[Z06] lets talk about LS7 HEADS ....
i have been searching here and there ..looking for options
so far :
West Coast Cylinder Heads ..
Precision Race Componets CNC Ported LS7 Heads:
ETP heads ....
any one hae used any of the above or any other option plz chime in with ur experience ....
what typicall cost ??
do u need to change rocker arms or not type of valves ?!
what are the avreage HP gains ..?
thanks
so far :
ETP heads ....
thanks
Former Vendor
so far :
ETP heads ....
thanks
so far :
ETP heads ....
thanks
Average gains depends on your set up, but most people will see between 28 and 38rwhp gains and sometimes more.
No need to replace the rockers. My vote: replace the exhaust valves with Ti units over the stock sodium filled original equipment. If you supply the heads, cost is usually close to $1,000 ready for installation (milled, valve job, exhaust port cleaning and cast cleaning).
These heads has enabled us to produce between 590 and 600 to the tires with our cams.
Thanks,
Carlos
All LS7 heads when done properly will give net you nice gains. We had pretty good luck with the WCC heads, they consistently perform pretty well.
Thanks,
Carlos
Thanks,
Carlos
