Avatar
Send a message via AIM to Painrace
My guess is 12% to 14% depending o what has been done to the car.
Jim
__________________
PAINRACE
Painrace is offline   Reply With Quote
Old 12-02-2009, 08:36 AM   #3
Mark Ducati
CF Senior Member
Here's what I was told by Mike at Vengeance Racing in Cumming, GA...
Quote:
Mike from Vengeance said the relationship of HP at the fly is a ratio of 1.16 : 1.00... they dyno only gave me 483 RWHP, so extrapolating back we get to 560hp at the fly (which is only an estimate).
Mark Ducati is offline   Reply With Quote
Old 12-02-2009, 09:02 AM   #4
Capt_South_USMC
Junior Member
Quote:
Jim
mods to the car include a cam, CAI, headers and x-pipe, tune. None of which I believe would increase parasitic loss.
Old 12-02-2009, 09:35 AM   #5
glass slipper
CF Senior Member
Quote:
Originally Posted by Capt_South_USMC View Post
Quick question:
My Z06 has 570 RWHP
Three posts and you already have four "equations" or numbers. Obviously there's a problem and the problem is there is no one number you can use because it's not a linear relationship. The equation for HP loss is HP=Ax˛+Bx+C where x is the engine HP, A is exponential losses, B is linear losses, and C is constant losses. Exponential losses are things like inertia (on a pure inertia chassis dyno only), linear losses are things like friction at the gears, constant losses are things like gear churn or oil windage in the transmission/differential, tires, and seals (in other words, they're independent of engine HP). Most losses are constant losses so you'll be closest to FWHP if you add a constant plus a fudge factor if you have a known loss from a specific drivetrain. For Z06s, stock LS7s with 505 HP (SAE certified) have ~55 HP loss through the drivetrain. That puts you at 625 HP. If your peak HP RPM is higher than stock, add another 5 HP. Add another 5 HP for additional loss through the differential gears and that puts you at ~635 FWHP. There is no HP loss to gears in the transmission because there are no gears for 4th gear, it's a straight through power flow where the input and output shafts are "locked" together. Of course I'm assuming the dyno run was done in 4th and your tires were properly inflated. Large variations from SAE atomspheric and engine conditions will throw the readings off significantly also. In other words, if you dyno in very cold temps, the computer runs more timing than during SAE tests so the engine makes more power and the 505 HP starting point is no longer valid. Correction factors greater than 7% are not allowed due to large errors induced in the correction formulas.
The bottom line is you'll never know what your FWHP number is unless you remove the engine and test it IAW SAE procedures. Most people wanting to back calculate FWHP are looking for a large number to stroke their ego and use 15-16% while a stock Z06 is actually closer to 10% and that number goes down as you add HP if you wanted to go by percentage. But that means it's a moving target. Pick whatever number you want if you're looking to stroke your ego. The only thing you really know is you have 570 RWHP, and even then that's only on that particular dyno on that particular day with that particular tire pressure....and on and on.
I'd be proud to say 570 RWHP, that's a damn good number that puts you in a very limited class of cars in the US.
glass slipper is offline   Reply With Quote
Old 12-02-2009, 09:41 AM   #6
MTIRC6Z
CF Senior Member
Don't argue with this man (aka. glass slipper), he knows what he's talking about and has a TON of experience with measuring HP...and please don't ask how I happen to know this
Cheers, Paul.
MTIRC6Z is offline   Reply With Quote
Old 12-02-2009, 10:11 AM   #7
Scuba_Steve
CF Senior Member
Scuba_Steve's Avatar
, Well said! I've never believed in the percentage thing when trying to figure out crank HP. Why should a car have more drivetrain loss the more power it makes? It simply doesn't. HP numbers are just that, I've always liked to see/know what the car traps and how much it weighs, that tells me the true HP IMHO. It gets frustrating up here in Colorado where everyone talks SAE corrected dyno numbers, our correction factors are anywhere from 17-32% so you can imagine how inflated everyones numbers/ego's are. I only talk uncorrected numbers and my trap speeds show my true HP. Thanks for the post .
Scuba_Steve is offline   Reply With Quote
Old 12-02-2009, 11:31 AM   #8
Painrace
CF Senior Member
Painrace's Avatar
Clutch weight and size, CF drive shaft, RPM upgrades to transmission and rear end could reduce the loses. That is what I was talking about.
As I remember my car lost about 65 HP from the engine dyno to the chassis dyno. My car has a lighter clutch and the RPM upgrades. This supports what glass slipper says above.
In road racing throttle response is also very important and a dyno does not measure that.
Jim
__________________
PAINRACE
Old 12-02-2009, 11:38 AM   #9
Katech_Jason
Premium Supporting Vendor
Katech_Jason's Avatar
Katechengines
Send a message via AIM to Katech_Jason
I had to read this a few times before I understood what you're getting at. You're saying his 570rwhp car plus 55hp estimated drivetrain loss equals 625hp.
This should be a sticky. Glass Slipper, you are my new best friend. Finally, somebody who gets it!
IF YOU SPEED-READ THIS THREAD, ALL YOU REALLY NEED TO READ IS THE QUOTE ABOVE IN BOLD
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Performance
__________________________________
http://www.katechperformance.com
YOUTUBE
FACEBOOK
MAILING LIST
Katech_Jason is offline   Reply With Quote
Old 12-02-2009, 01:17 PM   #10
Painrace
CF Senior Member
Painrace's Avatar
If my memory is right I lost 10.79734%!
Jim
__________________
PAINRACE
Old 12-02-2009, 01:41 PM   #11
stkjock
CF Senior Member
stkjock's Avatar
Bravo! glassslipper that is the best write up on HP loss I've seen, makes good sense too!
I never bought into the 15% static number as a loose. I know its commonly accepted in the mustang world, I've never accepted it.
stkjock is offline   Reply With Quote
Old 12-02-2009, 02:36 PM   #12
EG@EnglandGreen
Supporting Tuner
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ ____________ 281.464.2800
englandgreen englandgreen stephenrawlins englandgreen
Excellent post!!!! I agree with everyone else - this should be a Sticky
Stephen
EG@EnglandGreen is offline   Reply With Quote
Old 12-02-2009, 02:58 PM   #13
jimman
CF Senior Member
jimman's Avatar
jimman is offline   Reply With Quote
Old 12-02-2009, 03:10 PM   #14
Capt_South_USMC
Junior Member
Thanks! I am not a mechanic by any means. I just love muscle cars. I learned a lot from this post. I am not fluent in mechanicanese so I appriciate that you broke it down Barney style for me. I am not trying to stroke my ego rather trying to see how it converts to others cars I come across. My car is faster than I will ever need. Thanks for the time you put in to help me out.
Old 12-02-2009, 03:35 PM   #15
WeaponsGradeTorque
CF Senior Member
There are others on this board who "get it".
It's been said before but people want to hear what they want to hear. Losses being quadratic is nothing new. My 600 rwhp is probably getting close to somehwere around 650 BHP is my estimate.
WeaponsGradeTorque is offline   Reply With Quote
Old 12-02-2009, 03:57 PM   #16
blkz
CF Senior Member
Wow . Glass , great post . Everyday I learn something form this forum . Thank you .
blkz is offline   Reply With Quote
Old 12-02-2009, 05:13 PM   #17
SlowZo6
CF Senior Member
SlowZo6's Avatar
General conversion for C6s is approx. 12-13%.
SlowZo6 is offline   Reply With Quote
Old 12-02-2009, 05:33 PM   #18
C5 Frank
CF Senior Member
C5 Frank's Avatar
Great Post!!!
My stock '06 Z06 has dynoed 471rwhp SAE.... I realize my car is no freak..... it was a good day on that dyno is all!
Also my car traps 126 in pretty good air... just like all the other well driven stock Zs..... freak it is not.
C5 Frank is offline   Reply With Quote
Old 12-02-2009, 05:35 PM   #19
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Well put Glass Slipper.
'06 Quicksilver Z06 is offline   Reply With Quote
Old 12-03-2009, 04:12 PM   #20
sts57c5
CF Senior Member
sts57c5's Avatar
Thanks for all the great info, I just had my corvette dyno performed last week and I had 365 RWHP and I am happy.
sts57c5 is offline   Reply With Quote
Reload this Page RWHP conversion to engine HP?
Tags
600, bhp, calculate, caluculate, conversion, convert, converter, converting, crank, engine, equals, fwhp, hp, mustang, rwhp
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
