Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-09-2009, 02:49 PM   #1
exz06ic
CF Senior Member
exz06ic's Avatar
Send a message via AIM to exz06ic Send a message via Yahoo to exz06ic Send a message via Skype™ to exz06ic
Default GTO Spares for Skinnes for C6Z? Opinions Wanted
Has anyone ran GTO spare rim setup on a C6Z? Were there any issues with clearing the front brake calipers? Did you have to use spacers? Any feed back would be appreciated.
exz06ic is offline   Reply With Quote
Old 11-09-2009, 05:33 PM   #2
Shark Racer
CF Senior Member
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
They're 17s, aren't they? I think it would be unlikely they would fit. (even if they're 18s, these are monstrous calipers and the spare is probably pretty skinny.)
Shark Racer is offline   Reply With Quote
Old 11-09-2009, 05:59 PM   #3
Louis @ LG Motorsports
Premium Supporting Vendor
Louis @ LG Motorsports's Avatar
They do not clear the brakes
Louis @ LG Motorsports is offline   Reply With Quote
Old 11-09-2009, 06:14 PM   #4
Reference vid so you can see how it looks. They look odd, but they do work with base brakes.
Old 11-09-2009, 07:25 PM   #5
exz06ic
CF Senior Member
exz06ic's Avatar
Whats another inexpensive setup i already have 18x12 rear w/ 335 all i want is a set of front skinnies. I would love to get a set of cut down stock fronts.
Old 11-09-2009, 09:07 PM   #6
DaOtherOne
CF Senior Member
DaOtherOne's Avatar
Quote:
WOW .. that's crazy .. dump the clutch at 7K RPM ..
DaOtherOne is online now   Reply With Quote
Old 11-10-2009, 04:38 AM   #7
Cman01
CF Senior Member
2008 Chevrolet Corvette
Cman01's Avatar
So that skinny wheel setup on your CG Z06 is from where???? I would like a front skinny setup like that for when I hit the track but don't want to spend a ton of money on it. If a spare tire setup from another GM car will bolt to the front of a Z and clear the front brakes that would be the way to go.
Tony
__________________
T. Chan
Toronto, Canada
09 CG Z06 "Whipple Whipper v2.0"
01 Sentra SE, 07 SX4 (current DD)
Cman01 is offline   Reply With Quote
Old 11-10-2009, 11:21 AM   #8
Scuba_Steve
CF Senior Member
Scuba_Steve's Avatar
Quote:
Tony
They are GTO spares.
__________________
06 C6 Z06 ~ 514whp 450wtrq = 11.12@131 (DA 5301)
Revolutions Performance-(719)635-6200 J&S Polishing-(719)477-9484
Scuba_Steve is offline   Reply With Quote
Old 11-10-2009, 11:37 AM   #9
yenkovette
Junior Member
yenkovette's Avatar
Two minor problems if you care regarding GTO specs: they are not 5x120.65 PCD, they are 5x120 mm, and they are not hubcentric for a Corvette. So I doubt if any engineer would approve.
yenkovette is offline   Reply With Quote
Old 11-10-2009, 12:23 PM   #10
68sixspeed
CF Senior Member
68sixspeed's Avatar
Quote:
plus aren't they only rated for like 45-50mph?
68sixspeed is offline   Reply With Quote
Old 11-10-2009, 02:06 PM   #11
kumar75150
CF Senior Member
kumar75150's Avatar
Send a message via AIM to kumar75150 Send a message via Yahoo to kumar75150
Quote:
I think CCW is around 500 a wheel for skinnies. Not really an inexpensive option out there.
kumar75150 is online now   Reply With Quote
Old 11-10-2009, 03:02 PM   #12
Cman01
CF Senior Member
Cman01's Avatar
ok, LG I'm a little confused. You said earlier the GTO spares don't clear the brakes then you say they clear the base brakes. Then you have a Z06 with those wheels on it in your video but the bolt pattern is just a tad smaller than a Z06 bolt pattern.
What are you referring to AFA "base" brakes??? Stock C6 Z06 brakes??? If the bolt pattern on those wheels are just a little bit smaller than a corvette bolt pattern how did you get those wheels on your CG Z06????
Please clarify.
If you can provide some pics of those spares on that Z06 it would be great. You don't see them for that long in that video and the viewing angle was also quite sharp.
Old 11-12-2009, 04:36 AM   #13
Cman01
CF Senior Member
Cman01's Avatar
^^^^^^^^ttt, looking for answer on above post.
Old 11-12-2009, 10:35 AM   #14
walterm32
CF Senior Member
walterm32's Avatar
I'm pretty sure LG is talking about base c6 brakes. I know of a few c6 guys that run the gto spares up front. I think the c6 z51 brakes are even a bit too big to run the gto spares.
As far as the bolt pattern goes, I have no idea. I figured it was the same...
walterm32 is offline   Reply With Quote
Old 11-12-2009, 11:41 PM   #15
PRE-Z06
CF Senior Member
PRE-Z06's Avatar
Send a message via AIM to PRE-Z06 Send a message via Yahoo to PRE-Z06
Quote:
The tires are only rated for a constant speed of 55mph, but plenty of people people swap them to m&h front runners if concerned. I've been running the stock spare tires for 3 years w/ over 100 passes at 120mph+ and they've even seen 130+ on my buddies juiced c5z. Gary2004z06 also runs them on his c6z with "base model" c6(ie non z51) brakes. The only other modification is the hub opening has to be ground ~1/8" bigger on the wheel, as goats have smaller diameter hubs.
PRE-Z06 is offline   Reply With Quote
Old 12-10-2009, 02:52 AM   #16
fotoboy
CF Senior Member
fotoboy's Avatar
same here, just ground the center to fit the c5, had the spares balanced and all is good to 125 mph blast no problem
fotoboy is offline   Reply With Quote
Old 12-10-2009, 11:26 AM   #17
Scuba_Steve
CF Senior Member
Quote:
That's great but they still won't fit a C6Z unless you swap the brakes, which is what the OP was asking.
__________________
Old 12-10-2009, 04:36 PM   #18
fotoboy
CF Senior Member
fotoboy's Avatar
Quote:
how did lg do it?
Old 12-10-2009, 05:03 PM   #19
Cman01
CF Senior Member
Cman01's Avatar
I found a couple videos of this person running those spares on his Z06. He switched out the stock brakes to regular C6 calipers:
http://www.youtube.com/watch?v=j9VpA...eature=related
Don't want to go this route now (I'm keeping my stock Z06 brakes). Gonna look into picking up 2 front C6 Z06 wheels from the boneyard (for dirt cheap) and maybe sending them out to weldcraft to get them narrowed for drag duties.
Tony
Old 12-10-2009, 11:41 PM   #20
Scuba_Steve
CF Senior Member
how did lg do it?
As LG said in his post he used base C6 brakes.
__________________
Reload this Page GTO Spares for Skinnes for C6Z? Opinions Wanted
Tags
2006, c6, gto, rim, spare, z51
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
