[Z06] My ls7 engine fails ,, help
His mods should not have voided the warrantee. You know GM, they will claim the engine mods needed a proper tune.
His location on the post only says Hadiya. I know of the one in Ethiopia, I didn't know there was a Hadiya in Kuwait too.
I would have thought that the company might have argued that a 'tune' could , by virtue of its inherent capacity to enhance the vehicle's performance potential, increase the stresses on the iternal components to a level beyond their rated design capacity.
It is my general experience of Warranties, that they are all 'fine' until you need to avail yourself of their guarantees - then the small print becomes imporant,and it assumes an importance ever greater, in direct portion to the size of the queue of those behind you, wishing to express the same complaint as yourself.
If the faulty vehicle is entirely standard with regard to the manufacurer's design specifications, then its worried owner will surely have less to worry about.
Peace of mind is a wonderful thing
Hello guys
i have 07 z06 and my engine fails due to oil pump fails (the engine F***ed up)
i don't know if it's covered by the warranty or not
i spoke to the service manager he told we received a report from GM refusing to change the engine.
the car modified with kooks headers and VR intake only does it drops the warranty Bcoz that's their reason to refuse
so what to do? any advice?
There are a few members in Kuwait with Z06s. You should do a search and PM them, they may know a good local dealer or shop you can talk to... probably better than the advice us Amreekee's can give you
Essentially there's really no correlation between a failed oil pump & headers etc.
Obviously, Chevrolet knows something no one else does.
I've noticed coporations don't seem to care about bad PR in this lousy economy. They care more about survival, apparently.
For example I've owned Hot Springs hot tubs for years, 4 of 'em in total. Solely because HS' iron clad 5 yr P&L warranty which had to be used in the past, no problemo. Tried making a (legit) claim with 'em couple months ago, they told me to pound sand.
The mo sounds awfully familiar.
Could swear it said he's in Kuwait.
As I've been alluding, yes you do. Headers can actually cause problems without being properly tuned to compensate (i.e. pinging and/or detonation).
thnx for the replys
Hadiya is the town where i live :P in Kuwait
I ask the dealer before i fix the headers and vr they said if you not open the engine that's fine but anything you aftermarket fix we will not cover it by warranty, now after this problem came they said another thing. i'm sure it's from the oil pump Bcoz when i started the engine again LOW OIL PRESSURE sign came and the gauge is reading below 100Kpa then dropped to Zero
i had fix the headers and intake but not yet tuned with someone (vette is his wife) had a tunening license and he was learning from lingenfelter people here in your country
now i'm waiting the report from the dealer ( i wanna fight )
my friend have knock noise in his car transmission he passed the warranty enddate and it will be repaired under warranty Bcoz he claimed before ending date,, BS they are playing
#33
thnx for the replys
#34
The engine idles fine "yes" but no oil pressure and little more louder sound comming from the engine
Anyone here from GM?
#35
The oil pump was fine - crakshaft bearings had failed.
Sorry to hear about your misfortune - best of luck with the dealer
#36
Guy's I had the same exact failure on my '09 Z with 10,3XXmi on it. Oil pump pressure went down to 6psi at idle and was about 21psi at 4k rpm. Took it in to the dealer on a sat. said it probably was just the oil pressure switch. Swapped that out the following Monday under warranty. Didnt solve problem so they moved to the oil pump and that's when they found metal shavings. Tore engine down crank bearing were shot. Long story short I have a new engine on the way should be back in car in couple of weeks and one months note paid. My only mod on the car was an custom axle back exhaust and wheels.
#37
Did you track it? Now I'm worried.
Side note, since these engines are hand assembled, what is the probability that the assembly could be intermittently prone to human error?
#38
glad to hear your getting a new motor though..
#39
No my car has never been tracked. Just the usual spirited driving that we all usually do. The bearing issue came a failed oil pump. So im not sure if that could be blamed on a assembly issue. Car was built 07/08.
#40
