C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Time to freshen it up - GM Stage 3
Old 03-06-2009, 12:04 AM
jkittleson
jkittleson's Avatar
Default Time to freshen it up - GM Stage 3
After putting 20,000 miles on my 427 build, I decided it was time to tear it down and freshen it up. Glad I did because the caddy lifters were starting to come apart.
The car is mostly going to be dedicated for the track, so I upped the cam from the Katech Torquer to the GM Stage 3 grind and compression has been raised from 10.4:1 to 12:1. Last numbers from the previous build were 530 HP and 498 TQ to the wheels.
So to get the compression we decked the block .005" and the heads .050".
Here is the cam. - Thanks for the influence Short Throw. =)
Cam installed with Katech C5R chain. No more double roller to worry about.
I hate filing rings...
Pistons installed...
Everything torqued...
New clutch...
A little something for my buddy RC45.
Now if UPS would show up with the head gaskets, ATI under
drive and shorter pushrods, I could hear it purr. =)
Old 03-06-2009, 12:08 AM
RC45
RC45's Avatar
Nice... bring it on old man - I be ready for you
BTW, can you post up some photos of the Caddy Lifters... I still can't believe what they looked like.
Old 03-06-2009, 12:32 AM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
What fuel will you be tuning it on?
You will not be disappointed. Remember to utilize the higher RPM now!
New clutch...
The Textralia should hold your power. Have you thought about a lighter clutch? If you're driving it on the street, I understand your choice.
Great pics!
Any other mods to balance out your soon to be new found power?
Mike
Old 03-06-2009, 12:36 AM
dfinke23
dfinke23's Avatar
Milling that much, what kind of valve clearance do you have?
Old 03-06-2009, 08:45 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
That combo is good for 650hp.
__________________
Contact:
(e) zach@katechengines.com
Old 03-06-2009, 09:49 AM
jkittleson
jkittleson's Avatar
Great pics!
Mike
Will be tuning on VP C10 "100 Octane".
Hopefully I haven't lost all of my low-end since I increased the compression, but I know it won't have the grunt of the Torquer.
As far as the clutch, I looked at them all. The Textralia twin was backordered, so I went with the single. It worked pretty well for the last 20K miles. I am way over budget already.
Other mods include Hardbar Penske's, CCW wheels and Hoosier R6 and A6 combos. Soon as the tune is complete, I am putting a partial cage in it.
Old 03-06-2009, 09:51 AM
jkittleson
jkittleson's Avatar
I really should be fine, but will clay it tonight when the pushrods get here.
Old 03-06-2009, 10:00 AM
Short-Throw
I don't think you will be unhappy with any lower torque issues. I think you will be quite pleased how it will pull continually!
Isn't every project?
Brakes?
Old 03-06-2009, 10:01 AM
Katech_Zach
The extra compression will make up the torque lost from going from the Torquer cam to the Stage 3 cam. The last 12:1 Stage 3 cam LS7 we did made 569 ft-lbs.
Old 03-06-2009, 10:15 AM
jkittleson
jkittleson's Avatar
Correction on the fuel... Will be running VP Motorsport 109
Motor Octane 101
Research Octane: 109
R+M/2: 105
At 9.75 a gallon, can I mix this partially with pump gas and be safe to keep the cost down a little?
Old 03-06-2009, 10:30 AM
jkittleson
jkittleson's Avatar
Brakes?
Brakes are next. I am running stock calipers with 2 piece StopTechs and Hawk pads and Motul fluid.
Old 03-06-2009, 11:17 AM
Katech_Zach
Motor Octane 101
R+M/2: 105
As long as you have a homogeneous mixture of 60% 105 octane and 40% 93 octane (R+M/2) that would put you at 100 octane and that would be good. I'm not an expert on mixing fuels but I think that is how it works. How I arrived at that number was ((105 x 60) + (93 x 40)) / 100 = 100.2.
Old 03-06-2009, 11:45 AM
Luweegy
Luweegy's Avatar
When race fuel is dorment in the drum,is it ok to leave fuel in the pump line.Or should I pull the pump and put the cap back on the drum? Thanx
Old 03-06-2009, 11:48 AM
WFO
WFO's Avatar
Sweet..just sweet.
Old 03-06-2009, 11:54 AM
jkittleson
jkittleson's Avatar
If your talking about the drum pump, I would cap it off after use.
Old 03-06-2009, 12:14 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
I know you may want to use race fuel to extract as much as you can with your current combo but couldn't you also run 12:1 with pump gas?
Old 03-06-2009, 12:18 PM
jkittleson
jkittleson's Avatar
Not really worried about the little extra power. Just don't want to melt a piston.
I hear plenty of people running 12 + on compression without issues, but I hear the other side that says it's required. I personally think I'm right on the edge. Since 98% of the time this setup will be used on the road course, I just want to play if safe.
To Time to freshen it up - GM Stage 3
Old 03-06-2009, 12:22 PM
Red Rochester
Red Rochester's Avatar
Old 03-06-2009, 03:25 PM
jkittleson
jkittleson's Avatar
Originally Posted by Red Rochester
Sorry guys, I already threw them away. But the issue I had was the pins in the lower rollers were coming out. One had already started wearing the lifter bore at the bottom.
I replaced them with the stock LS7 units this time around.
Old 03-07-2009, 11:51 AM
2002rich
2002rich's Avatar
Not trying to be an alarmest but I had a LS7 lifter fail. Part of the retainer plunger clip broke. Long story how I found it but I then replaced them with morels.
BTW - sweet build
Quick Reply: [Z06] Time to freshen it up - GM Stage 3
