[Z06] Control your 2006-2013 Z06 Bi-mode exhaust from your Car2U visor! No Fobs needed!
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Control your bi-mode exhaust from your 2006-2013 universal visor remote! No Fobs needed! Lifetime warranty!
Open and close your bi-mode exhaust right from your universal visor remote, no keyfob remotes needed at all. 100% ZERO Battery Drain in ALL install configurations!
The Lear Car2U visor Compatible Exhaust Commander is HERE! Get yours now! This controller works with your Car2U Universal visor remote! Its an exclusive feature found only on the Exhaust Commander car2u.
Introducing the new Lear Car2U visor compatible Exhaust Commander
One Button Wireless NPP/Z06/ZR1 exhaust controller!
For sale in my online store and ready to Command your NPP, Z06 or ZR1 Bi-mode
Exhaust from one button on your 2006-2013 Lear Car2U universal visor remote! No Fobs Needed, just your visor remote that is already built into your car!
I offered the first version of my Exhaust Commander One Button
wireless NPP/Z06/ZR1 exhaust controller unit for sale 6 years ago. Now
here is the Lear Car2U visor compatible Exhaust Commander unit!
The kit includes the 2006-2013 Lear Car2U visor compatible Exhaust
Commander main receiver unit, and install instructions.
You can also have a keyfob remote added as a $25 option if you want to control the exhaust from outside the car. Keyfob remote is NOT needed to control the unit from your visor remote.
Take Command of you NPP, Z06 and ZR1 exhaust, you get to choose
whether the exhaust is Quiet and mellow, and you also get to
Command it to be Loud and mean when you want it.
Open and close your exhaust with ONE button on your Lear Car2U
visor. Switch between Quiet and Loud anytime at the push of a button!
You press the button on the Car2U visor once, the valves open and you are in Loud mode and ready to rumble! Press the visor button again the
valves in the bi-mode mufflers close and you have the quiet factory
operation mode, nice and quiet and opening at the factory rpm.
Exhaust Commander is 100% Zero Battery Drain when the
car is turned off.
Its a Simple 5 minute plug and play install! No permanent modification
is made to your car, it can be removed without a trace in 5 minutes.
Click Here to buy one--> Lear Car2U Visor Compatible NPP Exhaust Commander
Get your 2006-2013 Lear Car2U universal visor compatible Exhaust Commander One Button
Wireless NPP/Z06/ZR1 Exhaust Controller now!
Take Command of your NPP, Z06 or ZR1 Bi-Mode Exhaust!
Every unit is tested by me personally to ensure perfect operation and they are
backed by a 100% Lifetime Warranty!
I am completing the kits now and will be shipping them in the the order
the purchases come in.
[/SIZE]
Click Here -> Exhaust Commander D.A.S.H. the revolutionary new bi-mode exhaust controller!
NPP Bi-mode exhaust vacuum retrofit kits -> Exhaust Commander All-in-1 bi-mode retrofit kit.
My Online Store -> See all my Bi-mode Exhaust Controller Products!
car is turned off.
[/SIZE]
St. Jude Donor '13
Step 1: Fold down the passenger footwell carpet to reveal the fuse panel area.
Step 2:Pull the two fuses that the arrows are pointing to.
In the photo the fuses are already pulled out.
Step 3: Install the fuse adapter as shown in the top fuse slot.
Install the exhaust fuse signal wire into the left side of the exhaust fuse slot as shown,
and tie down the ground ring under the 7mm bolt on the amplifier as shown.
Step 4: Place the main unit underneath the amplifier.
Step 5: Use the supplied unique code to sync the Lear Car2U visor to the main unit.
Step 6:Fold the passenger footwell carpet back into place.
You are all done!
Great Lear Car2U compatible controller
I installed one of the sunset creation lear car2U controllers in July on my 08Z. Ben did what the other guys don't he integrate the Lear visor remote control.
Ben provided great support on the install. I also purchased the navigation commander, but haven't had time to install yet.
Ben is one of the best forum suppliers.
St. Jude Donor '13
I installed one of the sunset creation lear car2U controllers in July on my 08Z. Ben didn what the other guys don't integrate the Lear visor remote control.
I appreciate your support and business. If you need anything at all let me know.
I also sent you a PM.
Ben
St. Jude Donor '13
Have a Safe and Great Labor Day Weekend!
If you need any info, let me know.
Ben
Ben
Got mine installed last weekend--took maybe 10 minutes. The buttons are a little sensitive to program so I called Ben (6:30 PM Sat evening) and he talked me right through it. Kudos to Ben! Great product and great customer support. Highly recommended!
BTW--works Perfect...
Ben,
I've got a unit on order but it hasn't shipped yet. I looked at your instructions and realized there may be an install issue:
Where you have the box being installed is already occupied by the GM PAL unit in my car (per GM instructions). Is that controller box going to fit anywhere else there in the footwell? If not, I am going to be very disappointed to not be able to use your unit.
John
John
St. Jude Donor '13
Ben,
John
John
An alternative install method finalized. There will be a second install version that will work with the Pal installed in the factory manner. Since people have pals in the space my unit needs to go I am working on the alternate area to locate my box.
Ben
St. Jude Donor '13
Control your Z06 bi-mode exhaust from your Lear car2u universal visor!
No fobs needed, just the universal remote that is built into you car!
Ben
Ben
St. Jude Donor '13
Just installed one in a 2009 cyber gray ZR1.
Took less than 5 minutes and linked
to the visor in one try.
Ben
Ben
Quick question for ya: Do the exhaust valves operate as normal if you leave your system in the closed mode? Or is it only open or closed with your controller? Thanks.
St. Jude Donor '13
When the valves are closed they operate exactly like they do from the factory and open at the gm programmed rpm.
