C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Hydraulic Jack Cross Bar? Found it here...
Old 11-23-2009, 08:59 PM
mikes08z06
mikes08z06's Avatar
Default Hydraulic Jack Cross Bar? Found it here...
Northern Tool no longer sells the cross bar, I found it here:
http://cgi.ebay.com/ebaymotors/ws/eB...m=200402128326
Bought one. Fast delivery and good quality.
I thought others on this forum might want to know.
Old 11-23-2009, 09:04 PM
Fhqwhgads
Fhqwhgads's Avatar
I bought a similar one here (also finding that Northern Tool wasn't selling them anymore)
http://stores.toolzunlimited.com/Ite...Jack%20Adapter
Haven't tried it yet - the studs underneath the pads are really long (to the point I may have to chop them down to make them not drag on the ground). I'll be changing my oil soon so I'll let you know how it goes.
Old 11-23-2009, 09:47 PM
rws.1
rws.1's Avatar
thanks for the posts...
Old 11-23-2009, 10:02 PM
oldmansan
oldmansan's Avatar
St. Jude Donor '09
I want to say the Northern Tool cross beam adapters I bought were half the price.
San
Old 11-24-2009, 03:48 AM
JP426
JP426's Avatar
I ordered this one from Summit but it is on backorder.
http://www.summitracing.com/parts/SUM-918008/
Old 04-01-2010, 07:50 PM
bmack
6th Gear
bmack's Avatar
Can you tell me how it worked
Old 04-01-2010, 08:10 PM
P0LISH SAUSAGE
P0LISH SAUSAGE's Avatar
I just ordered 2 cross beam adapters from here today...
http://www.gregsmithequipment.com/Cr...r-p/ht1702.htm
Old 04-01-2010, 09:22 PM
Maxx Schlick
Maxx Schlick's Avatar
I have a pair of 3 ton Craftsman jacks with a pair of the Northern Tool crossbeams. They work great. The narower one fits the front and the wider one fits the rear. I can get the car up high and level. Once it is raised I put a jack stand underneath each end of the crossbeams.
Old 04-02-2010, 02:49 PM
jan eric
jan eric's Avatar
I got a 2/6" and screwed 2 6" inch pieces to the ends =3$ strong and light -works on front and back.
Old 04-03-2010, 11:08 AM
rws.1
rws.1's Avatar
sounds like the set up I use on my C5
Old 04-03-2010, 11:24 AM
Maxx Schlick
Good luck with that rig. Not to sure if it is prudent to use wood where you should be using steel, especially just to save a whopping $39 bucks.
Ever see the TV show called 1000 Ways to Die.
I can see it now, Jan's rig worked fine for a few times but then the $3 piece of Pine snapped in half, jack slipped out and Jan was squished down to the thickness of a bloody speed bump. Somebody get a mop.
Old 04-03-2010, 12:49 PM
Vito.A
Vito.A's Avatar
Actually, the wood is more forgiving on the front magnesium cradle. You do not get under the car until it is supported with jack stands.
Jan, would you post a picture of your adapter?
Old 04-03-2010, 01:08 PM
Maxx Schlick
The steel crossmember dosn't come into contact with the crossmember, the rubber pads do.
BTW it's embarassing to admit it, but before I got the steel crossmembers, I had a homemade wood one that I had rigged up, I felt like a complete fool when it snapped in half.
Old 04-06-2010, 02:53 PM
Maxx Schlick
I saw this snapped in half truck today and couldn't help thinking of home made wooden cross beam adaptors.
To Hydraulic Jack Cross Bar? Found it here...
Quick Reply: [Z06] Hydraulic Jack Cross Bar? Found it here...
